3 blank connectors Versys 2010 - Kawasaki Versys Forum
post #1 of 16 (permalink) Old 12-29-2010, 12:14 PM Thread Starter
Dragothic's Avatar
On the left side of the engine next to a radiator I found three different connectors that are not connected anywhere. Who knows what these connectors?
Dragothic is offline
post #2 of 16 (permalink) Old 12-29-2010, 04:16 PM
On the left, next to the radiator?? Can you get a pic?
invader is online now
post #3 of 16 (permalink) Old 12-29-2010, 09:52 PM
siyeh's Avatar
siyeh is offline
post #4 of 16 (permalink) Old 12-29-2010, 10:26 PM
Tigerpawed's Avatar
Does this help?
http://www.kawasakiversys.com/forums...2&postcount=17
Tigerpawed is offline
post #5 of 16 (permalink) Old 12-29-2010, 10:35 PM
Interesting.... first was thinking for the optional abs, but thought it was on the right.
post #6 of 16 (permalink) Old 12-29-2010, 11:16 PM
Yes, I remember the great undocumented 2010 5A fuse mystery... It has now been documented.
Originally Posted by Capn Kirk View Post
I just looked in the 2010 factory service manual and in the appendix, it is listed as "Accessory Relay Fuse 5 A (Insert the connector from the bottom in the rear fender side bracket)"
That's it. No further mention on WTH it is..
Maybe for heated clothing or such?
Originally Posted by Tigerpawed View Post
Here's two photos showing the 5 amp fuse and holder. You can see the two color-coded wires, which are white with a olive-green stripe. One has widely spaced stripe, the other is more closely spaced.
Looking towards back of bike:
Looking from left side:
The wires route into the main wiring bundle. In the top photo, it curves around and heads towards the viewer. I didn't see anyplace obvious they appear at the far end, but I didn't take anything apart. I'm still at work (on break, or brake or somethin')
post #7 of 16 (permalink) Old 12-30-2010, 06:16 AM
Cant see any and what year is your V. Mine is 09 and I dont see any blank connectors.
post #8 of 16 (permalink) Old 12-30-2010, 08:10 AM Thread Starter
Dragothic's Avatar
Pictures.
post #9 of 16 (permalink) Old 12-30-2010, 08:55 AM
Hardware's Avatar
Hey Tigerpawed, how did you do that `View Single Postí link?
I can see how to construct it by hand (.../showpost.php?p=nnnnnn&postcount=nn) but itís kinda cumbersome to do. Is there a forum thread tool/function that Iím missing?
~~ Live Like You're Dying ~~
Hardware is offline
post #10 of 16 (permalink) Old 12-30-2010, 09:14 AM
If you look in the upper right corner of each post, there is a number. If you click that number, it'll open the single post. The you just copy the URL from your browser address bar, & paste it in the "link" box in your reply, just like any other link....
post #11 of 16 (permalink) Old 12-30-2010, 09:21 AM
post #12 of 16 (permalink) Old 12-30-2010, 09:25 AM
This applies to 2010+ Versys only... Mine is a 2007.
post #13 of 16 (permalink) Old 12-30-2010, 09:53 AM
Thanks Invader, didn't see the small title in the original post.
Happy new year.
post #14 of 16 (permalink) Old 12-30-2010, 09:59 AM
Pegasus's Avatar
Those connectors do not even look like stock Kawasaki connectors. Trace the wires and see where they go. Use a volt meter and see if any are hot with ignition on and ignition off. You are on the trail then Sherlock.
Pegasus is offline
post #15 of 16 (permalink) Old 12-30-2010, 10:08 AM
blipco's Avatar
Sherlock used to say "come Watson, the game is afoot".
blipco is offline
post #16 of 16 (permalink) Old 12-30-2010, 08:42 PM
Hardware's Avatar
... in the upper right corner of each post, there is a number. If you click that number...
Thanks Bear
Hardware is offline
