Are all US Gen3's California models? - Kawasaki Versys Forum
 8Likes
  • 1 Post By leftbrain99
  • 2 Post By asphaltaddict33
  • 1 Post By fasteddiecopeman
  • 2 Post By onewizard
  • 1 Post By Duffy
  • 1 Post By Fly-Sig
post #1 of 9 (permalink) Old 03-25-2019, 05:46 PM Thread Starter
Alpha One Nine's Avatar
Greetings all,
I recently had the tank off of my 2015 650 that has about 5k miles to change the air filter and add some wiring.
I was following the service manual and per this page it would appear my bike is a California model?
It has the black box on the side like the lower picture.
I bought it new (leftover) in the spring of 2016 in Washington state which I think has similar emission standards.
Anyway, I figured I'd ask if any of your US models look like the top picture?
One more thing that concerned me a little is when I put the top of the air box back on it didn't seem like it wanted to snug down into the seal all the way around until the tightened the bolts quite a bit. It seemed like it was slightly teetering on a high spot or something. Once all 8 of the bolts were snug it seemed fine. Has anyone noticed anything like that? The replacement air filter element I put in is a HiFlo HFA2610 that also was not a prefect fit. It sat down in it's spot fine but the bolt hole to secure it to the airbox was not aligned perfectly and I had to oval out the whole with a drill.
Rick
Alpha One Nine is offline
post #2 of 9 (permalink) Old 03-25-2019, 10:03 PM
Washington does require that MY 2009 and later vehicles meet CA emissions requirements. I presume that applies to motorcycles. It's also been speculated that dealerships on the west coast all get CA bikes, which is plausible on various counts.
Alpha One Nine likes this.
leftbrain99 is online now
post #3 of 9 (permalink) Old 03-26-2019, 10:15 AM
I was also surprised that my 2016 had the California emissions equipment, I paid for the little white thing and ditched that big black box. Reused hoses from the black box but left any electrical stuff plugged in, no codes afterwards.
I recently put in a Hi-Flo air filter and it snapped into the grooves perfectly. The airbox lid is a bit finnicky, sometimes the surrounding wire harnesses get in the way so make sure nothing is pinched. I would have a slight gap around the lid till all the screws were snugged down, but dont have to use the force of the screws to pull the lid down.
Fly-Sig and Alpha One Nine like this.
asphaltaddict33 is offline
post #4 of 9 (permalink) Old 03-26-2019, 11:46 AM Thread Starter
I should clarify that the bolts for the air box lid have more resistance before they snug down than a bolt going into threaded aluminum.
I could tell when it was snug enough though. I guess that's what 11 inch pounds (torque spec in manual) feels like huh?
I cut the cable tie for that wire harness that covers the front left bolt to get it out of the way. That one was a pain.
Thanks for sharing you experience.
Rick
post #5 of 9 (permalink) Old 03-26-2019, 11:51 AM
Originally Posted by Alpha One Nine View Post
...Anyway, I figured I'd ask if any of your US models look like the top picture?
My '15 V650LT (in BC) is like the first pic (NO 'box'), and I've never had any issues changing air-filters.
post #6 of 9 (permalink) Old 03-26-2019, 11:57 AM
2015 650 ABS Tight AirBox
I did a post on this in my https://www.kawasakiversys.com/forum...onewizard.html post #4 Tank / Air Box Removal , I was doing a valve shim so removed the whole air box, I had to pry it out, after doing the valve shim I used something like 6 of the 100 LB wire ties on the harness , marked with phasing tape in my photo. After it went in easy, while apart I took the screws out checked the filter then put it back together, before reassembly. I also recall the throttle cable was pushing on the air box, after like I said it went easily together ( more detail in my #4 post).
quexpress and Alpha One Nine like this.
post #7 of 9 (permalink) Old 03-26-2019, 02:07 PM
What does that white gizmo thing try to accomplish?
I removed the Evap canister. The control box for the Rostra cruise control fits perfectly where it was, even used the same holes.
I bought my bike used in FLA and it had the canister. It now occupies a spot in the bike section of a storage cabinet, way down low and in the back.
Yeah, if you want true ram air tuning, you better be willing to ram some air! (SiSF)
'15 KLE650LT
'98 KLR650
And most of Canada too, eh?
SteveJ is offline
post #8 of 9 (permalink) Old 03-26-2019, 03:48 PM
My 15' isn't a Cali model (bought in SD)..........no problem changing air filter.
Duffy is offline
post #9 of 9 (permalink) Old 03-27-2019, 09:52 AM
Fly-Sig's Avatar
Mine, bought in Utah, was a California model. I swapped out the charcoal filter for the little white gizmo when I was troubleshooting a problem. It turns out the mounting bracket where the filter box mounted is perfect for attaching a little hidden container. I have a spare key in there just in case I lock my keys in the trunk while away from home. The charcoal filter doesn't affect performance in any way, so there's no reason to pull it off. If I wasn't using that position to mount the hidden storage box I would put mine back the way it was.
The little white plastic thingy is basically just a little purge tank. If fuel overflows out of the fuel tank it runs through the white thingy and out to the ground via a hose. It also vents something but I don't recall what.
I left the electrical connector attached to the purge valve but even that isn't necessary. It doesn't throw fault codes either way.
Fly-Sig is offline
Similar Threads
Valve adjustment interval for California models kawdog Technical Discussion - V-650 6 12-07-2015 03:20 AM
Of all the models, what has been the performance modification for the money? angst General Discussions - V-650 39 07-01-2015 08:58 AM
Hepco Becker Crash Bars fit all year models weljo2001 Modifications - Cosmetic - V-650 12 07-28-2011 05:10 AM
