Windscreen Etension brackets - Kawasaki Versys Forum
post #1 of 21 (permalink) Old 06-17-2011, 07:24 AM Thread Starter
eeore39648's Avatar
I just got my Versys. I have tried the windsield in all positions, even upside down. Still I get buffeting, that I don't want.
I would really like to keep the OEM windshield.
Does anyone make Exteneder brackets?
That would bolt to the OEM brackets, thus moving the OEM windsield upward.
If not looks like I am going to look into fabbing something myself.
eeore39648 is offline
post #2 of 21 (permalink) Old 06-17-2011, 07:27 AM
dfmcse's Avatar
Check out the MRA X-creen Add-On Variable Windscreen Spoiler Blade (clamp-on)
Doug
Mine is a BLUE 2009 KLE650A9F
Former RED KLR650 Rider.
Former Yellow/Black Suzuki M50 Rider.
dfmcse is offline
post #3 of 21 (permalink) Old 06-17-2011, 08:44 AM
DR_
You might want to try a different helmet that has better aerodynamics.
Another option is the Powerbronze windshield since it looks similar to stock but is a couple inches higher. Pretty cheap to.
DR_ is offline
post #4 of 21 (permalink) Old 06-17-2011, 08:57 AM
Does anyone have the Powerbronze windshield on their bike?
toofer is offline
post #5 of 21 (permalink) Old 06-17-2011, 09:19 AM
There's an adjustable windshield bracket for sale in some shops:
http://www.twistedthrottle.com/trade...rint/4893/652/
2008 Kawasaki Versys
1994 Honda NTV 650
1999 Suzuki AN125
blahwas is offline
post #6 of 21 (permalink) Old 06-17-2011, 12:20 PM
It is over 2 times the cost of a Powerbronze windshield though.
toofer is offline
post #7 of 21 (permalink) Old 06-17-2011, 12:34 PM
DR_
Yep, this is mine. It pushed the heavy airflow to the very top of my Bell Star helmet and reduced the buffeting considerably
DR_ is offline
post #8 of 21 (permalink) Old 06-17-2011, 01:01 PM
That's a neat looking windshield... I like it.
toofer is offline
post #9 of 21 (permalink) Old 06-18-2011, 07:12 AM Thread Starter
eeore39648's Avatar
Different helmet never crossed my mind. I do have a couple others I could try.
I am liking the Powerbronze windshield.
What helmet do you wear?
What is your hieght?
post #10 of 21 (permalink) Old 06-18-2011, 07:14 AM Thread Starter
eeore39648's Avatar
I was a fan of the Bracket, until I saw the Price!
Thanks for posting, I really think anyone could get the OEM windshield to work, with the bracket though.
post #11 of 21 (permalink) Old 06-18-2011, 08:54 AM
If you mentioned what year your Versys is, I didn't notice it so my suggestion may not be a viable one for you.
This is what I replaced the OEM windscreen with after fiddling with it as you've attempted. It isn't perfect but it is adjustable and does work nicely - in my case, at least - to reduce buffeting. It looks good, is well made, and doesn't cost a king's ransom either.
http://www.twistedthrottle.com/trade...view/4561/363/
post #12 of 21 (permalink) Old 06-22-2011, 10:31 PM
Try this if you're looking for cheap. Basically two strips of aluminum from Home Depot.
http://www.kawasakiversys.com/forums...ead.php?t=1144
lanesplitter is offline
post #13 of 21 (permalink) Old 06-23-2011, 07:11 AM Thread Starter
eeore39648's Avatar
I have thought about doing something similar. I have to go to the hardware, this morning I will check on the stock.
Thanks for your post!
post #14 of 21 (permalink) Old 06-23-2011, 07:56 AM
dallasdon's Avatar
Windshield Extenders mounts
I developed these about 2 years ago and it's something you can do in your garage with a grill and grinder and a little paint. You can raise your windsheld 4" overall or somewhere in between
'09 Versys -Green
TET'68 Survivor
dallasdon is offline
post #15 of 21 (permalink) Old 06-23-2011, 10:59 AM
CJBROWN's Avatar
Givi.
Pick up a used one for under a hundred. No fiddling, no adjusting, no farting around with it to make it work. Just bolt it on and go. Looks good, works, good, solves the issue. The rest of all that adjusting bracket crap is for the birds.
Chris Brown
In SoCal
CJBROWN is offline
post #16 of 21 (permalink) Old 06-23-2011, 01:23 PM
Ogre_fl's Avatar
Originally Posted by CJBROWN View Post
Givi.
Well, maybe for you.
I have the Givi shield and its not quite tall enough for me.
The buffeting is not bad but the wind noise is way too much, even with ear plugs.
I was planning on getting the Madstad bracket as I had great results with the one on my Strom & Buell, but first I will try fabbing up a set of extenders.
Oddly my bike came with the Givi on it and other than the wind noise I thought it was pretty good.
A few weeks ago I tried the stock screen, I have been swapping them back & forth and at least for summer I think I prefer the stock one.
Ogre_fl is offline
post #17 of 21 (permalink) Old 06-23-2011, 01:33 PM
CJBROWN's Avatar
Hmmm...I'll have to try the stock one again.
Chris Brown
In SoCal
CJBROWN is offline
post #18 of 21 (permalink) Old 06-23-2011, 03:46 PM
pirnie's Avatar
Mastad Disappointment
Originally Posted by Ogre_fl View Post
...I was planning on getting the Madstad bracket as I had great results with the one on my Strom & Buell, but first I will try fabbing up a set of extenders.
Anyone else find that the Mastad bracket is too wobbly? I'm suppored to have one of the newer ones, with the strengthing L-bar horizontally, but is has a real bounce and rattle with the Givi shield.
pirnie is offline
post #19 of 21 (permalink) Old 06-23-2011, 10:42 PM
Ogre_fl's Avatar
I don't have the Versys bracket so I can not reply about the bouncyness, but on the Strom once you made your basic adjustments if you don't snug up the lower screws they would rattle.
Even with the lowers snugged up you can still use the upper wheel screws to adjust the tilt.
Ogre_fl is offline
post #20 of 21 (permalink) Old 06-24-2011, 06:56 AM Thread Starter
eeore39648's Avatar
I fabricated a set of brackets yesterday. I used 3/4" x 1/8" aluminum flat stock. I cut them at 7 1/2" long each. I was able to move the stock screen up 3 1/2"
I tried it out at 80MPH I think I can live with the results!
Givi.
If you can find One Used, let us know!
