Unplug your swingarm! - Kawasaki Versys Forum
post #1 of 32 (permalink) Old 07-25-2012, 12:29 AM Thread Starter
RockyMoto's Avatar
If your bike is anything like mine (a pretty blue '09) and she has any time on her at all...you just might want to check that little hole in your swingarm...right in front of and below your axle nut....
Seriously.
Ride to live, live to ride.
2009 Kawasaki Versys
2010 Yamaha YZ 250F
2008 Honda CRF 450
2006 Honda CR 250R
I've owned a Maico.
RockyMoto is offline
post #2 of 32 (permalink) Old 07-25-2012, 03:47 AM
andrewhtf's Avatar
Hole? What hole?
Current : Maroon 2011.
Up next :
andrewhtf is offline
post #3 of 32 (permalink) Old 07-25-2012, 04:23 AM
VOz
VOz's Avatar
Does anyone know if an 09 swingarm will fit a 10+?
Looks like it will but welcome any advice, thanks.
Voz
Sydney, Australia
2012 Kawasaki Versys 650
VOz is offline
post #4 of 32 (permalink) Old 07-25-2012, 10:06 AM
Which side of the bike?
[SIZE="1"]Ride. Good.
2019 F750GS
2014 R1200RT
2008 Versys (SOLD 11/19)
2003 ST1300ABS (SOLD 5/15)
post #5 of 32 (permalink) Old 07-26-2012, 07:20 AM
El Tig's Avatar
Both sides but one is a bit further back than the other. There was a member who actually had corrosion to the point of being able to poke through the swingarm so do keep them clear!
El Tig is offline
post #6 of 32 (permalink) Old 07-26-2012, 07:46 PM
Yeap!. swing arm does take water and it take quite a bit of time to drain. I usually, after wash blow air from the front and also keep the bike on Paddock stand to drain the water off.
Just watch out...thanks for head up on the issues.
Fastoman is online now
post #7 of 32 (permalink) Old 07-26-2012, 08:35 PM
I dont have holes...ive got spools there...
NesquikNinja is offline
post #8 of 32 (permalink) Old 07-26-2012, 11:31 PM Thread Starter
RockyMoto's Avatar
Seriously...check the sprocket side on the bottom.
2010 Yamaha YZ 250F
2008 Honda CRF 450
2006 Honda CR 250R
I've owned a Maico.
post #9 of 32 (permalink) Old 07-27-2012, 01:35 AM
Motopsycho's Avatar
So much water was in there the last time I checked it.
IBA # 49372
Motopsycho is offline
post #10 of 32 (permalink) Old 07-27-2012, 06:18 AM
rrichard's Avatar
Thanks for the tip. Mine was dry but a lot of chain grease under there. I can see how they get plugged. I'm going to have to do a better job on bath day.
rrichard is offline
post #11 of 32 (permalink) Old 07-27-2012, 09:02 AM
Yes good reminder! Thanks!
Anyone increase the size of the holes yet? What do you think?
post #12 of 32 (permalink) Old 07-27-2012, 05:09 PM
Ill look again when i get off....i got caught in a WICKED storm yesterday for an hour and a half...if it collects water...its gotta be full haha
post #13 of 32 (permalink) Old 08-18-2012, 06:37 PM
anders55's Avatar
Thank heaven for this blessed forum!
This water dripping issue have been puzzling me for the last month. Thanks for the solution - now the bike is about 1 dl of water lighter..
I have a 2011 - is there a drain hole on the right side swing? I canīt find one.
anders55 is offline
post #14 of 32 (permalink) Old 08-20-2012, 11:34 AM
Motopreserve's Avatar
This seems like a great tip, but for the life of me, I'm not sure where to be looking. I see one small screw on the sprocket side, on the bottom of the swingarm. On the right side, there are 2 small holes, look to be same size, but nothing is covering them.
Any clarification is much appreciated.
Scott
**'2011 Versys, '75 Honda CL360 cafe project, '76 CB 550, '09 Husky TE610**
Motopreserve is offline
post #15 of 32 (permalink) Old 08-20-2012, 11:54 AM
Lours_Polaire's Avatar
Scott
+1
Pic please
Pretty please ...
LOP
Lours_Polaire is offline
post #16 of 32 (permalink) Old 08-21-2012, 08:16 AM
El Tig's Avatar
Swingarm Drain Holes 08
These are cameraphone pics of the underside of an 08. No, I don't clean the underside of my swingarm often but I do keep the holes open.
http://www.kawasakiversys.com/forums...hp?albumid=434
El Tig is offline
post #17 of 32 (permalink) Old 08-21-2012, 08:22 AM
Thanks for the pics TIG. Are people suggesting that the screw be removed from the left side? I already have the open holes (2) on the right. I guess I don't need to do anything to that side???
Appreciate the help.
post #18 of 32 (permalink) Old 08-21-2012, 09:29 AM
Thank's for the info and the pic !!!
LOP
post #19 of 32 (permalink) Old 08-24-2012, 01:36 PM
anders55's Avatar
Hereby answering my own question. The drain hole on a bike with ABS is on the inside of the right part of the swing. (Not visible here, but just above the arrow)
anders55 is offline
post #20 of 32 (permalink) Old 08-24-2012, 10:14 PM
There are definitely drain holes in both the swing arms for all models.
Just take you time to clean and check and make sure you get the water off as you guys often ride on salt. We are a bit safe here as its only water and alloy dont rust with water, but with salt that a different ball game.
