coolant reservoir is never used by the system - Kawasaki Versys Forum
post #1 of 3 (permalink) Old 06-15-2018, 09:09 PM Thread Starter
I noticed that the coolant reservoir never has any inflow or outflow of coolant. I checked the radiator cap and the spring seems to be working fine meaning that at 1.1 bars or pressure the cap should open and release coolant to the coolant reservoir. I wonder why it never happens (in my case)...? Is it because the coolant temperature never reaches high enough temp to reach 1.1 bars or pressure? When in traffic, I hear my fan spinning, so I know the cooling system works fine.
Do you guys see the coolant reservoir level go up and down?
vaulter is offline
post #2 of 3 (permalink) Old 06-15-2018, 09:19 PM
motorboy's Avatar
Yes should go up and down--change your rad cap-check reservoir tank vent--if your fan comes on it's getting hot enough to move coolant
Deep in Cajun Country
motorboy is offline
post #3 of 3 (permalink) Old 06-15-2018, 09:21 PM
If you top up the reservoir to the cap with coolant you will see the bike pee coolant when the engine gets hot.
