handlebar risers - Kawasaki Versys Forum
post #1 of 17 (permalink) Old 07-15-2012, 06:25 PM Thread Starter
handlebar risers
I am looking to gain some comfort,while riding.I have installed protaper bars and rotated them back some. Got some neck issues (too much motocross in younger days). I am interested in some feedback on bar risers,etc. Thanks!!!!
crobar is offline
post #2 of 17 (permalink) Old 07-15-2012, 07:12 PM
http://www.shop.motowerk.com/Anti-vi...ANVB-HB-RS.htm
I have the older regular riser (no anti vibe). Works well.
post #3 of 17 (permalink) Old 07-15-2012, 07:13 PM
Enjoy.
stater61 is offline
post #4 of 17 (permalink) Old 07-15-2012, 07:39 PM
2daMax's Avatar
I have the non-anti vibe risers, allows the me to sit a little towards the rear more, which my pillion wife says it helps to block the wind with my body being higher up.
Previous Ride:
My V's Farkle Log:
2daMax is offline
post #5 of 17 (permalink) Old 07-15-2012, 09:34 PM
I have the single Motoworks block and have been considering doubling them up..Then I would have to change all the routing of the cables and wires to the rear of the trees..
Zrex1 is offline
post #6 of 17 (permalink) Old 07-15-2012, 10:56 PM
Works fine for me. Normal spec. www.motowerk.com
post #7 of 17 (permalink) Old 07-15-2012, 11:38 PM
post #8 of 17 (permalink) Old 07-16-2012, 08:50 AM
V-COASTER's Avatar
I have the same problem. On longer rides, across my back and shoulders would get really sore so I had the Motowerk 1" riser on which helped.
When I installed the Seat Concepts seat. it set me a little bit higher and further back so I replaced the Speedy riser with a 2" ROX and that was the ticket. Everything fits me perfectly now.
2013 Versys1000
V-COASTER is offline
post #9 of 17 (permalink) Old 07-16-2012, 09:19 AM
Zatx's Avatar
I just had my SC seat put on last week and ran into the same height problem. I ordered the 1in. Speedy's riser hoping that would be enough, I'm 6'02". :/
Zatx is offline
post #10 of 17 (permalink) Old 07-16-2012, 09:44 AM
kenr74's Avatar
I'm running bars with an ATV bend. Much better than stock without having to add a riser.
kenr74 is offline
post #11 of 17 (permalink) Old 07-16-2012, 06:34 PM Thread Starter
Thanks.Did you use the stock cables?
crobar is offline
post #12 of 17 (permalink) Old 07-16-2012, 07:29 PM
BaileyMan's Avatar
PMing you with a question about your set up...
2011 Imperial Red
A little bit of road rash
BaileyMan is offline
post #13 of 17 (permalink) Old 07-16-2012, 09:45 PM
andrewhtf's Avatar
Had a 3/4 inch riser for only a week. Comfortable and less bar vibes on the interstate , and the pillion likes it too.
but once i hit the dragon's tail i missed the agility and almost crashed. Took it off immediately after and all back to normal, including the vibes. Looking to get a protaper with atv bend coming year end.
Current : Maroon 2011.
Up next :
andrewhtf is offline
post #14 of 17 (permalink) Old 07-17-2012, 12:06 AM
post #15 of 17 (permalink) Old 07-17-2012, 01:36 AM
What is the rise on "high ATV" bars vs. stock ith a motowerk riser? Also do they still accept bar ends? I have my throttle lock I like.
08' Versys
HAWKSHOT99 is offline
post #16 of 17 (permalink) Old 07-17-2012, 06:12 AM
Stock bars have about 145 mm (5.7") height. Motowerk's 1" (25.4 mm) riser is mounted on a rearward angle on stock handlebar mount, so it really adds less than 1" height, and moves handlebar back a bit. Tusk ATV High bars have a 4.75" (120.65 mm) height (2.51"/61 mm sweep and 30.5"/775 mm width) and are larger at the mount (1-1/8" instead of 7/8"), so they need a 7/8" to 1-1/8" fat/tapered bar adapter. Rox pivoting 2" (50.8 mm) riser/adapter can be adjusted forward and backward, which also affects resulting height of about 7/8" to 1" higher than stock with Tusk ATV High bars.
With Motowerk's 1" riser, you could use a 7/8" aluminum ATV High handlebar, but they also have a crossbar, and offer less vibration absorbtion than a 1-1/8" aluminum 'fat bar'. ProTaper ATV low 7/8" aluminum bars have a height of 5.5" (140 mm), a sweep of 3.3" (84 mm) which is close to stock, and a width of 32" (813 mm) which is wider than stock but can be cut shorter if desired: http://www.ebay.com/itm/Pro-Taper-7-...30308f&vxp=mtr
ProTaper 7/8": http://www.protaper.com/products/handlebars/se
Zeta 1-1/8" (1-1/8") aluminum ATV Medium bend (800 mm width, 123 mm height, 70 mm sweep):
http://www.ebay.com/itm/Zeta-SX-Hand...a297cc&vxp=mtr
Zeta 1-1/8": http://www.zeta-racing.com/handlebar...plication.html
ProTaper 1-1/8": http://www.protaper.com/products/handlebars/contour
All aluminum handlebars do not have the threaded ends for stock bar ends, although I really don't feel the need for them with my tapered aluminum bars and Zeta hand guards.
post #17 of 17 (permalink) Old 07-17-2012, 09:37 AM
V-COASTER's Avatar
Yes I did. I was kind of leery before I ordered but I had sort of remembered reading in an older post that a couple of people used the ROX and it worked out.
2013 Versys1000
