Fit question for sw-motech alu-rack top rack - Kawasaki Versys Forum
post #1 of 25 (permalink) Old 03-16-2009, 08:04 PM Thread Starter
Question Fit question for sw-motech alu-rack top rack
Hi everybody!
I think I mentioned this in another thread somewhere, but the sw-motech alu-rack top rack I ordered for my Versys doesn't seem to fit. The problem is that the holes in the rack rails don't fit around the mount posts the way that the grab bars do, and this means that my trim pieces won't fit back on.
The part number on my packaging matches the part number on Twisted Throttle's website, but this just can't be right. I'm hoping that they just got the rack packed with the wrong part number.
I know other people have this rack; when you installed it, did the holes fit around the posts like I think they're supposed to?
Vitesse is offline
post #2 of 25 (permalink) Old 03-17-2009, 01:44 AM
I purchased one about two months ago and it fit perfectly. Once I removed the seat and grab bars I installed the new grab bars and plate. All fit the same as I removed and the plastic pieces fit the same. Hope that you can get this straightened out because it truly is a great rack
AlbertaJeff is offline
post #3 of 25 (permalink) Old 03-17-2009, 07:11 AM
MN_Smurf's Avatar
My motech top rack should be here tomorrow, so I'll be able to get you a second opinion...
MN_Smurf is offline
post #4 of 25 (permalink) Old 03-17-2009, 07:16 AM Thread Starter
So, AlbertaJeff, the rack holes do fit around the posts like it seems that they should? That's good to know. MN Smurf, I'd appreciate your feedback too. Thanks!!
Vitesse is offline
post #5 of 25 (permalink) Old 03-17-2009, 08:13 AM
Isn't the Alu rack kind of a universal fit, but Motech also makes a different rack specific to the Versys?
charly is offline
post #6 of 25 (permalink) Old 03-17-2009, 08:34 AM
Wordguy's Avatar
Originally Posted by Vitesse View Post
...The problem is that the holes in the rack rails don't fit around the mount posts the way that the grab bars do, and this means that my trim pieces won't fit back on.
My experience was the same as Alberta Jeff's; everythng went together with no issues. I can't remember if the SW rails went around the posts or on top of the posts. I can check tonight when I get home. I think those "posts" are actually spacers that can come out (not sure).
Here's a picture I happen to have online. Does this look like your setup?
I think only the bolt goes through the rail, not the spacer/post. I remember that I had to fiddle a bit to get the right combination of bolts and washers, etc. But I was also installing the side case brackets at the same time.
-Alan
Wordguy is offline
post #7 of 25 (permalink) Old 03-17-2009, 09:48 AM Thread Starter
Hmm. If there's a spacer around the post, then my problems are probably solved, and I'll have 3 out of 4 farkles installed! I'll have to check when I get home but it's nice to have hope!
Vitesse is offline
post #8 of 25 (permalink) Old 03-17-2009, 10:31 AM
Yes, I can remember removing spacers. I haven't looked but I believe they are rubber mounted.
post #9 of 25 (permalink) Old 03-17-2009, 03:18 PM
It looks exactly the same part as the one Kawasaki sells (not surprising, it's the same supplier). If you got the one for the Ninja, it wont fit. If you got the one for the Versys (GPT.08.391.100/B_TWT rev01) it will fit. They look similar, but are not the same.
I'd leave the spacers in place, that's what's giving some rigidity top ten installation. Without them, you are compressing the rubber grommets completely to get a solid mount.
Gustavo
Gustavo is offline
post #10 of 25 (permalink) Old 03-17-2009, 07:13 PM Thread Starter
I took a second look at my tail, and I don't have spacers there anywhere. I don't have rubber grommets either. Twisted Throttle is sending me a new setup in case there was a labeling problem from the supplier. Yay for TT!
Vitesse is offline
post #11 of 25 (permalink) Old 03-17-2009, 08:22 PM
Wordguy's Avatar
The hardware I used is a combo of the original handgrip pieces, the alu rack, and the tab for the side cases. sorry, but I can't remember which came from where. Hopefully the new kit from TT will solve your issues.
Wordguy is offline
post #12 of 25 (permalink) Old 03-17-2009, 08:43 PM
MN_Smurf's Avatar
I'm glad TT is taking care of you, but I don't want to hear about any "supplier problems" considering that my rack is supposed to be here from them tomorrow.
MN_Smurf is offline
post #13 of 25 (permalink) Old 03-17-2009, 09:26 PM
gti20vturbo's Avatar
Mine bolted right up like the instructions indicated. I have never had a problem with any SWM product and their fit and finish can NOT be beat. I dont know what you mean though when you say "did the holes fit around the posts like I think they're supposed to?". Around what post? I removed the one body colored panel and bolted everthing up then put the panel back on. Here are some pics of mine with the seat off.
ST1300, Versys, SV650S
gti20vturbo is offline
post #14 of 25 (permalink) Old 03-18-2009, 09:15 AM Thread Starter
Here's what mine looks like. The hole in the rack is definitely smaller than the hole for the grab bar (also shown). The silver post is immovable. The rack holes need to fit around the silver posts if I'm going to get my green trim piece to re-attach.
Vitesse is offline
post #15 of 25 (permalink) Old 03-18-2009, 10:36 AM
Thatís what mine looks like. I tried (but not too hard) to pull the spacers out but mine would not budge. I took mine into work and drilled out a 9/16Ē hole. There is still enough material on the edges for strength. I will take some pictures this weekend when I mount my Shad46 case.
oscar.45 is offline
post #16 of 25 (permalink) Old 03-18-2009, 12:00 PM Thread Starter
See, I'm not gonna drill the holes to be bigger. That shouldn't be at all necessary, y'know? My replacement rack is coming tomorrow. I'll let you know how it goes.
Vitesse is offline
post #17 of 25 (permalink) Old 03-18-2009, 12:12 PM
Take the spacers out. Im pretty sure the OEM spacers come out and the SWM spacers (which are shorter) replace them and the rack sits on top of them. Its been a while but isnt that the way it shows on the instruction sheet? All the parts have little numbers next to them and you have to cross refrence the numbes to the parts list to find out where they go.
post #18 of 25 (permalink) Old 03-18-2009, 02:08 PM Thread Starter
What spacers? The bright metal posts don't move. There's no way I can see to MAKE them move, either, at least no tool I can think of that would be able to get a good grip on them. When I look down the center of them, it looks like one solid piece down to the threaded area, as if there'd be nothing to bolt onto without them. It's kinda hard to explain.
I hope I don't sound too testy here. I'm running on massive sleep deprivation.
Vitesse is offline
post #19 of 25 (permalink) Old 03-18-2009, 02:11 PM Thread Starter
Oh and my instructions only show me how to bolt the thing together after all the other stuff is removed. It's one big picture, no words at all.
Vitesse is offline
post #20 of 25 (permalink) Old 03-18-2009, 02:28 PM
They are spacers, they pull out trust me.
