Dang! Oil leak with less than 50 miles. - Kawasaki Versys Forum
post #1 of 12 (permalink) Old 03-18-2009, 03:26 PM Thread Starter
Picked it up last night with 1 mile on it. Thanks to my so-called friends, they notice oil leaking from underneath left side. Seems to be lots of oil on the bottom side of the motor and its about 1/2 quart low. My dealer thinks it's the "shift shaft seal". I do hope it's nothing major.
icversys is offline
post #2 of 12 (permalink) Old 03-18-2009, 03:35 PM
Briar Rabbit's Avatar
Doh!
Briar Rabbit is offline
post #3 of 12 (permalink) Old 03-18-2009, 04:00 PM
Me too!! Good thing you caught it before something bad happened, like running out of oil. Let us know how it turns out...
post #4 of 12 (permalink) Old 03-18-2009, 04:32 PM Thread Starter
Turns out it's an external oil line that runs along the shift shaft. It's leaking around the coupling so a new line needs to be ordered. Dealer said at 4 days to get the part but it's safe to ride. I guess I'll park it and patiently wait for the part to arrive.
icversys is offline
post #5 of 12 (permalink) Old 03-18-2009, 06:21 PM
Oh that really sucks for you.
Are you sure your stealer didn't "forget" to put a crush washer between the oil drain plug and the pan? I've seen the same as you describe in appearance when they do that.
Stealers like to overthink a thing.
Mark Milanowski is offline
post #6 of 12 (permalink) Old 03-18-2009, 09:19 PM Thread Starter
The leak was caused fram a $38 oil pipe. Part number 39193-0046. The end of the oil pipe has a plug in it. The oil is coming from around the plug. Auspicious beginning. BTW, thank you Ronayers.com.
icversys is offline
post #7 of 12 (permalink) Old 03-18-2009, 09:36 PM
Sorry to hear you had such a bad start to a new bike. Never heard of that here so must be an isolated issue. Keep us informed on how it goes from here on. Don't let that leave a bad taste for you. Is a fun bike. Good luck.
Yamaha Secca II
1600 Classic-sold
08 Verseys
1986 Corvette
Life is not a practice run. Enjoy each and every day.
Deano is offline
post #8 of 12 (permalink) Old 03-19-2009, 06:50 PM
amir_zwara's Avatar
Yeah bum deal on that... is the dealer fixing it for free? they really should.
amir_zwara is offline
post #9 of 12 (permalink) Old 03-19-2009, 09:20 PM Thread Starter
Oh yes, it's under warranty. Not even 50 miles on it. I could replace it myself if I had the part. It's just behind the front sprocket cover.
icversys is offline
post #10 of 12 (permalink) Old 03-20-2009, 05:22 AM
Zammy's Avatar
Did you snug it before replacing it ? I'm not being a smart a$$ ,just wondering what part actually failed.
Zammy is offline
post #11 of 12 (permalink) Old 03-20-2009, 08:43 AM
I wouldn't touch it myself. That is a dealer problem and he is obligated to fix it. If something breaks with you touching it then it is your problem. Let him fix it. Don't exactly understand how something could be broke and not just tightened right to beging with but that is up to him to asess under warrenty. You would think they would look at it and see if the plug was tight or maybe sealed before odering another pipe. Maybe he did. Possible i guess it got bumped and broke during shipment but you would think they would run it after they service it in the shop before they even drive it and notice any leaks. Keep us informed. Which Iowa City dealer? I have looked at bikes there at several shops.
Yamaha Secca II
1600 Classic-sold
08 Verseys
1986 Corvette
Deano is offline
post #12 of 12 (permalink) Old 03-20-2009, 09:04 AM Thread Starter
No, I definitely won't repair it myself. The part is on it's way and I'll take it to them (Iowa City Motor sports) when it's in. This external oil pipe has a soldered cap on the end, the oil is leaking from the soldered cap. The oil pipe is a cast aluminum square which is 1/2 x 4 inches in diameter. Oil is transferred from one part of the engine to another from this small square tube. If you want to see what it looks like, just take your front sprocket cover off. One of the bolts that holds your front sprocket cover on is attached directly to this tube. BTW, IC motor sports has a HUGE selection of bikes. The day was in they had just received 47 crates and we're trying to fit them in their warehouse.
icversys is offline
