Handguards on ebay. none??? - Kawasaki Versys Forum
post #1 of 16 (permalink) Old 11-29-2011, 01:12 PM Thread Starter
katangilis's Avatar
Hi guys
its cold in here during the winter ,and i try to fish a new handguards for my V.
but while searching "handguard kawasaki" on ebay ,i dont get any match
should i search in other words? ,and if so, what should i search ?
10X in advance
katangilis is offline
post #2 of 16 (permalink) Old 11-29-2011, 02:29 PM
Try this one:
http://www.ebay.com/sch/i.html?_from...All-Categories
I searched "motorcycle handguards".
post #3 of 16 (permalink) Old 11-29-2011, 02:32 PM
jrider's Avatar
If you only want to use the handguards for the wind and the occasional small stones and insects, you can use KTM handguards with very slight modification. Got mine from local shop for less than $60.
Gerald
jrider is offline
post #4 of 16 (permalink) Old 11-29-2011, 06:44 PM
Pismocycleguy's Avatar
Talking Barkbuster/Storm hand guards
I bought the Barkbuster Storm handguards from Twisted Throttle.
Inexpensive, fit well, and easy to install. They block the wind well also.
“Don’t bother me with DETAILS!”
Pismocycleguy is offline
post #5 of 16 (permalink) Old 11-29-2011, 06:56 PM
cmoreride's Avatar
These?
http://www.twistedthrottle.com/image...view/5145/652/
I'm interested in just the wind screening aspect of them.
Are they large enough to function well for that?
Is there any down side to removing bar end weights?
cmoreride is offline
post #6 of 16 (permalink) Old 11-29-2011, 10:09 PM
Not on either of my Vs - removed the bar-ends to install the Zetas.
post #7 of 16 (permalink) Old 11-29-2011, 11:22 PM
Motopsycho's Avatar
guards
mounts
works for me
IBA # 49372
Motopsycho is offline
post #8 of 16 (permalink) Old 12-01-2011, 03:31 AM Thread Starter
katangilis's Avatar
thank U all for update
so i understand there is no specific item for the V ,and i should look for regular handguards
ill check again with your tips
post #9 of 16 (permalink) Old 12-01-2011, 04:46 AM
dxhFZ's Avatar
http://www.ebay.com/itm/10-11-KAWASA...#ht_942wt_1061
for 2010 and 2011 kawasaki Versys specific hand guard
If you type simply "Versys" into the ebay search bar you come up with alot of cool stuff, including hand guards
dxhFZ is offline
post #10 of 16 (permalink) Old 12-01-2011, 04:49 AM
dxhFZ's Avatar
dxhFZ is offline
post #11 of 16 (permalink) Old 12-01-2011, 06:06 AM
I have the KTM handguards on my 2011 V. They work rather well as wind blocks. Seem pretty sturdy too. I think a parked drop would protect the brake and clutch from a break but not a bend. At anything moving I highly doubt it.
Had to remove bar ends and to me I actually feel less vibe. I think it is because the hand guards act as a damper by being secured mid handle and end handle.
I picked mine up from a fellow forum member. When I get ready to get an extra set of tires for doing some gravel and off road fun I'm looking at a good set of high quality handguards with the metal bar in the middle.
MikeV is offline
post #12 of 16 (permalink) Old 12-01-2011, 09:13 AM
Hand guards are expensive and not a mod I would consider doing again. It cost me about ~$120 for a comparatively high quality BarkBuster Storm hand guard kit. $60 for the hand guards themselves and $60 for the Versys specific mounting kit.
I find they don't make any difference when it comes to keeping the hands warm. They are mostly there for appearances. They do protect the levers in a drop though but replacement levers only cost $20.
In comparison Oxford heated grips cost $80, good insulated gloves start at $100, heated glove liners are $80+, and heated gloves are $150+ -- all are going to offer a lot more value than hand guards if warm hands is the goal.
post #13 of 16 (permalink) Old 12-01-2011, 09:32 AM
+1 on that information
I think my cost for warm hands atm is about 200$. Thats with the KTM Handguards (they actually do well for my tiny hands) for wind breaking and my heated gloves.
P.S. Where did you get a replacement clutch lever for 20$!?! Mine cost me $40 and 7$ for shipping. I have an extra one now but I like to keep my options open in case I need another one.
MikeV is offline
post #14 of 16 (permalink) Old 12-01-2011, 12:37 PM
My dealer sells after market clutch/brake leavers for ~$20. Also avail on ebay. Sounds like you got a Kawasaki branded one. The aftermarket ones look and feel identical to the OEM ones. The only difference is the price.
post #15 of 16 (permalink) Old 12-01-2011, 12:44 PM
you are correct. I'll make sure I find one aftermarket instead of OEM.
Thanks.
MikeV is offline
post #16 of 16 (permalink) Old 12-01-2011, 11:15 PM
Motopsycho's Avatar
I'm using kuryakyn iso grips, so I had to use the universal ones. Can't use the threaded bar end with those grips.
IBA # 49372
