Rear spring adjustment..at wit's end. - Kawasaki Versys Forum
post #1 of 29 (permalink) Old 04-21-2013, 08:17 PM Thread Starter
Zatx's Avatar
Okay guys. I'm extremely ticked off, frustrated, and in an all around poor mood, over trying to adjust the spring on my rear shock. This little piece of crap, pot metal, spawn of satan, spanner wrench that came with the bike has busted my stinking knuckles too many times.
Why in the heck is this adjustment nut/collar thing so hard to turn??
Is there a simple way to do it that I'm missing? I spent two hours tonight attempting to not cuss up a storm. Was so worked up I had to come in and read my bible.
Can you guys give some advice please?
Thank you.
Zatx is offline
post #2 of 29 (permalink) Old 04-21-2013, 08:27 PM
Mine wasn't as hard as yours, but wasn't always easy. Maybe a little lube around the collar and the pawls? It might help if you don't get lube where the wrench fits.
If you really want to make it easy, lift the back of the bike via the subframe with ratcheting straps--the way you might to remove the shock.
davidg is offline
post #3 of 29 (permalink) Old 04-21-2013, 08:28 PM
cuff's Avatar
I put a little moly grease on the ridges to make it slide easier. I also bought an adjustable shock wrench. If you're using the tool kit wrench put about a foot of pipe on the end of it.
IBA# 38547
cuff is offline
post #4 of 29 (permalink) Old 04-21-2013, 11:52 PM
King.Versys's Avatar
WD40 and she will slip and slide for you.
King.Versys is offline
post #5 of 29 (permalink) Old 04-21-2013, 11:56 PM
When adjusting the rear shock with the stock tool I use a small pipe over the handle to make it easier.
post #6 of 29 (permalink) Old 04-22-2013, 04:05 AM
Channel locks.
Mt. Versuvius is offline
post #7 of 29 (permalink) Old 04-22-2013, 04:31 AM
andrewhtf's Avatar
1. Squirt some wd40
2. Add a pipe to the handle as the stock one is to short for strenght leverage
3. Get another spanner/wrench.
Current : Maroon 2011.
Up next :
andrewhtf is offline
post #8 of 29 (permalink) Old 04-22-2013, 04:46 AM
You are using the supplied extension on the spring preload adjustment tool? I secure tool on adjuster ring with left hand, while rotating it with right hand. Works fine.
post #9 of 29 (permalink) Old 04-22-2013, 04:49 AM
Some made a notch on the tool to make it more secure... View post to see photo:
Originally Posted by faller View Post
I had the same issue. Just cut a notch in the outer end as I did in photo, works flawlessly.
Wayne
Other options: http://www.kawasakiversys.com/forums...ad.php?t=14141
post #10 of 29 (permalink) Old 04-22-2013, 04:53 AM
This tool does the rear shock easily.
post #11 of 29 (permalink) Old 04-22-2013, 05:55 AM
genehil's Avatar
I must have missed the part about motorcycle maintenance...
GeneHil - Mount Dora, FL
2011 Kawasaki Versys
genehil is offline
post #12 of 29 (permalink) Old 04-22-2013, 06:07 AM
There is the bit about Triumph in the Lord but not sure if Kawasaki is mentioned
post #13 of 29 (permalink) Old 04-22-2013, 06:41 AM Thread Starter
Zatx's Avatar
It wasn't the motorcycle maintenance it was the soul maintenance. I shouldn't have been getting so ticked off.
Zatx is offline
post #14 of 29 (permalink) Old 04-22-2013, 06:48 AM Thread Starter
Zatx's Avatar
I've tried everything mentioned in this thread with no luck. Thanks for giving me that link invader. I bought the tool mentioned in that thread for $14. I'll pay $14 to put this problem to bed.
Zatx is offline
post #15 of 29 (permalink) Old 04-22-2013, 07:46 AM
The adjustment wrench in the tool kit also has a handle extender that slips over it to provide more leverage. Are you using the extender?
post #16 of 29 (permalink) Old 04-22-2013, 09:37 AM
Banned
http://www.amazon.com/Drag-Specialties-Spanner-Wrench-77-2003-BC3/dp/B000WNK8OS/ref=sr_1_5?ie=UTF8&qid=1366641510&sr=8-5&keywords=shock+spanner.
or
Ebay
Don't like the one that came with the bike.
bought this one for the garage.
__________________
Seeya is offline
post #17 of 29 (permalink) Old 04-22-2013, 09:39 AM
My stock tool had a high spot in the center that rides on the adjustment nut, and allows the end to slide out of the hole. If you grind down the high spot, the wrench works fine. More leverage with the provided pipe, or something similar. Several solutions, as noted here. Good Luck!
ScottyNeal is offline
post #18 of 29 (permalink) Old 04-22-2013, 11:44 AM
cuff's Avatar
I'm going to ask a silly question, so please don't get offended. Are you trying to 'push' or 'pull' the shock wrench to get the adjuster to move?
IBA# 38547
cuff is offline
post #19 of 29 (permalink) Old 04-22-2013, 03:10 PM
I laughed out loud, right here in the the office, when I read this!
trialsguy is offline
post #20 of 29 (permalink) Old 04-22-2013, 03:13 PM
WWJD - What Would Jesus Drive? Answer: A Honda.
To quote scripture, John 17:13 "...and Jesus and all his disciples shall be in one Accord..."
