Front turn signal plates - Kawasaki Versys Forum
post #1 of 4 (permalink) Old 05-29-2013, 02:15 PM Thread Starter
Has anyone used these, or something similar?
http://www.dmvmoto.com/servlet/the-6...dapters/Detail
2wheelzen is offline
post #2 of 4 (permalink) Old 05-30-2013, 07:52 AM
andrewhtf's Avatar
Not me, seen another friend using it. It worked as intended, that's all.
Current : Maroon 2011.
Up next :
andrewhtf is offline
post #3 of 4 (permalink) Old 05-30-2013, 08:51 AM
Related observation: many aftermarket LED turn signals are LESS conspicuous than OEM signals with incandescent bulbs. LEDs are bright but also unidirectional so they can be hard to see from angles other than straight on. Incandescent bulbs shine light all around, and through the OEM signal lens the amber light is visible from a wide angle.
If you're upgrading turn signals so others can see them (and, therefore, YOU), make sure the ones you get are actually more visible, not less.
[SIZE="1"]Ride. Good.
2019 F750GS
2014 R1200RT
2008 Versys (SOLD 11/19)
2003 ST1300ABS (SOLD 5/15)
post #4 of 4 (permalink) Old 05-30-2013, 12:35 PM Thread Starter
I agree with Bones...
The triangle shaped Rizoma signals which are visible front, side, and behind are excellent. (Sorry I don't know the specific model)
