I have done this couple of time before but now not sure as to how to set the clock on 650 Kawasaki 2009.
I know it has something to do with Mode button. It cycles thru odometer, trip meter & clock etc but when I get to clock I am not how to change the clock time
I know it has something to do with Mode button. It cycles thru odometer, trip meter & clock etc but when I get to clock I am not how to change the clock time....
Ignition ON then:
Push MODE button to display the clock;
Push the RESET button for MORE than 2 seconds till both hour and minute displays start FLASHING;
Push the RESET button - only the hour display will flash, then use MODE button to advance the HOURS; and
Push the RESET button - then the minute display will flash, then use MODE button to advance the minutes;
Push the RESET button - both hour and minute displays start FLASHING again; then
Push MODE button - displays STOP flashing, and the clock NOW works.
But . . . . this procedure only works if you use your left hand while standing on your right leg . . . facing west!
Related Threads
Kawasaki Versys Forum
507.6K posts
81.9K members
Since 2008
