Dual-Star Heated Grips - Kawasaki Versys Forum
post #1 of 16 (permalink) Old 02-22-2009, 06:56 AM Thread Starter
redline's Avatar
A question for you guys.....
Even though the instructions tell you to wire it in to a voltage controlled circuit, do you see any problems with hard-wiring it to the battery...other than the obvious of accidentally leaving it on and the subsequent battery drain. I put an in-line 5 amp fuse in....
redline is offline
post #2 of 16 (permalink) Old 02-22-2009, 07:19 AM
Up early, Mr. B. I think your "obvious" potential issue would be your primary concern. Leaving them on would not drain your battery as fast having a set of headlamps burning, but consider that you use heated grips when it's cold, when your battery is challenged. Being able to start your bike becomes a bigger deal. Turn the grips (and your driving lights) off every time and no problem. Leave them on and...maybe no problem, but maybe.
Would now be a good time to install a relay controlled fuse panel? You could wire your heated grips and driving lights through it. Turn the bike on, those devices are available. Turn the bike off, those devices shut down. Next time you have an electrical farkle to installb (GPS, power port, etc.), you've already got the fuse panel there.
Today's forecast is for 3 to 5 inches of snow, so you're not riding. Time's on your side. Food for thought, redline.
[SIZE="1"]Ride. Good.
2003 ST1300ABS
2008 Versys
post #3 of 16 (permalink) Old 02-22-2009, 07:42 AM Thread Starter
redline's Avatar
I know, I know....you're right, time is on my side and you're correct about the relay / fuse panel. But I can always add it later...... BTW.....did I tell you I'm SICK OF THE SNOW?!?!?!?!?
redline is offline
post #4 of 16 (permalink) Old 02-22-2009, 08:16 AM
Briar Rabbit's Avatar
Your friendly neighbors from Connecticut say " Word! "
Briar Rabbit is offline
post #5 of 16 (permalink) Old 02-22-2009, 08:54 AM
Chicken Little's Avatar
You are going to eat your words if you wire it direct to the battery. Yup, it works, and there will come that dark day when you walk out in the rain and from across the grocery store parking lot, you will see you heated grips steaming in the rain, and realized you left them on for 45 minutes while you stood in line at the deli trying to get them to slice your turkey thin enough.
I stuck dual-stars on all my bikes, and the Versys is the easiest. That switched red tail light tap is just waving at you back there!
I did, for the first time, use the Eastern Beaver switched harness on the Versys. That was worth every penny. Either way, spend just a little more time and wire it switched!
Chicken Little is offline
post #6 of 16 (permalink) Old 02-23-2009, 06:34 PM Thread Starter
redline's Avatar
Boy, do I feel like a fool. You were soooooo right. Problem is, is that I didn't even make it out of the garage. I was "testing" the grips, when the wifey called me in for dinner, and proceeded to forget {me...no way...} to turn the d**n things off!!!! Looks I'll be re-wiring it this wekend......shoulda, coulda, woulda but didn't.........................on a side note, it seems as though they take a long time to warm up, and when they did {engine running at about 2K}, it didn't feel as though they got all that warm........????? I'm going to put my digital therm on the grips this weekend to see just how "hot" they get.
redline is offline
post #7 of 16 (permalink) Old 02-23-2009, 06:40 PM
Geez, dude, ya didn't have to confess it here in front of 600 Versys riders! It's ok, you will fix it. Now, they won't seem really hot until you get the rpm's up. I know your weather is bad, but if you could sneak around the block at higher rpms, I am sure you will be pleased. Also, your throttle side will heat up quicker than the clutch side. Throttle tube doesn't suck the heat like the solid metal clutch side. It will even out. FYI, I rarely have mine on high. They really cook on low at interstate speed.
post #8 of 16 (permalink) Old 02-23-2009, 08:44 PM
They do take a while to warm up since the cold bar sucks up most of the heat at the start, especially in New England in February, but once they get going they get plenty warm. I've had three sets of heated grips on three different bikes and they've all cranked out some BTUs to my otherwise frozen digits.
2003 ST1300ABS
2008 Versys
post #9 of 16 (permalink) Old 02-23-2009, 09:22 PM
carter's Avatar
do these things just mount under the grips and then theres a toggle switch to turn it on and off? I guess I'm ignorant, I've never seen these before. It looks like a cheap alternative to the other ones I've seen.
carter is offline
post #10 of 16 (permalink) Old 02-23-2009, 09:40 PM
Cheap, maybe. Work, for sure. Under the grip, dual filament control.
post #11 of 16 (permalink) Old 02-24-2009, 07:09 AM
I'm thinking of getting a set of these. They come with a hi/lo/off switch that would look pretty integrated if I can find the right spot to put it.
Vitesse is offline
post #12 of 16 (permalink) Old 02-24-2009, 08:05 AM
Vitesse- those are the dual-star grips. I think Symtec is making them all. Dual star offers a toggle switch standard, with a rubber cover to waterproof it. I have had both the rocker and the toggle switch control. I think the toggle is easier to use with gloved hands. I am frequently switching the rocker switch to high, instead of off.
post #13 of 16 (permalink) Old 02-24-2009, 03:18 PM
That's good to know. Thanks!
My only complaint about the toggle is that it's just such an eyesore, but that's a good point about ease of use with gloved fingers. What to do, what to do.
Vitesse is offline
post #14 of 16 (permalink) Old 02-24-2009, 07:23 PM
There's a black rubber boot available that screws over the toggle switch. Looks better, improves the feel with gloved hands, and I think it cost an extra $4 when I ordered the heated grip kit.
http://www.dual-star.com/index2/Ride...d_grip_kit.htm
2003 ST1300ABS
2008 Versys
post #15 of 16 (permalink) Old 02-24-2009, 07:58 PM
Yup, the toggle helps in the looks department. I will go back to it on the next bike. I really want a lighted switch, but I couldn't find a two way one at Radio Shack. I end up kinda feeling up the dash in the dark, looking for the switch.
post #16 of 16 (permalink) Old 02-24-2009, 09:18 PM
Yippee! Problem solved--I'm sold! Thanks everybody!
Vitesse is offline
