Who knew that oil could do so much - Kawasaki Versys Forum
post #1 of 19 (permalink) Old 06-19-2013, 01:28 PM Thread Starter
I did my first oil change yesterday. I didn't have to put a screw driver through the filter to get it off like some have but I did use channel locks. It went well after that...mostly. I have to remember to make some sort of diverter to keep the oil off of the exhaust pipe next time.
Anyway the big news was how much smoother the bike it running now. The vibes are down quite a bit. Not enough to make the mirrors totally clear but a lot better. I put in Rotella 15w40 dino juice like I do my other steeds. This makes we wonder what sort of oil Kawasaki is putting in for break in. Has anyone else experianced this?
david3921 is offline
post #2 of 19 (permalink) Old 06-19-2013, 02:06 PM
I use a piece of tinfoil to keep the oil off the pipes..
post #3 of 19 (permalink) Old 06-19-2013, 04:24 PM
Yes, Performed the first oil change at 250 klms (150 miles) ( to get rid of the filings). Could not get the filter off. Bought a proper wrench, still could not get if off. Took it to my dealer. He put an old hand onto it and got it off. I do not know how. I use a good quality auto oil, and change it often. The engine is running smooth.
Will change the oil again tomorrow with 2,000 klms, Hopefully all will go well, then follow a normal oil change schedule.
northsouth is offline
post #4 of 19 (permalink) Old 06-19-2013, 05:12 PM
Auto oils have anti friction stuff in them. These can make your clutch slip. Either use bike oil, or rotella like alot of bikes.
08' Versys
HAWKSHOT99 is offline
post #5 of 19 (permalink) Old 06-19-2013, 05:16 PM Thread Starter
Excellent idea. Thanks.
post #6 of 19 (permalink) Old 06-19-2013, 05:26 PM
Look at post #125 ..http://www.kawasakiversys.com/forums...p?t=836&page=7
post #7 of 19 (permalink) Old 06-19-2013, 08:25 PM
Avande's Avatar
I changed my oil at 200kms and again at 750kms and then switch to Amsoil synthetic motorcycle oil 10/40 at 2500kms. The bike is running smooth and totally awesome now at 4500kms! I found the bike started running really well after about 2500-3000kms.
Lovin every minute of it!
Avande is offline
post #8 of 19 (permalink) Old 06-19-2013, 10:35 PM
+ Did the same. Shifting becomes smoother also!
post #9 of 19 (permalink) Old 06-20-2013, 07:22 AM
Zatx's Avatar
This has bad news written all over it.
Zatx is offline
post #10 of 19 (permalink) Old 06-20-2013, 12:14 PM
Sorry guys. I made a slip up. Must be getting old.
Currently using Castrol Grand Prix 4 stroke oil motorcycle oil in the new Versys.
But I have used a good quality automotive oil in my bikes for over 100,000 miles and did not have a problem with it.
I guess that I should consider changing to the Amsoil Synthetic motorcycle oil for my new oil change as I have about 2,000 kms on the bike.
Are the synthetic oils really that much better than the normal oils?
post #11 of 19 (permalink) Old 06-20-2013, 02:39 PM
Avande's Avatar
This is my third bike and my first new bike. It's the first bike I'm running synthetic in. I'm trying it because a guy I know who owns a motorcycle school uses it exclusively and swears by it. His bikes get used and abused and run really well, so he must be doing something right. When you factor in the cost it's insignificant in the grand scheme of things.
Avande is offline
post #12 of 19 (permalink) Old 06-20-2013, 05:54 PM
What mileage did you drop the original oil at, and how was it broken it?
Rotella T 15W-40 is thicker at startup... New oil does help though. I run Amsoil AFF 0W-40.
post #13 of 19 (permalink) Old 06-20-2013, 06:20 PM
Using a funnel with a short plastic pipe at the engine.
Breaking in the V1K with dino oil motoman style. Changed oil at 50km, 500km and next 1000km.
There is a lot of metal in the oil for the first oil change.
post #14 of 19 (permalink) Old 06-20-2013, 06:56 PM Thread Starter
Around 450 miles. I got the bike (2012) in April but all the rain stopped me from riding. I broke it in pretty conservitivly. I kept it under 5000 rpm for the first 100 with no long runs at constant speed. I also made sure that I didn't lug it. After the first 100 I started bringing it up to 7000 rpm merging onto the highway. I don't pay attention to the rpms now that I've changed the oil. I just ride but still keep it from lugging.
post #15 of 19 (permalink) Old 06-21-2013, 03:11 AM
I used to think so. But no (or "sort of" or "define that much better"). Read used oil analyses (UOAs) at bobistheoilguy.com and form your own opinion.
They have some properties that are better. But I've seen bad UOAs from what are supposed to be really good oils.
If you're looking for oils that hold viscosity well in shared sump motorcycles, the best value in durable oils seems to be HDEOs. Like what the OP put in his Versys--which is the same one I recently switched to for mine.
davidg is offline
post #16 of 19 (permalink) Old 06-21-2013, 03:24 AM
I'm considering switching to Amsoil motorcycle oil for next Winter. I seem to remember it holding up well on bobistheoilguy (though I suggest checking for yourself). Costs a lot more than 15W40 HDEOs like what I'm using now. But it's gonna flow better on cold starts.
Or maybe I'll just cheap out and go back to Rotella T6 and change it more frequently. I'm sure it won't last as long as Amsoil 10W40 moto oil. But it costs way less.
Or keep using 15W40. IIRC it doesn't really get too cold for that here. Unlike up there.
davidg is offline
post #17 of 19 (permalink) Old 06-21-2013, 04:23 AM
I picked up 4 US gallons of Castrol's excellent Hypuron 15W-40 semi-synthetic diesel oil for $7 a gallon at Canadian Walmart. Also great for 4-wheelers.
http://www.bobistheoilguy.com/forums...Number=1472823
http://speedtalk.com/forum/viewtopic.php?f=1&t=32279
I have enough Amsoil AFF 0W-40 left to use in the Versys till end of 2016... You can get great discounts, especially when ordering in bulk from http://www.woodsbrosracing.com/amsoil-online-store.htm with the Promo Code if you want and get an instant quote.
post #18 of 19 (permalink) Old 06-21-2013, 06:32 AM
I am a giant fan of Mobil 1 full synthetic. You can normally get it for $10 a litre in the U.S. - cheaper than Amsoil and far better quality than Rotella. Mobil 1 is the oil used by Triumph from the factory and the one they recommend for all oil changes. Got hooked on it when I owned a Tiger and haven't looked back.
revrandy is offline
post #19 of 19 (permalink) Old 07-04-2013, 12:23 PM
Nope, Zatx - LOTS of us use car synthetic with NO problems. In fact I ran M1 10w-30 (car oil WITH friction modifiers) in my Bandit 1200S - 104 hp - for MANY miles w/ zero issues.
...Are the synthetic oils really that much better than the normal oils?
I read a study done by Amsoil (probably back in '86) before I tried using it, and IMHO the answer is ABSOLUTELY!!!
