Sidestand/kickstand issue.......help! - Kawasaki Versys Forum
post #1 of 34 (permalink) Old 07-15-2013, 01:01 PM Thread Starter
Banned
Question Sidestand/kickstand issue.......help!
I bought my Versys last Thursday, & already it's toppled off it's sidestand!!!
(luckily minimal damage as those Givi/Kawasaki panniers are pretty tough)
History; it's a 2012 model with 9k mls on the clock & was owned by a 300lb
6ft 2' guy!
I don't know if he stood on the pegs to mount it or not, but the sidestand
movement seems excessive to me, even after I tightened the nuts as far
as possible.
As well as the actual lever movement, the spring doesn't seem to "flick" it forward when I'm putting it down as positively as on other 'bikes I've owned.
Hopefully I'm allowed to put this link to my Youtube download to show you
guys the movement in the stand, & hopefully someone has had a similar
problem & found a solution.
http://www.youtube.com/watch?v=gyiaL...ature=youtu.be
Britmick is offline
post #2 of 34 (permalink) Old 07-15-2013, 01:14 PM
WallCrawl's Avatar
Mine has about the same if not more movement then the one in the video.
Thought it was normal
Dave
1983 Honda XL600R / M-6
2015 Ducati Scrambler Urban Enduro / M-10
2017 Versys X300 / M-12
1966 Honda CT90
WallCrawl is offline
post #3 of 34 (permalink) Old 07-15-2013, 01:16 PM
Ill have to check mine out tonight to see how different it is.. I thought all of them had some sort of flex, but maybe not.
In terms of the "springyness" that happens to me after enough gunk gets in the pivot points, I just spray some wd40 to loosen it up.
Can you give more information of how it "fell"?
Farkles:
Givi Tall Windscreen, Givi Top Rack and Case, Givi V35 Bags and Mounts, Givi QuickLock Tank Connector+Bag, Oxford Heated Grips, Nuvi 550 w/ Ram Mount, Barkbusters Full Wrap + Storm, Motowerks Flatfoot, Spools and Tank Protector, Bobbed Fender, Grip Puppies, 12v SAE Socket, Packjack, Airhawk 1 (med), Scala Rider G4, Contour Roam2
Next Stop: 44Tooth Sprocket (To be installed)
naudan is offline
post #4 of 34 (permalink) Old 07-15-2013, 01:18 PM
2009 V and my kickstand always shifts about 3/8 to 1/2 inch when I remove myself from the bike. I expect it now, so no problem. And, this morning I kicked it up, but it only went up part way and then down again - net result bike would not start in 1st gear.
Most of the time I will bring it down all the way with my boot, and double check to ensure it is all the way down. And it bike will always make the stand shift when I rest it on the stand. I think they all do this.
To be safe, always double check it is UP, and always double check it is down and all the way towards the front of the bike. This avoids any ill gotten drops.
Enjoy your V, they are a fun bike.
toofer is offline
post #5 of 34 (permalink) Old 07-15-2013, 01:31 PM
Did you park it in neutral?? My bike used to lean way over.When i first got the bike i had a messed up hip and had to stand on the peg to get on the bike. It had bent where the stand connects bent it back but over time it was leaning over again. later i installed Speedy Lowering Kit even though i'm 6'2" it made it easier to get my leg over. I didn't have to cut the stand once lowered the lean was gone.
post #6 of 34 (permalink) Old 07-15-2013, 02:36 PM
BLACK DOG's Avatar
I believe this is some engineer's idea of a joke to make sure my heart gets an occasional jump start
BLACK DOG is online now
post #7 of 34 (permalink) Old 07-15-2013, 03:04 PM Thread Starter
Banned
Question
Great replies guys & thank-you all!!!
I suppose no one knows of a better kick stand on the market or they'd've
mentioned it.
Britmick is offline
post #8 of 34 (permalink) Old 07-15-2013, 04:24 PM
Some people have used the klr stand. It's slightly longer, the bike leans less.
Mt. Versuvius is offline
post #9 of 34 (permalink) Old 07-15-2013, 04:40 PM Thread Starter
Banned
Thumbs up
That's funny because my last bike was a KLR & I actually fixed a block to the bottom of the stand so that it wouldn't lean over so much!!!
I know what you're saying though & it's a great idea because the KLR sits much taller than the Versys....
