Yes with tax about $10 a liter as opposed to $16.32 per liter , normally I find it takes more than 2 liters as I change the filter every oil change. Got a phone call it was ready for pickup, less than 6 blocks from my house, had to run out to my barbecue supplier and get a new igniter, finally found out way it fails after a good rain, just gave him the old one , warranty :thumb::thumb::thumb:. Found the "
rubber" button has a groove in it, I highlighted this because I use the term
Rubber , loosely, more plastic than rubber. The new one has a much tighter fitting groove, however I put some silicone into the groove after taking it apart ( Yes :grin2: all things come apart, the trick is to understand and not damage it in the process) .Last time I waited a day and when I walked in, it had dried out sufficiently to work again. Today I tried my hot air solder station, no luck so now it is replaced :clap:
