Speedometer accuracy.... - Kawasaki Versys Forum
post #1 of 5 (permalink) Old 01-22-2009, 02:50 PM Thread Starter
Went for a long ride yesterday , so for those who want to know the 'error' in the Versys' speedo (and don't have a GPS), here it is (my "V" has stock gearing and tires):
- the speedo reads 7% HIGH ( ie - at 60 mph your actual is 55.8 mph).
In 6th gear the INDICATED speed per 1,000 RPM is 14 MPH, while the ACTUAL speed per 1,000 RPM is 13 MPH. So, a little math -
- 5,000 RPM INDICATES 70 MPH, but is ACTUALLY 65;
- 6,000 RPM INDICATES 84 MPH, but is ACTUALLY 78; or conversely
- 65 MPH INDICATED is ACTUALLY 60.35;
- 75 MPH INDICATED is ACTUALLY 69.64; and
- 80 MPH INDICATED is ACTUALLY 74.28.
Hope this helps those who hunger to know what their REAL speed is . For the rest of us - you're SAFE riding at the INDICATED speed limit .
Cheers,
post #2 of 5 (permalink) Old 01-22-2009, 03:38 PM
dallasdon's Avatar
If you put a 16 tooth front sprocket on, the speedometer is just about dead on.
'09 Versys -Green
TET'68 Survivor
dallasdon is offline
post #3 of 5 (permalink) Old 01-22-2009, 03:44 PM Thread Starter
But (without getting into my service manual to check), I BELIEVE your odometer will go from spot on to being OUT by 6%. "Ya pays yer money and ya takes yer chances!"
Depends which is more important to you.
post #4 of 5 (permalink) Old 01-22-2009, 04:16 PM
Satex's Avatar
Even the odo is not "spot on" with the stock setup, although it's close enough to not quibble. I rode about 500 miles over the past weekend, and found that the odo was almost 1 mile optimistic every 100 miles. I've checked it before using a different gps and found the same error. This is pretty meaningless to me, but some folks may be dismayed in a year or two to find their 100,000 mile bikes actually have 101,000 miles.
BTW, my gps speed readings vs speedo readings are the same as yours. The speedo reads about 7-8% lower than actual at all speeds.
2008 Versys...still bonding to the bike.
2005 Husaberg FE450E. I LOVE this one.
... dirt bike built for my wife.
Satex is offline
post #5 of 5 (permalink) Old 01-22-2009, 04:32 PM
You mean higher. The speedo reads higher than you're actually going...
