Odometer Accuracy - Kawasaki Versys Forum
post #1 of 8 (permalink) Old 07-24-2013, 09:33 PM Thread Starter
Odometer Accuracy
I just got back from a 3,000 mile trip and made a major discovery. My odometer is not accurate.
For every 100 miles I ride, the odometer only registers 94. The speedometer though is accurate Ī 2 miles.
Not sure why this is the case. My rear sprocket was dropped to a 44, but that shouldn't change the accuracy like this. As it works in my favour, not sure I want to complain to Kawasaki about it, even if it still under warranty.
Anyone else notice this on their bike? Mine is an '11 if that matters.
revrandy is offline
post #2 of 8 (permalink) Old 07-24-2013, 09:46 PM
genehil's Avatar
I don't know about my 11's odometer accuracy but my speedometer's numbers are off by +2 according to my Garmin Zumo 660. When my speedo reads 50 my GPS is saying 48, etc.. The 2mph difference seems to be consistent throughout the entire range.
I have stock sprockets.
GeneHil - Mount Dora, FL
2011 Kawasaki Versys
genehil is offline
post #3 of 8 (permalink) Old 07-24-2013, 09:50 PM
Of course your odometer/trip meters are now off. You're geared 4.54% taller than stock with 15/44 sprockets... Your speedometer now reads about 3% under actual speed instead of about 7.5% under.
post #4 of 8 (permalink) Old 07-24-2013, 10:37 PM
kenr74's Avatar
I've noticed the same thing. My speedo will match my GPS but I can travel a known distance and my ODO will show less than actual.
kenr74 is offline
post #5 of 8 (permalink) Old 07-24-2013, 10:55 PM
I just came home from a trip that measured 5,679 kms on my ODO, but only 5,613 kms on my buddy's Honda. Pretty close for that distance, I'm not sure which is more accurate.
post #6 of 8 (permalink) Old 07-24-2013, 10:59 PM
With stock gearing, yours is closer to accurate.
post #7 of 8 (permalink) Old 07-25-2013, 08:32 AM
MotoCyclist's Avatar
I didn't check the accuracy when I bought my '09, but I added one tooth to the c/s sprocket and compared it to my Garmin etrex and the speedo was right on the money. I didn't compare it to the odometer. If you went 2 down on your rear sprocket that would be close to the final gearing I have with the larger front.
MotoCyclist is offline
post #8 of 8 (permalink) Old 07-25-2013, 05:25 PM
With 16/46 sprockets, you're geared 6.67% taller than stock, compared to 4.54% with 15/44 sprockets.
