90 degree valve stem help - Kawasaki Versys Forum
Like Tree18Likes
  • 2 Post By weljo2001
  • 1 Post By timster
  • 1 Post By aboyandhisversys
  • 1 Post By fasteddiecopeman
  • 1 Post By nayr14
  • 2 Post By fasteddiecopeman
  • 2 Post By twowheels
  • 6 Post By Gigitt
  • 2 Post By Gigitt
post #1 of 15 (permalink) Old 09-18-2017, 03:16 PM Thread Starter
timster's Avatar
Coming back to Nashville from a weekend trip to Barbers Motorsports park in Birmingham I hit something small and sharp on the highway. After hearing the load POP! I immediately pulled over to find a good size chunk of rubber missing from my rear tire which sucks since I only have 2500 mile on these. This happened with only 20 miles left on a 500 mile trip so I made it home thankfully but the tire is toast. I can see the metal cord in the missing chunk.
I will replace the tire myself and I would like to replace the stock stem with a 90 degree. I'm seeing different sizes? Can anyone recommend size and supplier? No-Mar has a selection but not sure of size since this bike is new to me. https://www.nomartirechanger.com/category_s/34.htm
You will never see a motorcycle parked in front of a psychologist office!
timster is offline
post #2 of 15 (permalink) Old 09-18-2017, 03:30 PM
You want the 11.3mm. The last 2 bikes i got mine from Kurvygurl for over $20.00 a pair. I have a pair i ordered off of ebay for less than $3.00 a pair waiting for a new set of tires to go with them....2 x Black CNC Aluminum Motorcycle 90° 11.3mm Wheel Tire Stem Tubeless Valve | eBay
post #3 of 15 (permalink) Old 09-18-2017, 03:37 PM Thread Starter
timster's Avatar
Thanks!!!
weljo2001 likes this.
timster is offline
post #4 of 15 (permalink) Old 09-18-2017, 03:56 PM
Originally Posted by timster View Post
Thanks!!!
Anytime...
post #5 of 15 (permalink) Old 09-18-2017, 04:51 PM
I was about to chime in that the 11.3mm are the ones you need,
I will add a cautionary note: I've seen all sorts of prices, from scare-you cheap to scare-you expensive. I bought cheapies, returned them and bought more $$$ ones.
Conclusion: I'd opt for more expensive ones, the cheapies are just that, unless you like to gamble.
JMO.
motorboy likes this.
aboyandhisversys is offline
post #6 of 15 (permalink) Old 09-19-2017, 01:14 PM
I put the 90 degree valves I bought from a Honda store, that they said were for a Gold Wing, but I'm thinking of getting some from Ebay as they're smaller, and neater looking.
post #7 of 15 (permalink) Old 09-21-2017, 11:22 PM
nayr14's Avatar
My Street Triple has the 90 degree valve stems stock. After experiencing those, I'm not sure why every manufacturer doesn't use them. I guess the extra dollar or two a unit is too much to bear.
quexpress likes this.
nayr14 is offline
post #8 of 15 (permalink) Old 09-22-2017, 12:05 PM
Here's what those Honda 90 degree 'stems' look like, on my '15....
timster and 16VGTIDave like this.
post #9 of 15 (permalink) Old 09-22-2017, 04:46 PM
Bought the cheapy ones from EBay. They took a month to arrive but work just fine. They are CNC aluminum. I've been using them for a number of months with no issues. If you store your bike outdoors though most cheapy stuff will corrode or rust but no corrosion so far with these.
Sent from my LG-H873 using Tapatalk
weljo2001 and timster like this.
post #10 of 15 (permalink) Old 09-22-2017, 11:17 PM
The best option for 90 deg valves are like these low profile ones on my Versys.
NOTE: install the valves pointing to the right!
You will thank me on your 1st air up
Gigitt is offline
post #11 of 15 (permalink) Old 09-23-2017, 09:43 AM
Source ??
OK from China?? how about a source and part number.
post #12 of 15 (permalink) Old 09-23-2017, 09:53 AM
Not too hard to find sources with google.
Google: 90+degree+tyre+valve
Google: 90+degree+valve+stem+motorcycle
onewizard and quexpress like this.
Gigitt is offline
post #13 of 15 (permalink) Old 09-23-2017, 05:50 PM
I bought a set from Moto-D Racing that seem made to last forever for $25. Valve stems are not terribly complicated devices, so the cheapies from China would probably work just as well. With what I paid for them, I might take them off and replace with regular valve stems if I get rid of it.
SlowIsSmooth is offline
post #14 of 15 (permalink) Old 09-23-2017, 09:04 PM
Buying direct from China is hit and miss with quality and you really get cheaply made/finished stuff.
IMHO buy them from a store or reputable seller. You can at least look and feel the quality before buying it, or best you can return it.
I would not bother taking them off to put on another bike... just buy another set and add them on the 1st tyre change.
once removed you might have issues getting a good air seal due to the rubbers being squished.
Gigitt is offline
post #15 of 15 (permalink) Old 09-24-2017, 03:59 PM
https://m.ebay.com/itm/90-Degree-CNC...-/172417867846
I believe you need the 11.3mm size.
