Tubeless tires? - Kawasaki Versys Forum
 1Likes
  • 1 Post By onewizard
post #1 of 7 (permalink) Old 04-03-2019, 07:37 PM Thread Starter
Tubeless tires?
This is probably a pretty basic question, but how do I know if my 2015 650 LT has tube or tubeless tires? The tires currently on it are Shinko 705/805.
And is carrying a can of "fix a flat" advisable on a Versys?
-dm
-dm
dbmccrohan is offline
post #2 of 7 (permalink) Old 04-03-2019, 07:50 PM
Devilsfan's Avatar
If the wheels are NOT spoked...and if you're NOT FastEddie, then you're sure to have tubeless tires!
***Let me add, I'd avoid Fix-a-Flat...even on car tires. Once you spray that stuff in the tire is pretty much shot. Get a patch kit, a tiny electric air pump and a cigarette outlet to plug it it and you should be good to go for at least getting you home/to the nearest bike shop.
Devilsfan is offline
post #3 of 7 (permalink) Old 04-03-2019, 08:01 PM
52Degrees's Avatar
Fix-A-Flat used to be the factory spare for Corvettes.
2016 KLZ1000GBFAL
No mods yet
52Degrees is online now
post #4 of 7 (permalink) Old 04-03-2019, 08:43 PM
https://www.msf-usa.org/downloads/mi...ide_2012v1.pdf
Some reading material on tires..Weather tube or tubeless , most tires do carry marking on tire wall.
post #5 of 7 (permalink) Old 04-04-2019, 09:21 AM
Excellent Tire Knowledge / What You Should Know
Everything from tire inflation to tire wear. Copied to How To Forum
Fastoman likes this.
post #6 of 7 (permalink) Old 04-04-2019, 06:10 PM
I would never use Fix-a-Flat on a bike tire. The makers of Slime tout the benefits of their product but I wouldn’t use it either.
Here is a little info on fix-a-flat:
https://www.campanellas.com/car-tips...at-use-caution
I used fix a flat on a bike tire once. The extra cost for cleaning up the rim definitely wasn’t worth it.
Pat Riot is offline
post #7 of 7 (permalink) Old 04-04-2019, 06:18 PM
I tried one of those products for my '08 and ended up w/ a permanently 'marked' rim where the stuff touched the outside. It's not bad, but it DOES pi$$ me off when I see it....
Similar Threads
Tube or Tubeless for off-road riding Johnny Woods General Discussions - V-650 3 06-21-2018 05:15 PM
Will a tube fit inside the tubeless tire (valve fitment?) Fly-Sig Technical Discussion - V-650 8 03-27-2018 03:37 PM
Stop & Go Tubeless Puncture Pilot Lurch71 General Discussions - V1000 18 10-21-2017 08:09 AM
How to mount your tubeless tires jhedges General Discussions - V-650 9 05-21-2009 08:33 PM
Distanzia tubeless? gti20vturbo Technical Discussion - V-650 4 04-30-2009 09:40 AM
