Anyone have any experience with McCruise cruise control - Kawasaki Versys Forum
Like Tree11Likes
post #1 of 26 (permalink) Old 01-30-2018, 07:53 PM Thread Starter
mrvwbug's Avatar
original thread https://www.kawasakiversys.com/forum...e-control.html
So my local Kawi dealer mentioned these guys as they make cruise control for the Versys and Connie.
https://www.mccruise.com/collections/kawasaki
They are not cheap, but looks like they've done their homework.
Anyone actually use one of these on their bike? Not sure I'd spend that much money on my 1st gen 650 ($825USD for the Versys 650 version), but I might be more inclined to look at a V1000 or Connie if these work well (right now im trying to find a used FJR ES, or wait for the Tracer 900GT to come out).
mrvwbug is offline
post #2 of 26 (permalink) Old 01-30-2018, 09:12 PM
16VGTIDave's Avatar
That is a lot of $$$ for an engine vacuum operated cruise control system. I've seen universal fit electronic servo systems selling for 1/4 that on eBay, though you will have to do some fabricating to install them.
I know you didn't ask about them, but throttle locks are well under $100. Some as low as $1 for an o-ring to slip between the bar end weight and the grip. I've been satisfied with a throttle lock after seeing the prices and complexity of aftermarket cruise control. I could handle the complexity, but choose not to.
16VGTIDave is offline
post #3 of 26 (permalink) Old 01-30-2018, 11:08 PM Thread Starter
mrvwbug's Avatar
Seems like the main thing you're getting for that money is bolt on install with bike specific fit. I wouldn't drop that much money on my 09 650 (especially since I'm probably looking to trade it in this year), but might be more inclined if I traded my 650 in for a V1k or Connie. Used Connies are way easier to find than used FJRs. I've also seen some leftover V1ks for reasonable discounts.
I've used throttle locks and currently use a crampbuster, neither works that well. I live in a place where I have 100+mi round trip of 80mph interstate slog to get to any fun roads, and the V650 is probably not the best bike for highway riding between the vibration and lack of power at highway speed (fun bike on twisty roads though).
mrvwbug is offline
post #4 of 26 (permalink) Old 01-31-2018, 07:28 AM
I use the $0.99 cruise control works great but you do need to keep your palm resting on the throttle. https://www.ebay.com/itm/Throttle-As...9Zm96j&vxp=mtr
jaaklucas and SmoothRoad like this.
Jack of Heats JoH is offline
post #5 of 26 (permalink) Old 01-31-2018, 08:08 AM
There are a few over on the COG forum that have used McCruise. Most there use the Rostra or this one from Murphs':
https://www.murphskits.com/product_i...roducts_id=422
There is an excellent write up on Rostra install on this forum by quexpress which I referred to when installing a Rostra on my '15 v650.
If the bike has the LT bags, his location will not work. I installed mine where the evap canister used to be.
Both of these units are about $200 but I think the Murphs unit may be a tough fit as I'm pretty sure it will not fit where the Rostra will go on an LT. Do note the switch gear on the quexpress install. Way cool. I used a handlebar mount waterproof remote ATV winch relay switch. It works well mounted next to the left grip. I wanted to control the cruise without removing my hand from the grip.
I had used the Murphs' one for about 200k miles spanning a decade. Only issue was one broken pull wire which I replaced. It is still working fine for the subsequent owner. I really wanted to use one of these but could not find a place to cleanly mount it.
All told, it took me about 8-10 hours to install the Rostra, including the head scratching and thinking fluid consumption. The bell crank installation really kicked my butt. Everything else was pretty straight forward if you don't mind and are capable of good wire splicing techniques.
I really, really like this farkle. It makes longer (and shorter) trips quite a bit less fatiguing.
HTH.
quexpress likes this.
'15 KLE650LT
'98 KLR650
And most of Canada too, eh?
SteveJ is offline
post #6 of 26 (permalink) Old 01-31-2018, 08:46 AM
You can try this: Zemco AP 500 Pilotomat: Geschwindigkeitsregler AP 300, AP 500, Pilotomat, ZEMCO, Tempomat, Cruise Control,
It has been done, but not be me.
2008 Kawasaki Versys
1994 Honda NTV 650
1999 Suzuki AN125
blahwas is offline
post #7 of 26 (permalink) Old 02-01-2018, 09:05 PM
I bought a Rostra Cruise kit for my Concours from a forum member that never got around to installing it. I also never got around to installing it and sold it to another member. I just never found the time to strip the bike down to install the cruise, but I found the time to strip it down to remove all the farkles before I traded it in.
post #8 of 26 (permalink) Old 02-03-2018, 11:11 PM Thread Starter
mrvwbug's Avatar
HTH.
