problem installing denali lights on SW Motech mounts - Kawasaki Versys Forum
post #1 of 10 (permalink) Old 08-07-2011, 07:43 PM Thread Starter
smoore's Avatar
Did anybody out there have this issue?
I'm trying to install a set of Denali lights on the SW Motech auxiliary light mounts. Well, the large bolts used in the Denali light mounts will NOT go through the hole in the flat horizontal plate of the SW Motech mount. I'm trying to drill out the hole in the plate, to no avail.
Did I just get a defective light mount, or has anybody else encountered this?
steph moore
New Mexico, USA
2008 Versys (a/k/a Hellboy)
smoore is offline
post #2 of 10 (permalink) Old 08-07-2011, 09:06 PM
I got the new SW Motech brackets for the 2011 Versys and the Denali V1 lights and had no issues at all. Very smooth install.
I recommend you contact twisted throttle before drilling holes.
post #3 of 10 (permalink) Old 08-18-2011, 03:11 PM
twistedthrottle's Avatar
Hi there - Kevin from Twisted... I am sorry you are having an issue. I investigated your problem and realized that I should have included a note and a link to the optional M8 Denali hinge required on the light mount page. I did add the note now and a drop down list of hinges for different applications including the M8 hinge.
I hope this helps.
Kev
twistedthrottle is offline
post #4 of 10 (permalink) Old 08-19-2011, 12:28 PM Thread Starter
smoore's Avatar
I hope this helps.
Kev
Hi Kev --
Thanks for your response. I am using the hinges that were shipped with the Denali lights -- I just replaced the large bolt with a smaller one and used fender washers to make it a bit more stable. It's adequate for now, but I'll consider ordering a pair of the M8 hinges if my kludge doesn't work.
steph moore
New Mexico, USA
smoore is offline
post #5 of 10 (permalink) Old 08-19-2011, 06:32 PM
Sprocket's Avatar
Hope you can post pictures of your install. Just wondering ballpark cost?
Sprocket is offline
post #6 of 10 (permalink) Old 08-19-2011, 11:01 PM
Motopsycho's Avatar
I had trouble putting my PIAA's on these brackets. I cut and drilled a piece of stainless steel angle iron to offset them far enough to clear the fairings.
IBA # 49372
Motopsycho is offline
post #7 of 10 (permalink) Old 08-22-2011, 12:53 AM
Ran into the same thing with the d2s. I just drilled out a slightly larger hole but knowing about the m8 hinge would have been handy!
CC
CrazyCarl is offline
post #8 of 10 (permalink) Old 08-22-2011, 11:30 AM
Here are my Denali lights on the bike. One out of 100 vehicles will flash their highbeams at me. I have approached at least a dozen LEOs with no complaints.
post #9 of 10 (permalink) Old 08-22-2011, 11:52 AM
Congrats on the sweet lookin V!
CC
post #10 of 10 (permalink) Old 01-21-2012, 05:29 PM
douglasgraham's Avatar
Mine went on easy as pie.
douglasgraham is offline
