Kaoko Cruise Control Installation - Kawasaki Versys Forum
post #1 of 7 (permalink) Old 06-09-2011, 01:18 AM Thread Starter
G19Tony's Avatar
It took about 20 minutes to install. You need a #6 hex socket and a heat gun. I tried without the heat gun and didn't like the sounds coming from the handlebars. The heat made it quick and easy. You reuse the M8 screw. There is a set screw on the control, it should be stiff turning. The directions are very simple to follow. I haven't tried it out yet, but will in the next couple days. The lock is very easy to override if you need to. They recommend mild thread locker on the screw, so I had some blue laying around.
Here is the old bar end weight and screw. A quick trip on the wire wheel removed the old locktite or whatever it is Kawasaki uses.
I ran a nylon bore brush on the threads inside the handlebar to clean up the old locktite.
The cruise control with new bar end weight, thrust washer and screw.
Completed farkle
G19Tony is offline
post #2 of 7 (permalink) Old 06-19-2011, 04:31 PM
eeore39648's Avatar
Hows it working?
How is the cruise control working?
How do you set it while riding?
eeore39648 is offline
post #3 of 7 (permalink) Old 06-19-2011, 06:50 PM
I have the same throttle lock as the OP. It is not cruise control(maintain the same speed as in your car). What these do is lock the throttle in the same location. So if you set it while accelerating you will keep speeding up.
I like it foe highway use. I do not use it for long distances, just a minute here and there to rest my hand.
To set it....There is a ring that spins between the throttle tube and the end weight. You spin that ring backwards toll it pushes against the throttle tube creating to much resistance for the throttle to close.
08' Versys
HAWKSHOT99 is offline
post #4 of 7 (permalink) Old 06-19-2011, 11:37 PM Thread Starter
G19Tony's Avatar
That's all I want to use it for too. Just rest my hand for a bit. The knurled knob was too loose on my test ride, I had to turn it too much to get it to lock, so I tightened the set screw. I haven't had a chance to try it out again.
G19Tony is offline
post #5 of 7 (permalink) Old 06-20-2011, 02:51 PM
rlj
rlj's Avatar
ditto....after watching the video on their site I was impressed with the way the it worked, to this day I can never set the throttle lock like the video does.....even though it can be harder to set than the video shows, on a long ride on the interstate it proves to be invaluable. I don't use it more than a few minutes at a time however and I highly recommend it. I give it 4 stars out of 5.
rlj is offline
post #6 of 7 (permalink) Old 06-20-2011, 02:55 PM
rlj
rlj's Avatar
and about using a heat gun to heat the bar end weight before removing, highly recommended!!! I didn't and I stripped the hex bolt, it was a bear trying to remove it. A 5-10 minute job ended up taking 45 minutes and four cold ones.......
rlj is offline
post #7 of 7 (permalink) Old 06-20-2011, 10:22 PM
The 4 cold ones may be why it took 45 mins. Actully thats pretty good time for that much beer that quick.
08' Versys
