I am thinking of using a radial on the rear and a bias on the front. Good or bad? - Kawasaki Versys Forum
Like Tree1Likes
  • 1 Post By Fastoman
post #1 of 11 (permalink) Old 11-12-2018, 12:19 AM Thread Starter
original thread https://www.kawasakiversys.com/forum...-good-bad.html
I have a Metzler Tourance radial on the rear and thinking of using my spare 130/80/17 Hiedenau K76 on the front.(The tire was a left over when I switched tires on my KLR) The tread pattern is very close and I need a new front tire. Just wondering if I can get away with this set up?
Cheers.
Okotoks Versys is offline
post #2 of 11 (permalink) Old 11-12-2018, 12:37 AM
https://www.rideapart.com/articles/2...-bias-or-both/
Since you have left over, no harm in trying...if the bike handles well than its no big issue, if not stick to OEM spec as its about your safety.
Fastoman is online now
post #3 of 11 (permalink) Old 11-12-2018, 01:25 AM
Beezerboy's Avatar
a rear on the front? usually when people do that they flip direction of rotation. dunno... it will work, I guess. hope they aren't as big a pile o crap as the K60
Beezerboy is offline
post #4 of 11 (permalink) Old 11-12-2018, 12:09 PM
Cheers.
Triumph supplied some of their models w/ a "bias/radial" mix a few years ago, and I've done it on one of my V650s, w/ no NOTICEABLE bad side-effects.
Originally Posted by Beezerboy View Post
a rear on the front? usually when people do that they flip direction of rotation. dunno....
I've run rear 130/80s on fronts on my Vs, turning EACH direction, and never noticed any 'better' or 'best' from EITHER direction. The "DON'T DO IT" restriction comes from cars.
post #5 of 11 (permalink) Old 11-12-2018, 01:20 PM
Beezerboy's Avatar
from discussion on other bike forums, the flipping the direction question has to do with the tread design on the rear tires being designed to drive, and front tires designed to brake.
post #6 of 11 (permalink) Old 11-13-2018, 06:01 AM
I did lots of mixes, never even felt a difference between radial and bias (ther should be one, I just can't feel it).
If you are not a racer (I'm not) and/or are not lowering pressure for offroad (I'm not), then it should feel fine.
dddd is offline
post #7 of 11 (permalink) Old 11-13-2018, 11:13 AM
When I said I had NOT noticed any differences, WHICHEVER way the 'arrow' was pointing, that included 'spirited' cornering and LOTS of brakes when required.
BTW - when I first ran a TOURANCE 130/80 rear on the front, METZLER ONLY showed the 'arrow' for using it as a rear, and like MOST other users - I just "obeyed" the arrow....
post #8 of 11 (permalink) Old 08-07-2019, 12:18 PM
78530i's Avatar
So, my understanding is that bias ply tires start to lose lateral grip sooner than radials; but its gradual; while radials hold great until they don't (more suddenly). Do what you will with that dubious information.
78530i is offline
post #9 of 11 (permalink) Old 08-08-2019, 04:03 PM
I believe that refers to 'cage' tires, as they corner in YAW, while unless you flat-track - motorcycles DON'T.
post #10 of 11 (permalink) Old 08-23-2019, 10:46 PM
mrvwbug's Avatar
A 130/80 is going to be a good bit taller, I think you would have fender clearance issues. Wider front will also slow down the steering on a bike which is already finicky about front tire profile (to me the V650 feels better with a pointier front tire like a Road 5). Even in the stock size the front felt slow with the old rounder profile PR4 on it, the Road 5 made it much more responsive.
mrvwbug is offline
post #11 of 11 (permalink) Old 08-24-2019, 06:43 AM
Some tires have very distinctive tread patterns to efficiently move water out of the way and provide superior traction.
Some are pretty much the same either way.
I would look to see if the tire in question has a very different tread pattern for the front tire on the web and if so have it run backwards if used on the front.
