44 tooth mod - Kawasaki Versys Forum
post #1 of 24 (permalink) Old 05-04-2011, 02:58 AM Thread Starter
44 tooth mod
Well did the 44 mod today and what a difference!! I can get through an intersection now with out upshifting Power is still there, but more smoother in delivery! I'm curious if anyone noticed an increase in gas mileage? Thanks everyone for all the posts and helping me to make my decision. Hoping for warmer days here in the soggy Northwest!
Rodski is offline
post #2 of 24 (permalink) Old 05-04-2011, 06:44 AM
If you kept the original front sprocket, your mileage should improve some as the rpms will drop as you cruise in any gear on the highway. How much though is difficult to measure since there are so many variables - wind, tire pressure, rapid acceleration, when you shift, etc, etc, etc.
But yes, theoretically, mileage will improve running at fewer rpms for a given speed.
Where did you obtain your 44T sprocket as I'm considering doing mine next month?
toofer is offline
post #3 of 24 (permalink) Old 05-04-2011, 12:55 PM
I was wondering why Kawaski decided to gear the versys different than the Ninja. I do notice running at higher RPMs for the same speeds. On my Ninja I could travel the two lanes and achieve 60 MPG. So far the Versys is getting 50 MPG.
post #4 of 24 (permalink) Old 05-04-2011, 01:00 PM
perhaps they thought the versys is not a pure street bike, and needed a little more power? it has plenty though, so good question
ZerothLaw is offline
post #5 of 24 (permalink) Old 05-04-2011, 01:49 PM
Pismocycleguy's Avatar
Talking
Sprocket Center .com
Superlite Black 44 tooth
Dont bother me with DETAILS!
Pismocycleguy is offline
post #6 of 24 (permalink) Old 05-04-2011, 05:52 PM
pegrider's Avatar
Gear Ratios?
Hey, twowheeladdict, the factory specification for the gear ratios for both the Versys and the Ninja 650R are identical for the 2009 models. Can't speak to the other years.
I get 60 mpg on the side roads and 50 mpg on the superslab on my 2009. And that's after repeated trips and checks.
pegrider
"It is the journey, in the end."
pegrider is offline
post #7 of 24 (permalink) Old 05-04-2011, 11:04 PM
Motopsycho's Avatar
15T-46T: 3.067 - 0.0% TALLER 100% ENGINE SPEED 6000 RPM AT 78 MPH
15T-44T: 2.933 - 4.3% TALLER 95.7% ENGINE SPEED 5742 RPM AT 78 MPH
15T-43T: 2.867 - 6.5% TALLER 93.5% ENGINE SPEED 5610 RPM AT 78 MPH
15T-42T: 2.800 - 8.7% TALLER 91.3% ENGINE SPEED 5478 RPM AT 78 MPH
15T-41T: 2.733 -10.9% TALLER 89.1% ENGINE SPEED 5346 RPM AT 78 MPH
15T-40T: 2.666 -13.1% TALLER 86.9% ENGINE SPEED 5214 RPM AT 78 MPH
15T-39T: 2.600 -15.3% TALLER 84.7% ENGINE SPEED 5082 RPM AT 78 MPH
+15 FACTORY FRONT 46 FACTORY REAR+
SUNSTAR 43 TOOTH $49.99
http://www.rockymountainatvmc.com/pr...&sizeAttr=1420
__________________________________________________ ______________
RENTHAL 39-47 TOOTH $49.99
__________________________________________________ _______________
JT 40-45 $30.99-$31.99
http://www.rockymountainatvmc.com/pr...&sizeAttr=1677
SUPERSPROX 40 OR 43 $89.95
http://www.rockymountainatvmc.com/pr...FamilyId=22817
IBA # 49372
Motopsycho is offline
post #8 of 24 (permalink) Old 05-05-2011, 01:24 AM Thread Starter
hey toofer got mine at sprocketcenter.com
Rodski is offline
post #9 of 24 (permalink) Old 05-05-2011, 11:45 AM
Sprocketcenter - ok, thanks for both replies. Seems like 44T for $44. Easy to remember. Just returned to read this thread.
2 weeks ago did the speedy kit. This week doing the seat mod. Next month doing the sprocket, and am leaning to the 44T rear with original front.
toofer is offline
post #10 of 24 (permalink) Old 05-05-2011, 01:45 PM
Question Which Seat Modification?
toofer
Which seat modification are you going with?
post #11 of 24 (permalink) Old 05-05-2011, 08:46 PM
Nytrydr's Avatar
are you running the stock gearing?
