break in period question.. - Kawasaki Versys Forum
post #1 of 18 (permalink) Old 01-21-2009, 05:44 PM Thread Starter
during the first 500 miles what does 4,000 r/min rpm translate 2 in mph
thanks
fortbethel is offline
post #2 of 18 (permalink) Old 01-21-2009, 05:48 PM
Satex's Avatar
It depends on which gear you're in, of course. Also, gear for gear, the RPM will result in the same speeds after the first 500 miles as during those first 500.
2008 Versys...still bonding to the bike.
2005 Husaberg FE450E. I LOVE this one.
... dirt bike built for my wife.
Satex is offline
post #3 of 18 (permalink) Old 01-21-2009, 06:04 PM
Good answer!
post #4 of 18 (permalink) Old 01-21-2009, 06:13 PM
Better question
Okay so, what aprox speed would the Versys do at 4K RPMs on 6th gear, on a normal sunny day, flat road and a rider of about 160lbs.
The other day someone posted a picture of the tach while they were riding, not much details were given, but the versys speedo read 49mph at 3K RPM.
I would at assume that at under normal conditions, nothing extreme, the Versys would do 60mph at 4K RPM on 6th gear.
Hope that helps...
SVNET is offline
post #5 of 18 (permalink) Old 01-21-2009, 07:03 PM
Red Herring's Avatar
More like 50.
Red Herring is offline
post #6 of 18 (permalink) Old 01-21-2009, 08:27 PM
carabnsol's Avatar
for me 4000 rpm = 55mph on flat level ground in 6th gear.
carabnsol is offline
post #7 of 18 (permalink) Old 01-21-2009, 09:35 PM
Take this for what it's worth. I work at a dealership that has been in business for 35 years selling the same lines. We have never seen an engine/tranny failure due to improper break-in. Neither have we had oil leaks, vacuum leaks, caliper failure, or fuel system problems due to improper break-in. Now that being said, I have seen 2 recent ID-10-T situations where sport bikes were bought & raced the same day. Needless to say, that didn't workout well. The last 2 bikes I had I ran them like I drove them on a daily basis from the start. I have had no problems.
I knew it was going to be a great day when I woke up, because I woke up!!!
The Cajun is offline
post #8 of 18 (permalink) Old 01-22-2009, 07:47 AM
I can concour with that....
I can concour with that 100%....
I once heard, technology is so high and engines are so well cut these days that the engine comes already broken in from factory, that used to be more of a factor on Henry Fords days no now.
As long as you don't abuse your engine doing 80 miles on 1st gear right as you roll out the dealer, if you don't do that, you should be fine.
My last two new bikes I rode them normally from day one, exactly as I would ride it everyday after and so far those have been the most two realiable bikes I have had.
I would not be too much concern about keeping a new engine under 50 all the time. As long as you don't push it too much on the lower gears, you can pretty much go as fast as you want on 6th gear.
Good Luck.
SVNET is offline
post #9 of 18 (permalink) Old 01-22-2009, 08:20 AM
hacktracker's Avatar
I agree with these ideas.
I don't break anything in anymore. I wait until the engine is warm then I enjoy myself. I won't throttle a cold engine.
Don
"ride more, worry less"
2000 Honda VFR800 - Street
hacktracker is offline
post #10 of 18 (permalink) Old 01-22-2009, 08:56 AM
redline's Avatar
Agreed.
redline is offline
post #11 of 18 (permalink) Old 01-22-2009, 03:38 PM
Post
Hope that helps...
4,000 RPM in 6th is 56 MPH INDICATED, but only 52 MPH ACTUAL.
For "break-in" - RIDE IT LIKE YOU STOLE IT - then change the oil and filter at 600 miles and again at 1200. That's how I broke mine in, and it works GREAT, burns NO oil, and gets 55 MPG.
post #12 of 18 (permalink) Old 01-22-2009, 04:03 PM
Satex's Avatar
Hey, I got the same indicated speed even when I'm going down a steep hill. So I tried it while going up a steep hill...still the same.... what gives??
Satex is offline
post #13 of 18 (permalink) Old 01-22-2009, 08:10 PM
Your bike is defective. You need to contact the NHTSA immediately and complain.
Gustavo
Gustavo is offline
post #14 of 18 (permalink) Old 01-22-2009, 08:28 PM
You must not have the optional CVT.
Don
post #15 of 18 (permalink) Old 01-23-2009, 09:25 AM
sharrison56's Avatar
The thing I have read to watch out for during the breakin period, more than the RPM limit, is running at the same RPM for long periods. Most everyone seems to agrees that you need to exceed the 4,000 RPM for short periods during the breakin period.
Steve
Now I have four!
sharrison56 is offline
post #16 of 18 (permalink) Old 01-23-2009, 11:33 AM
redline's Avatar
Talking
[QUOTE=hacktracker;23344]You must not have the optional CVT.
QUOTE]
OH NO! Not the dreaded CVT?!?!?!!?!?
redline is offline
post #17 of 18 (permalink) Old 01-23-2009, 04:20 PM
[QUOTE=redline;23396]
QUOTE]
i got my v with cvt......they are hard to find....if u locate one go for it !!!......just twist & go !!!!
KUDZOO is offline
post #18 of 18 (permalink) Old 02-12-2009, 10:13 PM
put it through its paces
Ride the bike as you plan to ride it after break in, just try to avoid staying at the same RPM for an extended period of time.
flanagan2 is offline
