Has anyone strapping camp items to Givi Top Rack? - Kawasaki Versys Forum
post #1 of 13 (permalink) Old 07-26-2013, 08:16 AM Thread Starter
Hey guys. I have done some motorcycle camping where I strap the bulky items to my rear passenger seat.
However, now I am planning on going for a quick trip 2-up style.
The problem is, now there is someone where my gear used to be .
So my inital plan is to remove my top box and use the Givi mounting plate as a 'platform' to hold/strap some of my gear to.. i.e. Big Dry Bag with gear + tent+ camp chair.
Has anyone does this before? Its not a huge platform so I am a little bit worried about the weight and/or the stability of the plate.
Did anyone come up with any other options?
Farkles:
Givi Tall Windscreen, Givi Top Rack and Case, Givi V35 Bags and Mounts, Givi QuickLock Tank Connector+Bag, Oxford Heated Grips, Nuvi 550 w/ Ram Mount, Barkbusters Full Wrap + Storm, Motowerks Flatfoot, Spools and Tank Protector, Bobbed Fender, Grip Puppies, 12v SAE Socket, Packjack, Airhawk 1 (med), Scala Rider G4, Contour Roam2
Next Stop: 44Tooth Sprocket (To be installed)
naudan is offline
post #2 of 13 (permalink) Old 07-26-2013, 09:27 AM
genehil's Avatar
I have a ktmduals rack where I have my Hardigg top box mounted for my long excursions. When the box is not mounted the rack is smaller than I would like so I purchased a $12 cutting board from Target and modified it to bolt to my ktmduals rack to give me more acreage to deal with...
GeneHil - Mount Dora, FL
2011 Kawasaki Versys
genehil is offline
post #3 of 13 (permalink) Old 07-26-2013, 10:19 AM Thread Starter
Hmm interesting.. I was hoping to avoid that if at all possible. But thats a better option than a piece of steel
I was also thinking that if I just put a smaller piece of wood on the inside of the drybag, that would give it rigidity so it would wouldn't sag .
Farkles:
naudan is offline
post #4 of 13 (permalink) Old 07-26-2013, 04:46 PM
I did what GeneHill did, but w/ a piece of aluminum. (Works fine!)
post #5 of 13 (permalink) Old 07-27-2013, 06:20 PM
Baron650's Avatar
Pretty sure you're going to exceed the load rating on the rack like that. Plus a passenger, that's a lot of weight up high. A lot soft bags will work pretty well even 2-up. Often you can get the straps to go under the seat.
Baron650 is offline
post #6 of 13 (permalink) Old 07-29-2013, 08:46 AM Thread Starter
I dont think its very heavy.. Just some sleeping bags, sleeping pads, a tent and a chair.
Its light stuff compared to what I shove into the top case usually.
I am more worried about the stability of strapping things to it :-/
I kind of dont want to go the route of making a makeshift platform.. doesnt work well with a GIVI since it isnt 100% flat like the other ones posted above.
Farkles:
naudan is offline
post #7 of 13 (permalink) Old 07-29-2013, 09:31 AM Thread Starter
Here is an example of what I was planning.
Hard to see, but I have 2 ROK straps holding it down. I just don't know if thats enough?
I have another set that I could put on the other way.. Anyone advise me against this?
3 hour ride on highway.
Farkles:
naudan is offline
post #8 of 13 (permalink) Old 07-29-2013, 09:51 AM
Not being a physics major, I don't know, but it sure looks a little top heavy and tippy for my taste.
massconn72 is offline
post #9 of 13 (permalink) Old 07-29-2013, 10:48 AM
Mine didn't 'tip-over' during the 7,508 kms I rode on my "North to Alaska..." adventure in June....
post #10 of 13 (permalink) Old 07-29-2013, 10:55 AM Thread Starter
Was that stuff on the pillon seat or a platform from a top case?
If so -- what did you bungie it to?
Farkles:
naudan is offline
post #11 of 13 (permalink) Old 07-29-2013, 08:13 PM
Baron650's Avatar
Oh, I see you already have hard cases. Well, that's a big bag, but as you point out, the duff is pretty light. Can you run a strap to the peg support trellis so the whole thing isn't hinging off the rack mounts?
Baron650 is offline
post #12 of 13 (permalink) Old 07-30-2013, 11:53 AM
Check the pics below. I didn't use bungees, I used four 'tie-downs' like you use to attach a V to a trailer - I figure those two bags (yellow one held the tent and sleeping mat, while the red one had the sleeping bag, pillow and blanket - NOT used - stove w/ utensils) weighed about 30 to 40 pounds MAX!
(Reason for the two bags is that I have one that will hold everything, but it leaked along its zipper when I rode to Mica Dam last summer - - - !)
ID:	28834   Click image for larger version
ID:	28842   Click image for larger version
post #13 of 13 (permalink) Old 07-30-2013, 11:58 AM
Here's a pic of the GREEN HORNET in Tok, AK, unloaded, but w/ the straps hanging down.