Nytrydr is offline
post #12 of 24 (permalink) Old 05-06-2011, 05:44 AM
pegrider's Avatar
Running stock
Yes, Nytrydr, that's with stock gearing.
The two-lane roads are twisty and up-and-down hill.
Superslab is what it is. Boring in a way, but ride fast and furious or be run over around the metro areas.
pegrider
pegrider is offline
post #13 of 24 (permalink) Old 05-06-2011, 07:56 AM
Originally Posted by Pismocycleguy View Post
toofer
I have removed the seat and shaved it down from the top using a sharp knife and sandpaper.
Also have purchased the Walmart gel cushion found in their automotive department ($19.95). Until I achieve what I really like, I simply "shave", recover with the original vinyl using duct tape underneath and go out riding for 30-60 minutes.
It is trial and error, but I am getting close to what feels comfortable to me. Last night I had the bike out for 1 1/2 hours, and only thought about my buns on the bike 2 or 3 times during the entire ride.
With the original seat, I kept thinking of nothing but my buns on the bike and my sliding into the tank ( which is very uncomfortable).
I've been playing with my seat on and off for about 3 weeks. Besides the weather has been Yucky, so riding has been very limited. I discovered that merely sitting on the bike is not a fair comparison. Even when I have felt comfortable sitting on the bike in my garage, when I took the bike riding, I did not feel comfortable.
But, what I had last night was good, I will try to improve it some by trimming the Walmart cushion. What I have is essentially the original seat cushion shaved and trimmed down quite a bit and using the Walmart cushion on top of the original foam. The Walmart cushion will require some trimming as well.
toofer is offline
post #14 of 24 (permalink) Old 05-06-2011, 09:38 AM
I find it odd that so many manufacturers make a 43 and 45 but no 44. I wonder why?
versman is offline
post #15 of 24 (permalink) Old 05-06-2011, 10:43 AM
TowerMan's Avatar
www.Supersprox.com do a 44 tooth, as I have just received a new RST478-44 rear today
http://www.supersprox.com/uk/products.php?cat=10068 - have them in stock now
BUT
http://www.supersproxusa.com/products.php?cat=13259 - do not have them in stock at the moment
Richard
at
TowerMan is offline
post #16 of 24 (permalink) Old 05-07-2011, 08:50 PM
DR_
I received my sprocketcenter.com Superlite 44t today and got it installed in about 30 minutes. I was pretty skeptical of a lot of the comments here but not any more. The sprocket really matches the bike so much better than the stock 46t. It is a much smoother relaxed ride now. Great mod.
DR_ is offline
post #17 of 24 (permalink) Old 05-08-2011, 06:56 PM
I too have changed rear sprockets- I went with a 43-tooth. Just bought a less-expensive JT sprocket; not knowing if I would really like this change or not.
Has sure made a nice change for highway riding- bike feels a lot more relaxed.
NDTransplant is offline
post #18 of 24 (permalink) Old 05-08-2011, 08:46 PM
BAMF's Avatar
yea i was looking for some feedback on that.
I am in between getting a 43 or a 44 tooth.
I ride 30 miles each way to work everyday and my trips are mainly highways or long windy roads. I DO ride 2 up so i dont wanna lose all my torque but wouldnt mind losing a little if it made cruising more efficient and less stress on the motor.
any opinions?
1997 KLR 650
2011 Halle-friggin-leuya Versys
BAMF is offline
post #19 of 24 (permalink) Old 05-08-2011, 09:24 PM Thread Starter
BAMF I would go with the 44t instead of the 43t. Reason being if you are riding two up it might be too sluggish for you. There is only about a hundred rpm difference between the 44t and 43t. Go to gearingcommander.com and you can see the differences and play with ratios. Good luck and enjoy the change!
Rodski is offline
post #20 of 24 (permalink) Old 05-08-2011, 09:31 PM
Pretbek's Avatar
any opinions?
I have the 43T which I chose because I mostly commute. It works fine for 2 up too, but my next sprocket is a 44T, because I find 43T to be just a little too tall.
44T is probably the Goldilocks sprocket. For me.
Pretbek is offline
