MRA Windscreen - Kawasaki Versys Forum
 1Likes
  • 1 Post By Gangles
post #1 of 9 (permalink) Old 10-12-2017, 04:59 PM Thread Starter
hawkerjet's Avatar
MRA Windscreen
Curious is anyone is running one of these and how do you like it?
https://www.revzilla.com/motorcycle/...00#reviews_tab
Cookin Wid Gas
hawkerjet is offline
post #2 of 9 (permalink) Old 10-14-2017, 11:29 AM
Gangles's Avatar
https://imgur.com/a/SuPL6
I have the one with the spoiler attached at the top. Is it worth the price? Eh... maybe? I mean you can get other, taller screens that may work just as well if not better, for almost half the money...
For clarity I am 6'4" (193cm) and 160-170lbs with a 34" inseam.
The screen is small, but the spoiler helps a LOT with getting the air over my head, I have a Dual Sport peak on my helmet and at the highest setting I'm JUST getting buffeted around the top of my peak, I'm sure if I took it off the air would flow more cleanly past my head.
I think i'll probably end up buying the Givi windscreen and taking the spoiler off of this one and bolting it on to the Givi for even more wind protection with that one.
Overall i'd give it a 6/10, mostly due to the cost vs other windscreens... I'm not sure why it's so much more expensive that the others... Save your money and buy the Givi screen imo, unless you really really want a spoiler...
EDIT: Just saw you linked to the one without the spoiler, which isn't ludicrously expensive like the one with the spoiler is...
SteveJ likes this.
Gangles is offline
post #3 of 9 (permalink) Old 10-15-2017, 08:33 PM
Favor SVP? Can you post up results of that experiment iff'n you get the Givi? I have the 4114 Givi. It is better than the Puig but not quite ti Nirvana yet. TIA.
'15 KLE650LT
'98 KLR650
And most of Canada too, eh?
SteveJ is offline
post #4 of 9 (permalink) Old 10-16-2017, 11:01 AM
Gangles's Avatar
I plan on it
Gangles is offline
post #5 of 9 (permalink) Old 10-16-2017, 03:33 PM
I bought a second hand mra touring windscreen without the spoiler for my '17 v1k.
I found it a bit better than the stock one in the lower position, but I still got a lot of noise on my ears (no turbolence).
Then I bought the mra x-creen touring spoiler, which costed almost twice compared to the windscreen but it allows many different positions. I still have to find the sweet spot, but I'm able to do long distance rides without too much fatigue.
I can't compare it to the other aftermarket windscreens, but I still have to understand if the money spent is worth or not.
With my previous vstrom 650 2010, I found the peace with madstad brackets and an mra variotouring screen. I still have to reach that level of "perfection" with the v1k.
I would have preferred that the lower part of the mra windscreen for the v1k was larger, just like the givi one. That would have probably lowered the noise around the ears. That's the only issue I have.. noise! Earplugs perhaps do their job well in long distance highway rides!
the same windscreen can be mounted also on the newer v650.. but I'm not sure if the results are similar or not..
Inviato dal mio HUAWEI VNS-L31 utilizzando Tapatalk
fear_factory84 is offline
post #6 of 9 (permalink) Old 10-18-2017, 01:44 PM Thread Starter
hawkerjet's Avatar
Thanks Fear Factor for the write up and pics. I really like the look of the touring screen minus the spoiler.
I tried 3 different shields on my FZ09 and the hands down best one was the MRA. The shape of the one on your V-1000 reminds me of it.
So I ordered one yesterday. Will give a report when I get a few rides with it.
Something else about MRA shields is the material they use. It's very safe in a crash. It does not break into shards or sharp edges like some others do.
A riding buddy had an Ermax brand on his bike and took a slow speed spill. The screen broke and the exposed edges were very sharp. Fortunately he did not hit it with any body parts.
Cookin Wid Gas
post #7 of 9 (permalink) Old 10-22-2017, 07:44 AM
I agree the materials tha mra uses are pretty good.
A thing that is annoying me on this windscreen setup is that the upper part is too flexible at highway speed and it's always moving. Perhaps my bolts are bolted over rubber washers. It is possible that they are too soft for the job.
I need to play with it a bit to find the perfect setup.
Let me know if yours is behaving too in this way.
Inviato dal mio BTV-DL09 utilizzando Tapatalk
post #8 of 9 (permalink) Old 10-22-2017, 10:00 AM Thread Starter
hawkerjet's Avatar
I wonder if the vario addition is causing the movement. I won't be running the vario unit on mine.
I tried 3 different small screens on my FZ09 and the hands down winner was the MRA double bubble. It was a tad taller than the other two but produced the most smooth laminar flow of all.
Looking at the pictures you posted I see a similar profile on your MRA shield as the one on my FZ09.
Will advise on how it works and if it wiggles at highway speeds.
Cookin Wid Gas
post #9 of 9 (permalink) Old 10-23-2017, 12:10 PM
I can't show what does my screen at highways speed because I have no action camera to film it, but if you see this youtube video with the v1k and a puig screen with a spoiler, has just the same behaviour as mine:
You can see that the top end of the screen is always moving a little...
This is probably is because how the mounts are made and the fact that we are using bigger screens than the stock one.
