Front tire vibration - Kawasaki Versys Forum
post #1 of 11 (permalink) Old 04-09-2013, 05:40 AM Thread Starter
So recently I had the local shop mount up another Bridgestone BX023 front tire. They have done this for me before with no problems. With the gravel and cinders being off the roads finally and the warmer temps I'm getting back into my normal riding style. (I ride more conservatively all winter).
Yesterday I noticed a bad vibration coming from the front wheel starting at about 85mph and gets noticeably worse as my speed increases. By 100mph it's pretty bad.
So I took the wheel back to the shop to have them re-balance, he said it wasn't bad but made it perfect. He said the wheel had a bit of a hop and first thought was the rim. I said it was fine with the old BX023 tire. He then said maybe it's a bad tire? I remounted the wheel and no change.
So do I try some beads, or liquid? Is it possible the tire is bad from new? Has about 200 miles on it.
I'm thinking I'll have to get another tire and try that, if the problem goes away then I will know if it was a bad tire. If not then I will have to look at other possibilities.
The front bearings seem tight and there was no problems with the previous tire.
So try the beads or liquid not?
Thanks, Mike
WindWalker is offline
post #2 of 11 (permalink) Old 04-09-2013, 05:49 AM
Purificator's Avatar
I would rather change that tire or get it properly inspected. beads and liquids normally should provide the same balance you would have with a manual balance...
Purificator is offline
post #3 of 11 (permalink) Old 04-09-2013, 07:01 AM
Seems to me that if all was ok before the tire change, and now there's a problem after the change, the problem is with the change. Bad tire is the most obvious culprit. I would not try to overcome it with beads, etc. You could switch back to the old tire for a test, to confirm that it's a tire issue, without the expense of a new tire. If confirmed, perhaps the tire vendor will do a replacement. Maybe a local tire dealer would help you out - to try to gain your business.
ScottyNeal is offline
post #4 of 11 (permalink) Old 04-09-2013, 05:39 PM
It may not be absolutely round. Happens rarely, but it would cause your problem.
Have a look on both sides where the tire meets the rim. Make sure the beads are evenly seated all of the way around. There's usually a line on the tire to help see this.
09 Versys
00 KLR
USN 1959-65
ttpete is offline
post #5 of 11 (permalink) Old 04-09-2013, 06:04 PM
Yes, it's probably not properly seated out in the rim.
post #6 of 11 (permalink) Old 04-10-2013, 10:44 AM
After I 'seat' the beads I run my finger around the whole tire at the rim, feeling for any differences.... Maybe?
post #7 of 11 (permalink) Old 04-12-2013, 12:47 PM
Go out on the highway and stand up on the pegs, look over the windscreen and down on the front tire. You'll probably see it bouncing up and down a little, needs balancing. You may see it wobble side-to-side, then you have a bent wheel.
Good luck
Streeter is offline
post #8 of 11 (permalink) Old 04-12-2013, 12:52 PM
goat12's Avatar
I had a bad wobble in the front of my 2011 too. Didn't matter what speed I was going- the wobble was there. Rebalanced the front, made sure the back was aligned etc. Ultimately it turned out to be a bad bearing up front. Once replaced I've been wobble free, for what it's worth.
goat12 is offline
post #9 of 11 (permalink) Old 04-12-2013, 06:33 PM
aka Yamadog's Avatar
By "local shop" do you mean the dealer? Did you buy the tire from same?
I'm no diplomat
aka Yamadog is offline
post #10 of 11 (permalink) Old 04-15-2013, 11:47 AM Thread Starter
Tire came from Bike Bandit.
Local shop is a Yamaha dealer. I used to race mx and harescrambles for them.
Tire is properly seated and rebalanced.
I can look down the fork while riding, no need to stand. You can see the wheel start to bounce up and down when you get over 90mph.
I'm going to get another tire and replace it and see if that corrects the problem.
post #11 of 11 (permalink) Old 04-15-2013, 06:57 PM
Jack up the front and spin the tyre by hand. You may have to push the pads into the caliper a bit to get rid of any brake pad drag. Spin the tyre by hand and check for out of round, sideways run out out etc. Probably not beaded correctly.
kiwitourer is offline
