Cleaning the bike - Kawasaki Versys Forum
Like Tree1Likes
post #1 of 29 (permalink) Old 04-04-2013, 07:23 PM Thread Starter
Avande's Avatar
Cleaning the bike
So I'm trying to get the break in out of the way and I'm riding the bike any chance i get. Started today with no rain and then it started raining halfway through the ride. I live in the country and all the mud an crap from the tractor tires is on the road and as soon as the rain hit it all turned into a total mess. So now my 3 day old bike looks like ****...literally! It's everywhere.
Just curious how others wash and detail their bikes? Soap and water...I know...just looking for any useful tips or products that might help.
On my old bike I usually just mix up a little dish soap with warm water, lightly mist the bike down and the get in the there and wash, then mist rinse. I know some guys never like to use water and I've seen other guys at the auto wash pressure washing their bikes.
Avande is offline
post #2 of 29 (permalink) Old 04-04-2013, 08:50 PM
King.Versys's Avatar
King.Versys is offline
post #3 of 29 (permalink) Old 04-04-2013, 09:01 PM
I normally just wash the bike with a good car wash with a wax added to it. Wet the bike wash down using a soft cloth or wash mit. Rinse and towel dry. I will got to a car wash with the bike. Most car wash places have the psi set around 900. If your still not sure about the car wash then don't get the tip of the wand real close to the bike. I use to work for a company that sell commercial pressure washers. You can take a 3500psi machine down to 90psi just by putting in the correct tip.
post #4 of 29 (permalink) Old 04-04-2013, 09:10 PM
Rinse it off first with the water hose.
post #5 of 29 (permalink) Old 04-04-2013, 09:39 PM
motociclista's Avatar
You can always try the Lonerockz method: ride at least 100 miles in the rain without stopping. He swears that's the closest his Versys has ever come to getting a bath.
motociclista is offline
post #6 of 29 (permalink) Old 04-05-2013, 12:05 AM
washing is normal like any car wash, but you will need to get it dried out after wash with a blower or a hot day to keep the rust away. There are points in the Versys that are prone to rust.
I always use a blower to get it dry after wash.
post #7 of 29 (permalink) Old 04-05-2013, 08:17 AM
If my bike is real bad I use a hose and car wash soap. You never want to use dish soap. It is designed to clean the grease off dishes, and will remove any wax you have on the bike.
Usually I wash my bike with a airisol can. Spray it on then wipe off with a clean towel. I also wax the bike quite often.
08' Versys
HAWKSHOT99 is offline
post #8 of 29 (permalink) Old 04-05-2013, 08:57 AM
Zatx's Avatar
Never ever use dish soap on any vehicle.
Use a concentrated car wash with a wax in it like weljo mentioned and follow Invader's advice of rinsing it off first.
Here is what I do:
1.) Rinse
2.) Wash
3.) Rinse every few minutes, never allowing the soap to dry on the bike (this is done about 3 times per wash)
4.) Dry off with a clean towel
5.) 5 minute ride around my neighborhood to blow out the water that is in all the crannies I can't reach with a towel.
6.) Dry it off again after the short ride
7.) Wipe down with "detailer spray".. it's like a spray on wax that you don't let dry, you just wipe off.
My 2011 still looks brand spanking new (except where I've let her touch the ground.. sniff).
Zatx is offline
post #9 of 29 (permalink) Old 04-05-2013, 12:29 PM
I use a pressure washer, and a bucket of soapy (car wash soap!) water with a wash-mitt. I spray the chain with WD40 BEFORE and AFTER, and am very careful to NOT spray around the bearing-surfaces at each axle or steering-head, swing-arm pivot, the sides of the chain, or directly at the radiator.
After wetting the bike and spraying any mud off, I wash it down with the soapy mitt, rinse with the pressure washer, then dry with a chamois.
(BTW - ORIGINAL chains on BOTH Vs... 42,800 miles on the AZ one, 21,870 kms on the BC one.)
post #10 of 29 (permalink) Old 04-05-2013, 01:15 PM
genehil's Avatar
I take mine to the quarter car wash once or twice a year and that does it for me... I don't detail mine.
GeneHil - Mount Dora, FL
2011 Kawasaki Versys
genehil is offline
post #11 of 29 (permalink) Old 04-05-2013, 09:23 PM
andrewhtf's Avatar
Wash using car wash liquid.
Hose rinse - car wash mixture with car wash sponge - hose rinse. Let it sit a while and then go off for a ride for a minute or two. That's all. No waxing, no detailing.
Current : Maroon 2011.
Up next :
andrewhtf is offline
post #12 of 29 (permalink) Old 04-06-2013, 12:52 AM Thread Starter
Avande's Avatar
Went and bought some Turtle Wax car wash concentrate and hosed her down and then got in there and washed her up real good.... man that **** got everywhere. Stay off country roads when the farmers are spreading manure...especially if it's raining!
Avande is offline
post #13 of 29 (permalink) Old 04-06-2013, 10:33 PM
...Stay off country roads when the farmers are spreading manure...especially if it's raining!
AND - watch for cattle carriers while riding.... You can get TWO sorts of sprays - WET - and WET with lumps...!
post #14 of 29 (permalink) Old 04-06-2013, 11:26 PM
1. Rinse and spray off the grit with water garden hose
2. Car wash detail (neutral PH)
3. Use different wash pad for different bike parts. Top to the bottom, front to back
4.Wash off before soap gets dry
5. Wipe off dry with microfiber cloth
6. Leave till finish any dripping done.
7. Warm up till fast idle comes to about 1250-1300 rpm.
8. Done and await the next ride.
Waxing does make the muck don't stick easy and easier to clean off.
jefapotomus likes this.
post #15 of 29 (permalink) Old 04-07-2013, 07:27 AM
Ride in the rain, park in sun to dry.
revrandy is offline
post #16 of 29 (permalink) Old 04-08-2013, 12:10 AM
post #17 of 29 (permalink) Old 04-08-2013, 04:09 AM
Motul bike wash. Spray on, leave 3-4 minutes then hose of. No scrubbing at all. Works well on paint, alloy, screen etc. I just use a chamois to dry the paintwork. Brilliant wash the bike in 10 minutes.
kiwitourer is offline
post #18 of 29 (permalink) Old 10-10-2013, 05:48 AM
gyzmo's Avatar
Great tips. Thanks for the posts!
gyzmo is offline
post #19 of 29 (permalink) Old 10-10-2013, 06:40 AM
S100 Total Cycle Cleaner.
http://www.s100.com/s100_tcc.htm
Spray on, hose off. Gets in all the little spots you can't reach by hand and it really works.
post #20 of 29 (permalink) Old 10-10-2013, 08:05 AM
I use motomuck, no rinse just spray on wait and hose off. http://www.motomuck.co.nz/
