How to remove fuel from tank - Kawasaki Versys Forum
post #1 of 17 (permalink) Old 04-27-2013, 06:59 PM Thread Starter
What's the best way to remove fuel from the tank apart from riding the bike? I am having the tank painted soon and need to empty the tank.
post #2 of 17 (permalink) Old 04-27-2013, 07:23 PM
King.Versys's Avatar
http://www.amazon.com/Hand-Pump-Siphon-Gas-Liquid/dp/B004107292/?tag=533633825-20
King.Versys is offline
post #3 of 17 (permalink) Old 04-27-2013, 07:39 PM
BLACK DOG's Avatar
I don't believe there is a better way than riding it.
If nothing else it's a couple hours of therapy and jelousy inducement.
BLACK DOG is offline
post #4 of 17 (permalink) Old 04-27-2013, 07:43 PM
Siphon it or take off the tank and dump it.
post #5 of 17 (permalink) Old 04-27-2013, 07:52 PM
aka Yamadog's Avatar
I have a fuel removal service...just pay my airfare and I'll empty your tank for "free"
This
I'm no diplomat
aka Yamadog is offline
post #6 of 17 (permalink) Old 04-27-2013, 08:17 PM
http://www.aerostich.com/e-fill-siphon.html
http://www.amazon.com/gp/product/B000BG1X54/ref=pd_lpo_k2_dp_sr_1?pf_rd_p=1535523722&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B000ZOT39A&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=0B7ZKA87E87611WCB4AH
http://www.amazon.com/ABC-Products-Generates-Transfers-Flammable/dp/B008RRW71I/ref=pd_sbs_auto_12
post #7 of 17 (permalink) Old 04-28-2013, 12:49 AM
Considering that THERE ISN'T better way than riding, if you have to dismount the tank, after to do it, I think you can easily empty it from the tap.
duffyduck1 is offline
post #8 of 17 (permalink) Old 04-28-2013, 12:53 AM
There is no tap... You could operate the fuel pump to empty the tank, but you should never let the fuel pump run dry. The easiest way would be to run it low, then turn tank upside down to dump out the rest, as noted by weljo2001 (no, don't set it on fire!).
post #9 of 17 (permalink) Old 04-28-2013, 03:25 AM Thread Starter
Thank for the reply's I'd forgotten about those cheap siphon pumps, that should do nicely.
post #10 of 17 (permalink) Old 04-28-2013, 05:56 AM
Some neat items I had never thought of! Thanks!
I empty my snow blower by letting it run till its dry every year. I may invest in one of these. I don't like the mouth full of gas trick.
post #11 of 17 (permalink) Old 04-28-2013, 06:40 AM
I've used those cheap siphons with the plastic bulb. They all end up leaking. Has anyone tried anything that is better, holds up, doesn't leak? The ones in the Amazon links look good, but has anyone actually used those? I'm always on the lookout for a decent siphon! In the meantime, I don nitrile gloves and spread newspaper all over.
HondaGalToo is offline
post #12 of 17 (permalink) Old 04-28-2013, 06:55 AM
DO NOT USE LIGHTER TO CHECK FUEL LEVEL!
Sorry my bad! LOL
post #13 of 17 (permalink) Old 04-28-2013, 09:35 AM
cheap transfer pump
I used this to drain my tank, and it worked like gangbustahs. Drained the tank in about 30 seconds, no leaks, flexy hose reaches recesses in the tank.
Too big to live on the bike, but fine for the garage.
http://www.harborfreight.com/multi-u...ump-66418.html
old man red is offline
post #14 of 17 (permalink) Old 04-28-2013, 09:30 PM
A piece of plastic hose. One end in the tank, suck on the other. Siphon the fuel. This is age old technology.
kiwitourer is offline
post #15 of 17 (permalink) Old 04-28-2013, 09:47 PM
post #16 of 17 (permalink) Old 04-29-2013, 07:00 PM
Here's the Harbor Freight version
http://www.harborfreight.com/fluid-s...ump-93290.html
George
bicyclist is offline
post #17 of 17 (permalink) Old 04-29-2013, 08:51 PM Thread Starter
My days of getting a mouth full of fuel are long gone
