Change in sound after valve adjust? - Kawasaki Versys Forum
 3Likes
  • 1 Post By hawkerjet
  • 2 Post By invader
post #1 of 5 (permalink) Old 02-18-2019, 03:31 PM Thread Starter
Last year I bought an 09 with about 15,000 miles. Finally got around to adjusting the valve clearances. Now it really seems like the engine sounds different; mainly a throaty rumble from the air box. Is this just my imagination or can getting the valves adjusted change the dynamics of air flow enough to make it sound different?
Dave31410 is offline
post #2 of 5 (permalink) Old 02-18-2019, 07:20 PM
I did valve clearance check and there was no difference in the sound. still the same.
wait till other chime in on your problem.
post #3 of 5 (permalink) Old 02-18-2019, 08:51 PM
I did not notice any change in sound after adjusting clearance.
Jack of Heats JoH is offline
post #4 of 5 (permalink) Old 02-18-2019, 10:41 PM
hawkerjet's Avatar
Did you remember to install an air cleaner?????????? No air cleaner would result in additional intake sound for sure.
Also did you get all the hoses reconnected to the airbox? A hose off might change the sound you hear not to mention allow dust and dirt into the box.
I too did not hear any change when I did my valve adjust.
Good luck.
invader likes this.
Cookin Wid Gas
hawkerjet is offline
post #5 of 5 (permalink) Old 02-19-2019, 01:48 AM
Did it also get new spark plugs? Your throttle bodies now need to be vacuum synchronized at 1,300 rpm idle. You can then make sure airbox, filter, crankcase vent tube are in place.
https://www.rockauto.com/en/parts/ng...park+plug,7212
https://www.rockauto.com/en/parts/de...park+plug,7212
onewizard and Fastoman like this.
invader is online now
Similar Threads
valve adjust intervals kawdog Member Introductions 2 12-12-2014 03:24 AM
Valve Clearance check and adjust service needed... De-Silva Technical Discussion - V-650 1 06-23-2014 06:43 AM
Another valve check/adjust thread kc4sox Technical Discussion - V-650 13 09-15-2012 11:19 PM
Versys valve adjust fasteddiecopeman Technical Discussion - V-650 22 06-09-2011 01:49 PM