Britmick is offline
post #10 of 34 (permalink) Old 07-15-2013, 05:31 PM
I have a 2013 V and whenever I park the bike, I always kick it down then once off the bike, I pull the kick stand with my toes just to make sure that it is fully engaged. At times, the stand seems to buckle because it is not fully "open". Thankfully and luckily the bike has not fallen because of this, hopefully never will. Now I wonder if this is normal or not!
ESE_VERSYS2013 is offline
post #11 of 34 (permalink) Old 07-15-2013, 07:05 PM
Yup, just like mine, but mine is 2009. Looks as if this is SOP.
Have a great week.
toofer is offline
post #12 of 34 (permalink) Old 07-15-2013, 07:53 PM Thread Starter
Banned
Exclamation
Whenever I park the bike, I always kick it down then once off the bike, I pull the kick stand with my toes just to make sure that it is fully engaged.
Mine fell over as I was dismounting using the "stand on the peg" method!!
Britmick is offline
post #13 of 34 (permalink) Old 07-15-2013, 10:02 PM
andrewhtf's Avatar
Mine wobbles as much too, but so far it hasn't dropped off on its own.
Occasionally i had thoughts of slipping in some 1mm washers in between, or even swapping to a klr side stand but as it is not in dire urgency, i will live with it. For now.
Current : Maroon 2011.
Up next :
andrewhtf is offline
post #14 of 34 (permalink) Old 07-16-2013, 02:31 AM
anders55's Avatar
A cure is as follows:
Put a 1 mm (approximately) washer directly under the head of the kickstand bolt. This shortens the bolt and makes it possible to lessen the gap a little bit in order to get a more snug fit around the stand.
Be careful here and use a washer of the right thickness. Too thick => stand will be stuck, too narrow => stand will still have too much play.
anders55 is offline
post #15 of 34 (permalink) Old 07-16-2013, 04:36 AM
Not exactly to the point of this thread, but thought I'd share this cautionary tale nonetheless. My brother's weestrom blew over one night in Newfoundland because he left it in neutral when he parked it. Exceptionally heavy winds, but my bike was fine next to his because I had left it in gear.
post #16 of 34 (permalink) Old 07-16-2013, 04:49 AM
Good point though, Mt. I always park it in gear and lock the handlebars, but mainly due to my fear that someone will just roll it and take the bike.
post #17 of 34 (permalink) Old 07-16-2013, 08:49 AM Thread Starter
Banned
Thumbs up
Not exactly to the point of this thread, but thought I'd share this cautionary tale nonetheless. My brother's weestrom blew over one night in Newfoundland.
So are you telling us all to steer clear of Newfoundland?...........
Sorry............I couldn't resist that one!!!
I will start to leave mine in gear which I NEVER have done because "back in the day" a bike would start even of it was still in gear, so I guess it's inbred in me.............Memo; rearrange "Old dog...New tricks....CAN teach!!!"
Britmick is offline
post #18 of 34 (permalink) Old 07-16-2013, 10:47 AM
Your sidestand movement is the same as on my '08 and '09 Vs. Two days ago I had the '09 on the rear stand and went under to check the nut on the inside of the 'stand. I was able to tighten it, even tho' it's a lock-nut, so I removed the nut, cleaned it, then put RED Loctite on it, and re-tightened it.
On my KLR (which seemed the same system as on the V) I removed the bolt, drilled the head for a LOCK wire, then put it back in, threaded LOCK (NOT safety) wire thru the hole, and anchored it nearby.
Yesterday I bought a new lock-nut, which, IF I find the nut loose again, I will use to replace the one I Loctited, as well as drilling and lock-wiring the bolt head.
I ALWAYS park the bike IN GEAR, and if it's not in a garage on the rear stand, w/ the steering locked full left (I read that by locking the steering, IF it falls over for whatever reason, the damage will be much less!)
post #19 of 34 (permalink) Old 07-16-2013, 01:07 PM
Evil Dave's Avatar
I have a 2011 V. I thought I had the kickstand down all the way but when getting off the bike, the bike and I went over. My stupidity of course. The GIVI V45 and my leg took the brunt of the force but I still broke the end of the shift lever. I am more cautious getting off the bike and will look at the play on the kickstand.
Evil Dave is offline
post #20 of 34 (permalink) Old 07-16-2013, 04:27 PM
Too bad the stand didn't lock in place.
speedy08 is offline
