new bike new crash bars - Kawasaki Versys Forum
post #1 of 6 (permalink) Old 07-09-2012, 11:35 AM Thread Starter
Hello, new to the forum, have an 08 red 650. Has givi side cases, cruise control, hand Fairfax, heated grips...few things extra.
I installed my HB crash bars the other day and had different
results than expected based on reviews.
I had good instructions that came with them, in English, along with torque ratings. Everything went on smoothly, no strippig, no trouble.
Except now the plastic covers that go above the rearsets won't fit. My first instinct was to take out the dremmel.....is this what others have done??
NesquikNinja is offline
post #2 of 6 (permalink) Old 07-09-2012, 11:45 AM
I put H-Bs on my '08 about 4 years back, and the only problem I can recall, was that those nuts that are "captured" in the front of the engine began to turn, so I could NOT torque them as per instructions.
post #3 of 6 (permalink) Old 07-09-2012, 02:40 PM
Mchustlr's Avatar
I put the same set on my 08 about a year ago...no issues.
Maybe you dont have it completely lined up right?
Mchustlr is offline
post #4 of 6 (permalink) Old 07-09-2012, 04:01 PM Thread Starter
There's 4 mounting points...can't really be lined up wrong.
Mine look a little different than some that I've seen. Maybe they are a new gen of something
EDIT:
*FACEPALM* just realized the cover goes under the bars and not over..
post #5 of 6 (permalink) Old 07-09-2012, 05:35 PM
Are you referring to the plastic cover over the filter canister on the California model? If so, I just cut mine to acheive clearance with no bad results.
Buckeye is offline
post #6 of 6 (permalink) Old 07-09-2012, 09:31 PM
Originally Posted by Buckeye View Post
Are you referring to the plastic cover over the filter canister on the California model? If so, I just cut mine to achieve clearance with no bad results.
Yeap! the lower side flaring need a slight shaving off. No big deal...
Fastoman is online now
