That buzz........Finally - Kawasaki Versys Forum
post #1 of 5 (permalink) Old 05-01-2011, 07:51 AM Thread Starter
Toddzilla's Avatar
I finally figured out my fairing buzz.
Last fall I went through and used the fuzzy side of Velcro to dampen my fairing buzz. It helped some, I probably had 3 or 4 different buzzes.
The loudest didn't go away. yesterday I figured out where it was and went to work.
Here is where it was coming from.
Note the foam pieces that are worn through.
Here are the thin little tabs that are the culprit.
And my solution. Fuzzy Velcro of course.
I also cut up a bicycle inner tube and made a couple of dampeners for between the windscreen and the brackets. there was a buzz there also which is possible if the screen is in the top or bottom position.
Now I need one of those smiley faces that are in a yoga position..........ohmmmmmmmmm.............not the electrical kind.
Todd
"Always go forward. Going straight is no fun."
'08 Red
Givi shield
Famsa Tank bag and pannier set
Happy Trails Panniers
Zeta blinker handgaurds
SeatPad Mod w/ Alaska leather cover
Heated grip wraps
Fiammi Hi & low tone horns
2008 V
1985 BMW R80
1989 Honda XR600R (650)
Toddzilla is offline
post #2 of 5 (permalink) Old 05-01-2011, 09:14 AM
Good find, I'll keep that spot in mind......if I ever get to ride, we got a foot of snow yesterday!!!!
**Sold**2008 Red Versys, Algard, LSL Frame Sliders, EvoTech Radiator guard, Givi screen, Givi V35 panniers, Moto Werks handlebar riser and footpeg lowering blocks, Aprilia Tuono mirrors, Carbon Fiber FendaExtenda, Spools/Sliders front & rear
2000 DRZ440E
2003 KLX440R
2003 TTR125LE
zgfiredude is offline
post #3 of 5 (permalink) Old 05-01-2011, 09:24 AM
I cut those little tabs off and just put a thick piece of black vinyl covered foam where you put the velcro. It worked perfect. Idn't see what the use of thin little tabs is other than to cause noise.
the borg is offline
post #4 of 5 (permalink) Old 05-01-2011, 05:58 PM
Sprocket's Avatar
1/8 inch think foam weather stripping tape works well too.
Sprocket is offline
post #5 of 5 (permalink) Old 05-02-2011, 11:30 AM
miguelito's Avatar
I gotta work on mine again, (for the third time). I add fuzzy velcro like you, and the buzzing goes away for a while, then eventually returns. Very annoying.
Michael
- Terry Pratchett
miguelito is offline
