Top Box? - Kawasaki Versys Forum
post #1 of 12 (permalink) Old 11-17-2013, 11:41 AM Thread Starter
Top Box?
I know top boxes have been discussed many times but here is my question.
I've been looking at the Pelican and Seahorse cases but I can't find a size I like. I keep looking for something around the size of the Trax 38 which is around 16x13x13. Everything I find seems to be short, maybe 8" tall at best.
Whatever I get is going to be going on a rack from Sam. I'll work out any necessary mounting for it so that really isn't important. Going to be working out a mating plate for a bow case too.
I did come across this case from Plano, but I would neeed to see how "stiff" it is, and it does seem a bit wide.
http://www.planomolding.com/product....ID=126&PID=877
I'd like to find something that I could build a bit of backrest into for the few times I coax my wife into getting on.
Thanks,
Mitch
Slow-Steady is offline
post #2 of 12 (permalink) Old 11-17-2013, 11:55 AM
If that's your only requirements, you're working way too hard.
Go to JC Whitney and oder one of these. It's 11" tall, comes with a mounting base, locks, has a backrest and is relatively inexpensive.
http://www.jcwhitney.com/garage-pro-...rid=c14523u0j3
I had one on my KLR, it wasn't the highest quality but it worked fine. It would hold a full face helmet and it stayed secure and dry.
ray h is offline
post #3 of 12 (permalink) Old 11-17-2013, 12:08 PM Thread Starter
Thanks, I completely forgot about checking JC Whitney. I see they have a couple options.
http://www.jcwhitney.com/emgo-univer...61729y2009u0j3
post #4 of 12 (permalink) Old 11-17-2013, 04:25 PM
I use a Rubber Maid Action Packer. They use to sell them at Walmart but now they have a Chinese clone about the same size. The Action Packer is cheap, durable, fairly waterproof and lockable. I am using it on Sam's rack. When I get around to it I will figure out a way to mount my milk crate.
waltermitty is offline
post #5 of 12 (permalink) Old 11-17-2013, 04:50 PM
genehil's Avatar
I'm running a Pelican Storm Case iM2450 Dry Box, 19.2x15.2x9in.
It meets my needs.
GeneHil - Mount Dora, FL
2011 Kawasaki Versys
genehil is offline
post #6 of 12 (permalink) Old 11-18-2013, 12:09 PM
RRKVERSYS's Avatar
Large top box option
My top box may be a bit too large for you. Here it is anyway. It measures 22 wide, 16 deep and 12 tall. It swallows two full face helmets no problem with room for more gear. Weighs about 12lbs empty. Has a rubber seal and four latches. It isn't water proof "as is" when you buy it. (I put a bright light in it, closed it, and took it into a dark closet and had light showing through a depression in the seal near the handle) but with a little ingenuity, it can be made water tight. At 22" wide, its still narrower than the handle bars. I don't take a passenger most of the time, but it is tall enough that mounting a back rest to the hinge side looks like an easy adaptation. I ordered hinge stays and lock from Pelican, although they aren't in these pictures. I run with it empty. Just a big trunk to store gear in when I get off the bike. It's built from a resined plastic sililar to a pelican case. Its much better than half as good (4/5 as good?) as a pelican case for 1/3 the cost and 1/2 the weight. It is a case for a plasma cutting machine made by Thermal Dynamics. Paid right at $100.00 for it before the stays and lock. Fits my needs to a "T" . Also have a set of Pelican im2600 panniers from twisted throttle. Using the Motech attachment system. I love it.
Name:	top box on Versys.jpg
ID:	38097   Click image for larger version
Name:	TOP BOX WITH HELMETS.jpg
ID:	38105   Click image for larger version
Name:	MOUNTED TOP BOX.jpg
ID:	38113   Click image for larger version
Name:	top box with im2600 pelican cases.jpg
RRKVERSYS is offline
post #7 of 12 (permalink) Old 11-18-2013, 09:40 PM
Topper's Avatar
Don't want to hijack, but what's the rack made by Sam a couple people have mentioned in this thread?
Topper is offline
post #8 of 12 (permalink) Old 11-18-2013, 10:13 PM
http://www.kawasakiversys.com/forums...uals+rear+rack
post #9 of 12 (permalink) Old 11-19-2013, 04:49 AM
His rack is the best I've seen for the Versys, fit is perfect and I had my rack in a couple of days.
post #10 of 12 (permalink) Old 11-19-2013, 12:56 PM
I bought a used steel one from another "inmate" here... TWO thumbs UP!!!
post #11 of 12 (permalink) Old 11-19-2013, 05:28 PM
Baron650's Avatar
Holy Cow, Round Rock, that is a BIG box!
I carry a cable lock to attach the helmet and s'tich when I'm off the bike. I keep it in my bright yellow Seahorse case.
Baron650 is offline
post #12 of 12 (permalink) Old 11-19-2013, 07:55 PM
RRKVERSYS's Avatar
I love the cleat idea Baron. I think I'll incorporate that into my pelican cases. Yeah.... my top box is large. OK.. HUGE... but it only weighs 12lbs and I don't travel with it loaded. Its sole purpose is to stash gear I get off my V. Well, maybe a few groceries on the way home too.
