Front wheel chock adjustment - Kawasaki Versys Forum
post #1 of 10 (permalink) Old 06-06-2019, 02:12 PM Thread Starter
Smiley's Avatar
I bought this wheel chock today, a good deal for $60 ($45 USD)- on sale until June 9. It appears to be very robust and I plan to mount it on my lift.
Question: to any riders here who have the same chock: which hole did you to mount the front pivot assembly for our 17" rims? I am alone here and don't want to risk hitting the brake discs on the pivot assembly when it drops the wheel into place.
My instinct says the 2nd hole as pictured on the link, but uncertain. Thanks for any advice you can offer.
Edit: the brand is Power Fist. "Adjustable for wheels from 14" to 21" If the first hole, closest to the hoop is for a 14" wheel, then it follows that the next is 16", then 18" and the last is for 21"
So would I use the second or third hole for a 17"? Maybe I should just try the two options. I drilled the four holes and mounted the chock to the ramp. I'm impressed, it's very solid, with good nuts, bolts and washers provided for assembly. Need your own bolts for mounting to a floor, platform lift or pickup truck bed.
https://www.princessauto.com/en/deta...ck/A-p8240145e
Smiley is offline
post #2 of 10 (permalink) Old 06-07-2019, 04:18 PM
I had an earlier version of that chock on my tow from AZ to AB back in '11, and here's a pic.
It appears that the holes were situated vertically and I was in the TOP one. HOPE this helps you.
post #3 of 10 (permalink) Old 06-07-2019, 04:22 PM
Also - looking at the distance between the part of the chock going up to the back of the tire, that there's LOTS of room between it and the brake-discs. I can also add that I wasn't at all concerned about them contacting, and that was the SECOND time I did that particular set-up.
post #4 of 10 (permalink) Old 06-08-2019, 06:53 AM Thread Starter
Smiley's Avatar
Thanks, Ed, but I am returning the chock. I installed it and tried both of the positions, the third from front fit the diameter of the wheel best but the chock is too wide to hold the bike upright.
Despite the robust build, I do not recommend the Power Fist wheel chock for the Versys.
Smiley is offline
post #5 of 10 (permalink) Old 06-08-2019, 06:48 PM
Randyjaco's Avatar
I have the same chock from Harbor freight. I just added some wood spacers to the chock, just thick enough for a snug fit for my tires. It perfectly grips my tires but won't mar my wheels. Couldn't ask for a better chock.
Randy
Do yourself a favor, find America One News Network (OANN) on your cable carrier. 208 on Uverse. News without the Network BS or bias
Randyjaco is offline
post #6 of 10 (permalink) Old 06-08-2019, 07:26 PM Thread Starter
Smiley's Avatar
Randy do you have any photos of the spacers? Thanks. I haven't returned it yet and am open to suggestions.
Smiley is offline
post #7 of 10 (permalink) Old 06-08-2019, 09:16 PM
Randyjaco's Avatar
Here you go. I trimmed them so they wouldn't hit the disks and planed them down for best fit. I hope they work for you,
https://www.kawasakiversys.com/forum...ictureid=28987
https://www.kawasakiversys.com/forum...ictureid=28989
post #8 of 10 (permalink) Old 06-09-2019, 05:16 AM Thread Starter
Smiley's Avatar
Thanks for the photos.
Smiley is offline
post #9 of 10 (permalink) Old 06-09-2019, 02:57 PM
I always ran my V INTO the chock till my tire was in FULL CONTACT w/ the front of the chock.
That's w/ an OEM 120/70 Dunlop.
post #10 of 10 (permalink) Old 06-09-2019, 05:44 PM Thread Starter
Smiley's Avatar
Even with the tire jammed tight, there is too much lateral movement. The design of the Power Fist is not the same as the chock that both Ed and Randy have. It appears to be made for fat-tired front or rear wheels.
I have a few friends who service their bikes here sharing my lift. I cannot see the chock working with three different bikes of various wheel and tire dimensions without a lot of adaptation.
I don't need a chock for my V anyway, it was more to suit my friend's bikes that don't have swingarm bobbins to stabilize their bikes vertically on the lift. They'll have to continue using ratchet straps to stabilize the bike vertically.
Thanks for your suggestions and tips.
Smiley is offline
