Coolant Level? - Kawasaki Versys Forum
 3Likes
  • 1 Post By weljo2001
  • 2 Post By cjcintucson
post #1 of 7 (permalink) Old 05-02-2019, 10:07 PM Thread Starter
Randyjaco's Avatar
Coolant Level?
How does everyone keep an eye on coolant level? I have a 2008 and I like to make sure my coolant level is right. I live in Texas and things get hot here. The problem is to check I need to remove the Tupperware. I tried viewing the reservoir from the tank side and even made the appropriate marks on the interior side of the reservoir. The problem is the coolant isn't dark enough to show up against the marks. I even tried to use some floats, but they tended to move to the opposite side. Is there a way quick check the coolant level?
Randy
Do yourself a favor, find America One News Network (OANN) on your cable carrier. 208 on Uverse. News without the Network BS or bias
Randyjaco is offline
post #2 of 7 (permalink) Old 05-02-2019, 10:50 PM
Alpha One Nine's Avatar
What coolant are you using?
I used some of that yellow coolant in my Connie and could never tell where I was at.
Was planning to change it out with the red Toyota stuff but ended up selling it.
The OEM Kawasaki stuff seems pretty dark to me.
Rick
Alpha One Nine is offline
post #3 of 7 (permalink) Old 05-02-2019, 11:59 PM
I use Motul ....easy to see...
P1020299 by weljo2001, on Flickr
Versys 1000 Radiator Flush & Fill by weljo2001, on Flickr
Fastoman likes this.
post #4 of 7 (permalink) Old 05-03-2019, 02:43 AM
I use some Green stuff and it easy to see the level and also use black tape for low level indicator.. no problem here
Fastoman is online now
post #5 of 7 (permalink) Old 05-03-2019, 07:36 AM
Just a wild thought here, but I can't see where dumping a bunch of green food coloring in there would hurt anything. Just trying to think outside the box. Hope those that know the dynamics of coolant/antifreeze will comment if there is any harm in it???
quexpress and brwster like this.
cjcintucson is offline
post #6 of 7 (permalink) Old 05-03-2019, 11:58 AM
Coolant Freeze level
Somewhat related, for those that live in a area where it never freezes, reducing the glycol mixture increases the heat transfer. I had a post earlier about this.
https://www.kawasakiversys.com/forum...669-post4.html
post #7 of 7 (permalink) Old 05-03-2019, 06:36 PM Thread Starter
Randyjaco's Avatar
I use Prestone pre-mixed. It is green but not dark enough for where I want to view it.
https://www.kawasakiversys.com/forum...ictureid=28855
With the Tupperware off I can see the level fine. The idea is to be able to check my coolant level without removing the Tupperware. I find that I lose a couple of ounces of coolant a month, so it's worth checking.
Randy
Similar Threads
Versys-X 300 coolant level Olcec Versys-X 300 General Discussion 8 11-09-2017 10:36 PM
How to check the coolant level? SteveMartinUSA General Discussions - V-650 18 07-31-2017 01:16 AM
Add coolant to existing coolant? AdventureSeeker Technical Discussion - V-650 11 09-26-2015 04:49 PM
Versys takes fun to another level chazzman General Discussions - V-650 3 04-27-2008 09:01 AM
Oil level in site glass brian_nbmc Technical Discussion - V-650 4 04-24-2008 12:29 PM
