Best replacement Mirrors? Not a fix to OEMs. - Kawasaki Versys Forum
post #1 of 20 (permalink) Old 07-07-2009, 02:07 PM Thread Starter
So in an effort to tighten my mirrors for the same reason as everyone else, I snapped the stem. They're Junk! So my question is for those that tried OTHER mirrors, which work best? Work worst? Thanks, I'll need to order new ones soon.
jeepinoutwest is offline
post #2 of 20 (permalink) Old 07-07-2009, 04:03 PM
DragonBreath's Avatar
I replaced the mirrors on my KLR with ones from TPI Motorcycle Parts. Follow this link and click through to KLR Section and then to Mirrors. The post is 10mm like most bikes, so it should work on the Versys. I also used their mirror dampeners. They may or may not have added value, but for less than $10 for the pair, it's worth trying anyway.
I'm probably going to order these to replace the mirrors on my Versys soon. If you decide to go this route, please report back here.
Chris in Oneonta, NY
>>>> states on a bike <<<<
>>>> East Coast done <<<<
>>>>> Westward HO! <<<<<
DragonBreath is offline
post #3 of 20 (permalink) Old 07-07-2009, 04:39 PM Thread Starter
Anyone try Z1000 mirrors, review? pics?
post #4 of 20 (permalink) Old 07-07-2009, 05:27 PM
I use bar end mirrors that screw into the OEM bars. They work a hellova lot better than the stockers, don't move at all, and were cheap.
schleppy is offline
post #5 of 20 (permalink) Old 07-07-2009, 09:20 PM
glowcat13's Avatar
Hey schleppy did you have to remove the bar end weights or are you still able to use them and what would be the chances of putting on hand guards with bar end mirrors any idea?
glowcat13 is offline
post #6 of 20 (permalink) Old 07-07-2009, 09:29 PM
I do not know why everyone has had problems with the mirrors I have had zero trouble with mine.
speedversys is offline
post #7 of 20 (permalink) Old 07-07-2009, 10:42 PM
Hi Jeepinoutwest,
The Z1000 work very well. Much less vibs than the OEM.
Also allows you to see further out to the side.
Best Regards.
post #8 of 20 (permalink) Old 07-07-2009, 10:57 PM
Part #'s, source?
>>>>> Westward HO! <<<<<
post #9 of 20 (permalink) Old 07-07-2009, 11:06 PM
Z1000 pic won't attach.
Sorry not able to help with the Z1000 mirror part no.
post #10 of 20 (permalink) Old 07-08-2009, 02:55 AM
LAVersys's Avatar
How much are those Z1000 mirrors?
LAVersys is offline
post #11 of 20 (permalink) Old 07-08-2009, 06:51 AM
Hi LAVersys,
Interesting online parts catalogue for the V:
http://fiche.worldofpowersports.com/...p?Type=12&A=72
Z1000 mirrors each USD 47.73
Refer to http://fiche.worldofpowersports.com/...=13&A=101&B=47
Can't conform but someone told me F800gs mirrors also work for the V.
Good Luck.
post #12 of 20 (permalink) Old 07-08-2009, 07:46 AM
MackDaddy's Avatar
Z1000, and CRG knockoff's on the bar ends as well. They compliment each other quite well...
MackDaddy is offline
post #13 of 20 (permalink) Old 07-08-2009, 07:51 AM
MN_Smurf's Avatar
ronayers.com lists the Z1000 mirrors for 41.34 each. LH part number is 56001-0117. RH is 56001-0118.
MN_Smurf is offline
post #14 of 20 (permalink) Old 07-08-2009, 09:04 AM
thequadnut's Avatar
heres mine
I love mine. Gave about the same as posted later in thread. nout $90 for the pair inc tax and freight.
2008 Versys
Muzzy Exhaust-race core!!
Upgraded Kawi Windshield
Madstadd Bracket
Fiamm 132 db low note horn
Osram Hyper 65 h7 lights
Kawi/Givi V35 Bags
Shad SH-29 Top Case
SW-Motech Quick release Brackets
Sw-Motech Alu-Rack
Garmin GPSMap 60csx
Joe Rocket Manta Tankbag-Red
Kawi Tank Protector
thequadnut is offline
post #15 of 20 (permalink) Old 07-08-2009, 04:19 PM Thread Starter
I ordered Z1000 mirrors today, $82 from cheapcycleparts.com includes shipping. Thanks for all the help.
post #16 of 20 (permalink) Old 07-09-2009, 02:58 AM
LAVersys's Avatar
Thanks you guys!
The Z1000 mirrors looks really good, much better than the original mirrors.
Z1000 mirrors just screw right on, right? No modification of any kind?
LAVersys is offline
post #17 of 20 (permalink) Old 07-09-2009, 04:32 AM
Yes, LAVersys. Just screw on. Using a spring washer to prevent mine from moving around.
post #18 of 20 (permalink) Old 07-09-2009, 06:06 AM
Question for the guys using Z1000 mirrors - Do these have the terrible "inner nut" setup with 4 washers and all that crap? or is it a straightforward bolt on type? I'm happy to shell down 80 - 90 bucks for a solid setup that I dont have to mess with often!
Thanks guys!
De-Silva is offline
post #19 of 20 (permalink) Old 07-09-2009, 08:17 AM
I put these on mine. They have a lock-nut at the base and are long enough that mirror extenders aren't needed. Vibration is almost nonexistent.
http://www.jcwhitney.com/autoparts/I...13815810000666
http://www.jcwhitney.com/autoparts/I...13815910000670
JonInMassachusetts is offline
post #20 of 20 (permalink) Old 07-09-2009, 10:20 AM
I took the bar end off, but if you had a long enough bolt you could definitely use both.
schleppy is offline
