sync/motion mix? - Kawasaki Versys Forum
post #1 of 13 (permalink) Old 04-27-2011, 11:09 PM Thread Starter
Mawson's Avatar
sync/motion mix?
I need to replace my rear tire. ( scorpion sync). Front is same but still lots of tread. Being on a bit of a budget, I am thinking of just replacing rear with a conti motion.
Anyone see an issue running a sync-front/conti motion rear combo?
Last edited by Mawson; 04-28-2011 at 12:31 AM. Reason: poster is semi retarded and can't type
Mawson is offline
post #2 of 13 (permalink) Old 04-27-2011, 11:41 PM
Why not maintain the same make and just change the back.
IMHO- not advisable to mix tire by different manufactures though some are running mix set's.
It depends how much you want to risk as handling do change a bit by these mixed set's.
Just my 2cts thoughts.
post #3 of 13 (permalink) Old 04-27-2011, 11:50 PM
Anyone see an issue running a sync-rear/conti motion front combo?
You now have Scorpion Synch front and rear, and want to have a Conti Motion rear with Scorpion Synch front? If so, there's something wrong with the end of your post...
post #4 of 13 (permalink) Old 04-28-2011, 12:32 AM Thread Starter
Mawson's Avatar
You are correct sir!Post has been corrected.
Mawson is offline
post #5 of 13 (permalink) Old 04-28-2011, 12:37 AM
I think that combo would be just fine... My Conti Trail Attack rear with Avon Distanzia front combo is absolutely excellent. Like your proposed combo, I also like having a bit more aggressive tread in front to reduce the Versys' front washout tendency on dirty/gravel roads.
post #6 of 13 (permalink) Old 04-28-2011, 12:53 AM Thread Starter
Mawson's Avatar
Perfect. I will order a conti and then replace as a set next time.
Mawson is offline
post #7 of 13 (permalink) Old 04-28-2011, 01:01 AM
Cool... Let us know how well it works out.
post #8 of 13 (permalink) Old 04-28-2011, 10:52 AM
Mawson,
MANY times, on MANY different bikes I've run mis-matched front and rear tires. (And don't forget that some bikes come from the factory w/ a bias at one end, radial at the other which is a NO-NO for cars!)
post #9 of 13 (permalink) Old 04-28-2011, 01:38 PM Thread Starter
Mawson's Avatar
Mawson,
Thanks for the input. As it turns out I can't find a conti motion in stock at a decent price right now so I may just have to get another sync for the rear anyway...
Mawson is offline
post #10 of 13 (permalink) Old 04-28-2011, 09:09 PM
brothercannon's Avatar
I'm running a scorpion sync on the front and a tourance on the rear with no issues.
brothercannon is offline
post #11 of 13 (permalink) Old 04-28-2011, 09:36 PM
Should be good.
An enduro front and an intermediate on the rear.
The world's your oyster. Good rides,man.
post #12 of 13 (permalink) Old 04-28-2011, 11:23 PM
Motorcycle Superstore. Rear ContiMotion for $85.99.
http://motorcycle.motorcycle-superst...chAutoComplete
post #13 of 13 (permalink) Old 04-28-2011, 11:30 PM
I like the Mich PR so far, but that is a great price! How many miles on the rear, anybody??
