Installing Grip Puppies/Installing LED Brake light - Kawasaki Versys Forum
Like Tree11Likes
  • 2 Post By bneedles
  • 3 Post By Gigitt
  • 1 Post By troop
  • 3 Post By fasteddiecopeman
  • 1 Post By BLACK DOG
  • 1 Post By Doug Just Doug
post #1 of 16 (permalink) Old 09-10-2017, 07:50 PM Thread Starter
Hi. I have a new Versys 650 LT. Going to install Grip Puppies but I've never had to remove hand guards on my previous bikes. Is there any secret to removing the hex head bolt at the end of the handlebar? I can't seem to budge it and I don't want to strip out the head.
Also, I am looking at installing a Hyperlite LED Brake/Running light by the license plate like on my previous bikes. Any secrets on how to run wiring from the license plate to under the seat where the wiring connections are?
Thanks, Bill
bneedles is offline
post #2 of 16 (permalink) Old 09-10-2017, 08:22 PM
quexpress's Avatar
They are not easy to remove (thread lock, etc.). It took quite a bit of force to remove mine. I was however very careful not to let my hex wrench slip.
Thanks, Bill
It's not a secret but here's how I ran wires from under the seat to the license plate. The rear fender has a hollow section which makes this quite easy to do. The key is knowing where to drill your holes.
Under the seat behind the seat latch, you can drill a hole between the two hex bolts shown in this pic.
On the left side of the little square block that is located under the rear license plate bracket of the rear fender, you can drill a hole as shown below. A pencil has been pushed through the drilled hole.
Pass a wire through the top hole.
... and pull it out from the bottom end of the fender.
You can now fish your electrical wires through the same route and then make the required connections at both ends.
Good luck!
I still have a full deck.
I just shuffle slower.
quexpress is offline
post #3 of 16 (permalink) Old 09-11-2017, 12:46 AM Thread Starter
Thank you very much. Exactly what I needed...Bill
quexpress and Boston like this.
bneedles is offline
post #4 of 16 (permalink) Old 09-11-2017, 07:56 AM
TIP:
When installing the foam grip puppies... use a few drops of liquid dish soap and water.
Once you have an inch onto the grip, it will get harder and harder to push/pull it all the way... The foam needs to be slippery and when slippery you cannot grip the foam to pull it. USE A DRY clean rag now over the foam end that is on the grip and pull it all the way into position... The rag is the trick to getting it fully on - with rag it takes 30 sec per grip.
Gigitt is offline
post #5 of 16 (permalink) Old 09-11-2017, 09:28 AM
Purell or alcohol based hand sanitizer also works well. Alcohol based gel dries much faster than soap. FYI...
quexpress likes this.
troop is offline
post #6 of 16 (permalink) Old 09-11-2017, 09:39 AM
I've run across several hex bolts on the Versys that were hard to remove. I simply take a length of pipe or conduit (2 or 3 feet) and slip it over the end of the allen wrench. I bear down on the end of the pipe slow and steady with my right hand, being sure to keep the wrench aligned with my left. It breaks the thread lock every time.
Bale2011 is offline
post #7 of 16 (permalink) Old 09-11-2017, 09:47 AM
Doug Just Doug's Avatar
I had to break the thread locker to install Givi hand guards on my ABS model. I used an L-shaped Allen wrench (as opposed to a T-handle) clamped into a large Vice Grips, which allowed me to put my body weight into it while using one hand to make sure the wrench didn't slip out of the bolt.
2015 Versys 650 ABS
AMA, MSTA, Retreads
Doug Just Doug is offline
post #8 of 16 (permalink) Old 09-11-2017, 01:16 PM
FWIW - I bought a set of socket "allen-wrenches" in both 3/8" and 1/4" drive (from Princess Auto/ Harbor-Freight Tools), so I VERY seldom ever use an "L" shaped wrench. FAIRLY inexpensive, and work FINE!
BTW - the 3/8" set include a 1/2" drive 14mm for the front axle removal.
post #9 of 16 (permalink) Old 09-11-2017, 02:10 PM
BLACK DOG's Avatar
Also if you get the socket type hex keys you can use them with a hammer type impact driver and avoid eccentric loads on the bolt.
Or am I the eccentric load?
Doug Just Doug likes this.
BLACK DOG is offline
post #10 of 16 (permalink) Old 09-11-2017, 03:09 PM
quexpress's Avatar
Guilty! That's what I did!
post #11 of 16 (permalink) Old 09-11-2017, 04:20 PM
hawkerjet's Avatar
I have installed grab on grips and grip puppyies of several bikes. I found the easiest method is using compressed air.
If the end of the grip has a lip I tightly warp some electrical tape around the end to compress and make it smaller. Then slide the grip puppy over the end of the existing grip. Put your air nozzle under the end of the puppy inflate and work the grip on. If you cannot get air under the grip from one end then try the other.
It takes a bit of technique but once you get it going you will be amazed how smoothly the grip goes on. Nice thing is this method is much less messy than the wet methods.
Good luck.
hawkerjet is offline
post #12 of 16 (permalink) Old 09-12-2017, 02:33 PM Thread Starter
What is the metric hex size for the handlebar end? I want to buy the correct set....Thanks
bneedles is offline
post #13 of 16 (permalink) Old 09-13-2017, 12:19 PM
On my '15 it's 6mm.
post #14 of 16 (permalink) Old 09-14-2017, 08:40 PM Thread Starter
thanks
bneedles is offline
post #15 of 16 (permalink) Old 09-15-2017, 08:17 AM
Smiley's Avatar
I use Grip Buddies instead: nothing to remove. Simply wrap them around the grip and the velcro keep them where you put them. I have very large hands and they greatly reduce hand/wrist cramping caused by small diameter grips.
Smiley is offline
post #16 of 16 (permalink) Old 07-22-2018, 03:08 PM
Good luck!
Thanks! I just installed a set of Hyper-Lites using your method for running the wires. Nice clean install.
2015 Versys 650 ABS
AMA, MSTA, Retreads
