Handlebars not even - Kawasaki Versys Forum
post #1 of 6 (permalink) Old 05-29-2013, 01:13 PM Thread Starter
Handlebars not even
Went down in a right turn. Fixed the broken footrest, and brake pedal. Handlebars are no longer parallel. Compare both pictures to see the non horizontal as opposed to the horizontal before the crash.
The bike runs fine and straight. Just that when going straight the handlebars are
at position similar to the left photo.
Is this an adjustment or a replacement?
Any help will be appreciated.
Name:	mcycle bars 007.JPG
ID:	22730   Click image for larger version
Name:	mcycle bars 008.JPG
toofer is offline
post #2 of 6 (permalink) Old 05-29-2013, 02:51 PM
Toddzilla's Avatar
Your fork tubes may have twisted in the triple clamps.
I think this is a pretty straight forward fix, if so.
"Always go forward. Going straight is no fun."
'08 Red
Givi shield
Famsa Tank bag and pannier set
Happy Trails Panniers
Zeta blinker handgaurds
SeatPad Mod w/ Alaska leather cover
Heated grip wraps
Fiammi Hi & low tone horns
2008 V
1985 BMW R80
1989 Honda XR600R (650)
Toddzilla is offline
post #3 of 6 (permalink) Old 05-29-2013, 05:43 PM
Banned
Triple tree needs to be,
loosened
centered
and re-tightened.
Really screws with your head don't it?
Seeya is offline
post #4 of 6 (permalink) Old 05-30-2013, 06:41 AM Thread Starter
thanks guys, I'll search the forum, see what I can locate regarding triple tree/forks.
EDIT
Found some posts and info. Also stuff on youtube. Seems most bikes that have this can
be resolved by loosening the upper triples and holding the wheel steady, move the handlebars back towards center. Should hear a "pop" or so, and then tighten the tree
and should resolve the problem. This should be done after any fall - especially a hard
fall.
toofer is offline
post #5 of 6 (permalink) Old 05-30-2013, 04:12 PM
mxgeezer's Avatar
Sometimes my dirtbikes require new rubber grommets after a hard crash. Not sure if the V has them, though.
"Now if I wasn't Lesley Horwinkle I wouldn't be here, now would I?"
mxgeezer is offline
post #6 of 6 (permalink) Old 05-31-2013, 12:37 PM Thread Starter
I plan to resolve this issue over the coming week-end. Yesterday I noticed that my forks were no longer aligned. By that I mean the right hand fork is 1 1/2 inches higher than the left hand fork and no longer in the smooth area of the tube. Obviously my triple clamps were too loose - don't recall ever using a torque wrench when I tightened them up. I will this time. I have no idea when this happened though I recall that the bike was not quite the same the last time I took it on the road.
Once I get this resolved, I'll take it for a quick spin around the block and check the handlebar positioning. I'm thinking it may correct itself if this is the original cause.
now I think to myself... "did the fork pop up when I was turning and cause me to fall" or did I apply front brake pressure and lock up the wheel, or did I simply go down on account of sand on the pavement?
Too many questions, I'll just fix it and go on.
toofer is offline
