2008 Kawasaki Versys - Detail & Features - Kawasaki Versys Forum
post #1 of 1 (permalink) Old 01-23-2008, 09:38 AM Thread Starter
Details and Features
Unique features
  • Aggressive styling
  • Powerful parallel-twin engine
  • Compact size and weight
  • Long-travel suspension
  • Comfortable cockpit
Engine
  • 649cc parallel twin-cylinder, DOHC engine is the most compact in its category.
  • The engine is considerably smaller than that of the Ninja 500 and helps reduce the dimension of the entire motorcycle.
  • Tuned to deliver smooth, responsive power in the low-to mid-rpm range with exceptional roll-on response –ideal for negotiating city traffic
  • Triangular crank and transmission shaft layout makes it short front to back, a semi-dry sump oil system reduces overall engine height, and the narrow pitch of the chrome composite plated aluminum cylinders helps reduce engine width.
  • Muffler with 3-way catalyzer and bullet-tip opening is mounted below the engine to help lower the center of gravity and aid weight centralization
  • 180-degree crankshaft plus balancer shaft for extremely smooth engine operation.
  • Oil jets on the connecting rod big ends spray oil on the undersides of the pistons to aid cooling.
Liquid Cooling
  • Maintains consistent engine temperatures for long engine life and sustained power during hard use
  • Allows closer engine tolerances for more horsepower
  • Fewer external hoses because the coolant is routed through the engine cases
Digital Fuel Injection (DFI)
  • Utilizes 38mm Keihin throttle bodies with ECU controlled sub throttle valves for optimum performance and rideability
  • The sub throttles, located behind the main throttle valves, permit the DFI system a more precise throttle response, similar to a constant velocity carburetor
  • Automatic fast idle system makes starting and warm-up easy
  • Precise fuel injection plus exhaust catalyzer significantly reduce emissions
Digital Capacitor Discharge Ignition (CDI) System
  • Microprocessor controlled timing never requires adjustment and is ultra responsive to engine needs
  • Spark plug mounted “stick” ignition coils are compact and help reduce weight
Six-Speed Transmission
  • Cassette style transmission means the shafts and shift drum are in a compact layout that is easily removed as a single unit from the case for easier maintenance
Trellis Frame
  • High tensile steel trellis frame is small and light
  • Designed using 3-dimensional computer analysis to achieve the optimum stiffness balance for better handling
  • Narrow at the knees and feet for increased rider comfort and control
Single shock Rear Suspension
  • Aluminum gull-wing swingarm and offset, laydown single rear shock complement the frame design to create an integrated line flowing from the steering head to the rear hub
  • Short, compact frame and engine design allows the swingarm to be longer, which helps improve overall handling
  • Showa shock has adjustable preload and rebound damping and uses a free piston and two-stage damping valves for smooth action during initial compression that becomes much firmer near the end of the stroke for a more planted feel
Long-Travel Fork
  • 41mm Inverted fork with stiff springs combines the best of off-road and sportbike-type suspension for excellent performance over a wide range of conditions
  • Tapered, relatively short outer tubes help provide the ideal stiffness balance to compliment chassis settings
  • Fork height, preload and rebound damping can all be adjusted to fine-tune the suspension to specific conditions or riding style
Triple Petal Design Brake Discs
  • Petal design rotors offer improved cooling and warp resistance
  • Same rotor design as found on the Ninja ZX™-6R and ZX™-10R supersport machines
Six-spoke wheels
  • Also found on the Ninja ZX-6R and ZX-10R; the six-spoke design requires much less material between spokes so that the rim thickness is thinner and overall wheel weight is reduced
Comfortable Cockpit
  • Each part of the two-piece seat was designed with a different thickness and firmness of foam to optimize comfort for both rider and passenger
  • Passenger seat and grab bars were designed to provide a natural seating position for added comfort
  • Easy-to-read instrument panel has a large analog tachometer and digital readout for the speedometer, fuel gauge, odometer, dual trip meters and clock. White LED backlighting provides increased visibility at night
Adjustable Windscreen
  • Three different settings, each 20mm apart, allows riders to adjust windscreen height to suit their preferences
Read the 2008 Kawasaki Versys Q&A with Karl Edmondson, Kawasaki Product Manager
Source: Kawasaki (www.kawasaki.com)
admin is offline
Similar Threads
2008 Kawasaki Versys Photos admin Member Rides 28 09-17-2008 10:18 AM
2008 Kawasaki Versys - Specs admin General Discussions - V-650 0 01-23-2008 09:46 AM
2008 Kawasaki Versys Introducton admin General Discussions - V-650 0 01-23-2008 09:26 AM
