Anyone cut in a gel pad on their seat? - Kawasaki Versys Forum
post #1 of 11 (permalink) Old 04-09-2013, 06:58 AM Thread Starter
rlj
rlj's Avatar
I have an extra stock seat foam and seat pan, thinking about getting a gel pad and cutting it into the seat as well as shaving the seat a bit to make it flatter. Has anyone done this? I've watched a few videos and looks fairly straight forward, if I screw it up it's no big deal as I have some Sargent foam I can always replace it with if I ever decide to switch from the Seat Concepts seat.
Would there be better foam like some sort of memory foam instead of gel?
13 Yamaha FJR 1300
09 Kawasaki KLX 250S
05 HD Sportster Roadster 1200
02 Malaguti F12 Phantom 49cc Italian Scooter
rlj is offline
post #2 of 11 (permalink) Old 04-09-2013, 07:10 AM
I've tried many different combinations of memory foam and gel trying to get a lower - and more comfortable - seat. The most comfortable combinations for me came from proper positioning of the material under my butt. Just leave the cover loose and move the padding around until it "feels" good; then staple the cover back in place.
Having said all that, I got the overall best result by removing all the stock foam from the seat, added some foam/gell to the front four inches to raise it, staple the cover back in place, then place an AirHawk R inflatable pad on top of all that. Use very little air. It's a very comfortable - and low - combination.
ScottyNeal is offline
post #3 of 11 (permalink) Old 04-09-2013, 08:16 AM
I tried. Lost alot of time and some money.
Finaly ended in small company which makes seats for living
Good luck
viral is offline
post #4 of 11 (permalink) Old 04-09-2013, 09:06 AM
Know a guy who put memory foam into the seat of his Z750 then brought a gel pad and now hes had the gel pad inserted into the seat and uses a airhawk and he also tried a few other home made mods on the way and the seat has cost him a small fortune especially with freight costs to NZ. I can ride 600km on my stock versys seat and he cannot before all the mods go 100 km with out feeling like hes been locked up in the wrong prison
post #5 of 11 (permalink) Old 04-09-2013, 11:12 AM Thread Starter
rlj
rlj's Avatar
Good luck
I mainly want to do it just for kicks. I have the seat pan and foam laying around and thought it would be an interesting project as I'm drinking a few cold beers over the weekend. Sounds like it may not be an effective mod but it will be fun playing around with it.........
13 Yamaha FJR 1300
rlj is offline
post #6 of 11 (permalink) Old 04-09-2013, 07:45 PM
Zrex1 is offline
post #7 of 11 (permalink) Old 04-09-2013, 07:58 PM Thread Starter
rlj
rlj's Avatar
Originally Posted by Zrex1 View Post
and how did it work out for you?
13 Yamaha FJR 1300
rlj is offline
post #8 of 11 (permalink) Old 04-09-2013, 08:54 PM
Pad it up so you sit back in the saddle with no forward slope and get an air hawk. Wonderful comfort!
Good luck with gel seat. I hope you can correct forward slope and it should work great!
post #9 of 11 (permalink) Old 04-09-2013, 11:16 PM
Adding a soft gel this week and will see how it goes.
Thanks for all the info.
post #10 of 11 (permalink) Old 04-10-2013, 10:30 AM
After doing a FEW jobs with beers on hand, I would suggest you save the beers for AFTER...!
post #11 of 11 (permalink) Old 04-11-2013, 08:53 PM
Works great, it is a fix..I also shaved the rear of the seat abunch before I insterted the Saddleman gel pad for 50$..Made the seat flat.
Zrex1 is offline
