10 Bucks and 10 minutes - Kawasaki Versys Forum
post #1 of 23 (permalink) Old 03-31-2013, 11:27 AM Thread Starter
BB's at Walmart 10 bucks. Turn bars to left lock on side stand. Pour BB's with
funnel from what ever you have lyin' around. Tap on bar occasionally to settle BB's to the left end. My hands are never numb now. Bike is electric smooth. You can thank me later
ID:	18514   Click image for larger version
Fullcircle is offline
post #2 of 23 (permalink) Old 03-31-2013, 12:20 PM
andrewhtf's Avatar
Doesnt that adds unnecessary weight?
Current : Maroon 2011.
Up next :
andrewhtf is offline
post #3 of 23 (permalink) Old 03-31-2013, 03:52 PM Thread Starter
About 30 ounces I would guess. About 1/5 of that jar of BB's. 2 lbs at the most.
post #4 of 23 (permalink) Old 03-31-2013, 04:28 PM
Question:
Does this fill up the whole handle bar? It's hollow from end to end, or is there something containing/blocking the BBs so that you are just adding them to each end? Thanks.
post #5 of 23 (permalink) Old 03-31-2013, 05:07 PM Thread Starter
Hollow end to end. I can't believe I waited a year to do this.
post #6 of 23 (permalink) Old 03-31-2013, 05:37 PM
dxhFZ's Avatar
Neat idea!
Bikes:
65cc Benelli Dynamo
Yamaha ttr-125
Kawasaki KX-125
Yamaha Yz426-f (current)
dxhFZ is offline
post #7 of 23 (permalink) Old 03-31-2013, 05:57 PM
chid's Avatar
you have to fill in everything?
Versys 2015 Green
chid is online now
post #8 of 23 (permalink) Old 03-31-2013, 08:14 PM Thread Starter
i guess you can experiment a little at a time. All you're tryin' to do is change the vibration frequency. You can't eliminate it just change it. My bike will still wheelie
post #9 of 23 (permalink) Old 03-31-2013, 08:23 PM
BLACK DOG's Avatar
I filled the ends of my bars with lead shot after filling the center with sealing foam (Great Stuff) so only abt 6 inches at the ends
BLACK DOG is offline
post #10 of 23 (permalink) Old 03-31-2013, 08:29 PM Thread Starter
If I had easy access to lead shot, I woulda done the whole thing with that. I'm assuming everyone that's concerned with the added weight has a 30" waist?
post #11 of 23 (permalink) Old 03-31-2013, 08:46 PM
BLACK DOG's Avatar
Originally Posted by fullcircle View Post
if i had easy access to lead shot, i woulda done the whole thing with that. I'm assuming everyone that's concerned with the added weight has a 30" waist?
32" 190 pounds 6'-1" 56 years
post #12 of 23 (permalink) Old 03-31-2013, 08:53 PM Thread Starter
Touche.. quess I'm just speakin' for myself
post #13 of 23 (permalink) Old 03-31-2013, 09:34 PM
goat12's Avatar
Great idea! I was wondering if bbs would fit into the ends on the stock bars. Definitely going to do this soon.
goat12 is offline
post #14 of 23 (permalink) Old 03-31-2013, 09:55 PM
Did you use the whole jar?
Are your mirrors clearer now?
2011 Kawasaki Versys
cbolling is offline
post #15 of 23 (permalink) Old 03-31-2013, 11:43 PM
If your bike was vibrating enough to make your hands numb suggest doing a vacuum synch. If it is not in balance it will cause a lot of extra vibration. Normally this should be done annually. With the cylinders power stroke balanced there is not that much vibration from the engine. You can buy a synch tool for $100 or build your own for less than $20. See threads on this site.
post #16 of 23 (permalink) Old 03-31-2013, 11:59 PM
G19Tony's Avatar
I gave it a try. Used about 1/5th of the jar, as the OP said. We'll see how it does Tuesday. I'll be going for a day trip.
I guess I need a BB gun to use up the rest. I may fill up the bars on the TU250.
G19Tony is offline
post #17 of 23 (permalink) Old 04-01-2013, 11:22 AM
Let us know what you think after the trip.
I am really interested in calming down the mirror vibration so I can see behind me better.
cbolling is offline
post #18 of 23 (permalink) Old 04-08-2013, 11:11 AM
Any updates?
cbolling is offline
post #19 of 23 (permalink) Old 04-10-2013, 12:27 PM
I did this last year. I could tell as soon as I drove out of the driveway. makes a BIG difference.
Lead Shot was what I had.
David
David RSparky3 is offline
post #20 of 23 (permalink) Old 04-10-2013, 03:32 PM
What year is your V? I don't feel any handbar vibes in my '08 V. It could be a sync issue, like someone said earlier.
trialsguy is offline