How different do you think installing this on an 09 V650 would be? I think the 1st gens have more space under the seat or the left upper fairing to mount the module. If this install isn't too sketchy I would probably consider putting that on my 09. 800 bucks is a little steep for a bike that I only paid 2800 for, though I would still probably consider the McCruise system on a newer V1k or C14 (being much more expensive and complex bikes). McCruise is a lot cheaper on bikes with a drive by wire throttle (i.e. Yamahas).
mrvwbug is offline
post #9 of 26 (permalink) Old 02-04-2018, 11:30 AM
Stuck Thread / Future How To Forum Thread
As in the title, thanks for posting
mrvwbug likes this.
post #10 of 26 (permalink) Old 06-13-2018, 10:10 AM
gmctech's Avatar
I damn well coughed my Java out my nose when I saw the damage on those units! There's no way in hell I'd ever pay that just for cruise...... to each their own but seriously that price is down right ludicrous
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves, "You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." George Carlin, US comedian and actor (1937 - 2008)
gmctech is offline
post #11 of 26 (permalink) Old 06-13-2018, 11:03 AM
I poked around with this and that and wound up with a Cramp Buster for $10. Simple, pretty much does what I want. JMO.
otto_versys_blotto likes this.
aboyandhisversys is offline
post #12 of 26 (permalink) Old 06-13-2018, 11:26 AM
gmctech's Avatar
not even a buck for this.....
https://www.ebay.com/itm/Universal-M...wAAOSwMtxXvWOS
gmctech is offline
post #13 of 26 (permalink) Old 06-13-2018, 11:31 AM
otto_versys_blotto's Avatar
Just ordered one of those, looking forward to testing it out this weekend.
otto_versys_blotto is offline
post #14 of 26 (permalink) Old 06-13-2018, 11:45 AM
I think you'll like it, be careful of clearances between the 'buster and your tank. unexpected contact may result. you may have to rotate it up a bit in slow speed situations. YMMV.
learn to balance the 'buster on the heel of your hand (my odd comment will make sense once you get it on the grip) and you'll be a happy rider (or at least I was....)
post #15 of 26 (permalink) Old 06-13-2018, 02:42 PM
Throttle locks only give your right hand a short break. The bike slows down on inclines and speeds up on declines. Not a good scenario. I use my electronic cruise control to maintain my speed so I can pay attention to the road instead of having to divert my attention to the speedo.
post #16 of 26 (permalink) Old 06-13-2018, 03:04 PM
How much does it cost to add cruise to a GMC truck?
Time cost money so low volume productions take a lot more time than high volume. Companies have to balance selling enough to stay in business without being too costly that they don't sell.
I am considering the Yamaha Tracer 900 GT with electronic cruise control and it cost $13k
If I can get a Versys 650 LT for $9k and add cruise control for $1000 I am saving $3k.
If you have ever ridden all day, every day, for days at a time, you will appreciate electronic cruise control. I use it all the time in all of my vehicles that have it.
post #17 of 26 (permalink) Old 06-13-2018, 07:09 PM
gmctech's Avatar
Thumbs down
A GM truck could have aftermarket cruise installed for about $400 and that includes new factory multifunction switch, vacuum servo and wiring into the BCM did it on my dad's 2004 GMC farmers special .... I actually installed a rostra kit in a friends old protege and the kit was $189.00 and it was $100 for my time to install it.... so yeah. I know why that pricing is stupid crazy high.... yes rostra is a big company. But come on if you think $1000 plus incidentals is a deal then you're my kinda customer. Lol... but seriously there's absolutely no reason one could not make the Rostra 250-1223 Universal Electronic Cruise Control Kit work a versys such as my 2009. I am going to order one tomorrow (bet I can get it for about $200) and make it work on my Versys. When I do I'll gladly take your grand and install one for ya.....
gmctech is offline
post #18 of 26 (permalink) Old 06-13-2018, 07:46 PM
gmctech's Avatar
Looks like somebody beat me to it, but I'm so interested in this cheap cruise control hack I cannot wait to do this to the versys! The rostra kit definitely looks like the cheapest option out there
gmctech is offline
post #19 of 26 (permalink) Old 06-13-2018, 08:59 PM
For someone that doesn't have your skills, or the time, or both and doesn't want to spend $13000 on a new bike, $1000 to add electronic cruise control to keep on riding when the arthritis makes it hard to continually hold the throttle, I would say it is priceless.
A grand to me is like $200 to you. To someone else $20 is like your $200 and they feel like you are wasting your money and all that time doing this project. It is all relative.
If my wife starts hankering for a new truck, I might just have to install a cruise control in her '08 GMC Sierra HD farm truck.
post #20 of 26 (permalink) Old 06-15-2018, 10:24 AM
gmctech's Avatar
Cool
Yes, I do see where you're coming fom my friend. sometimes I get ahead of myself because I'm a technician with SET (specialized electrical training) certification... sorry about that.... I dabble with electronics and electrical on everything from airplanes to farm equipment to hybrids to Can-Am Spyders.... I ordered my rostra kit and should be in on Monday. I figure once I get the bike stripped down and start the install it should take me a little less than a day to get the cruise fully functional and buttoned up.... once I do I'd gladly be willing to help out any fellow Versys riders close by to me and install this kit on their bike for a pretty good deal on labour...
twowheeladdict and quexpress like this.
gmctech is offline
