Android GPS app uses GPX file format - Kawasaki Versys Forum
post #1 of 5 (permalink) Old 05-22-2018, 06:47 AM Thread Starter
Does anyone have a good Android GPS app that uses GPX files?
I am a big fan of “inroute” for ios, pretty much everyone that is in the group I ride with also use it, however it is only available for ios. Many in the group have android phones and no-one seems to have found a good Android app that uses GPX files.
Ideally the app would be able to import or export GPX files. I know you can convert from one file format to another but that is a pain. Really looking for a good android app that uses GPX files.
Jack of Heats JoH is offline
post #2 of 5 (permalink) Old 05-22-2018, 07:19 AM
Doug Just Doug's Avatar
I don't know much about such things, but I've been using a 2nd-hand Android phone (Kyocera Duraforce) as a dedicated m/c unit using the OsmAnd app for offline map/nav, and it apparently uses and/or supports importing GPX files. From the FAQ:
I have a GPX file, how do I get it into OsmAnd?
Android
You can download and open it via File Browser or Dropbox and select OsmAnd as a target application
You can put it in OsmAnd home folder: osmand/tracks/(optional_sub-folder)/your_file.gpx
https://osmand.net/help/faq.html
OsmAnd - Offline Mobile Maps and Navigation
2015 Versys 650 ABS
AMA, Retreads Int'l.
Doug Just Doug is offline
post #3 of 5 (permalink) Old 05-22-2018, 02:41 PM
Locus Map Pro
Locus Map - mobile outdoor navigation appLocus
A bit of a learning curve, but I did it...
unstable_rider is offline
post #4 of 5 (permalink) Old 05-23-2018, 12:41 PM
GPX Viewer: https://play.google.com/store/apps/d....app.gpxviewer The pro version will give you turn by turn nav. Haven't paid for it yet but probably will for the weekend.
jrshermz is offline
post #5 of 5 (permalink) Old 05-23-2018, 01:21 PM
Another Locus Pro user here... works good for me.
'08 Versys.. Givi rear rack, JCW trunk and E21's, Givi shield, Madstad bracket, Speedy peg and mirror brackets, lowering kit, SC Seat, R1 Shock.. other stuff. '09 KLX250 setup for singletrack. 2011 Xterra, '80 CJ-7
abramsgunner is offline
