Backoff XP Brake Light Module not working - Kawasaki Versys Forum
Like Tree1Likes
  • 1 Post By Bale2011
post #1 of 15 (permalink) Old 08-27-2017, 03:48 PM Thread Starter
I tried installing this today and couldn't get it to work. Followed the instructions and several YouTube videos to the letter.
1) Disconnected battery.
2) Grounded black wire (ground) from Backoff to frame.
3) Cut the blue brake light wire.
4) Attached red wire from Backoff to blue wire leading to power.
5) Attached white wire with red stripe from Backoff to blue wire leading to bulb.
6) Reconnected battery.
This left me with a tail light only and no brake light.
Just for the heck of it, I repeated the process using the red brake light wire (supposed to be the tail light). This left me with a fully functioning tail and brake light but the Backoff unit did nothing. I'd send it back, but now the wires are all mangled. At least it was just $41 with shipping. Anyone have an idea of what went wrong?
Bale2011 is offline
post #2 of 15 (permalink) Old 08-27-2017, 07:43 PM
Read the fine print
Once
installed,
The
original
BACKOFF module will emit 3 short brake light flashes and then one long flash and it repeats. The signal automatically repeats itself as long as the brake lights are on. This pattern is not random, but has been selected because of its
ability to retain following drivers attention.Please Note: This module will not work with LED brake lights.
So you are frustrated and would like to make it work NP. Very simple, this is what you do, go back to the original connection, blue wire from the bulb to red white and blue power to the red wire. This time you are also going to connect a resistor to the red/white and the other end of the resistor goes to ground. https://www.amazon.com/uxcell-Alumin...eywords=40+ohm This resistor is overkill but readily available, and no need to worry about it overheating, about a 5 watt parasitic load while braking. I see no reason why this shouldn't work, as it imitates a incandescent bulb .
The reason why, the back off is a series switching device that uses voltage drop across it to drive the internal electronics, if you look it has a 10 amp rating or 140 watt rating, the total load is 5 watts plus the Led brake light should be sufficient to drive the back off, However https://www.amazon.com/Rating-Alumin...0+ohm+resistor you could buy 2. This would give 10 watts plus, guaranteed to work. Try one first and if needed 2. Many of these devices have a minimum of around 0.3 to 0.5 amps to drive them, the LED brake light is much less . The 40 ohm is 14.2 VDC / 40 = 0.335 amp , two is 0.67 amp or 10 watts
onewizard is online now
post #3 of 15 (permalink) Old 08-28-2017, 01:46 AM
Rotten Ronnie's Avatar
Send a message via Skype™ to Rotten Ronnie
I went with this unit as it works with both incandescent and led.
http://www.3rdbrakeflasher.com
2009 Kawasaki Versys 650, 2001 Honda XR400R (street plated)
Ride Reports and other drivel:
Rotten Ronnie is offline
post #4 of 15 (permalink) Old 08-28-2017, 06:20 AM Thread Starter
Onewizard, its in moments like these that a man can either feel stupid about making such an obvious mistake, and/or laugh at himself. I shall do both! Thanks.
Rotten Ronnie likes this.
Bale2011 is offline
post #5 of 15 (permalink) Old 08-28-2017, 02:29 PM Thread Starter
Onewizard, I'm revisiting this again because I see in your post you're quoting info for the original Backoff, whereas mine is the XP model and their website says the XP works with LED lights.
"The BackOFF™ XP Brake Light Module automatically flashes your brake light(s) to capture the attention of following drivers and to make your motorcycle more visible. When installed, the motorcycle's brake light becomes significantly more noticeable because your brake light(s) will flash with your choice of 2 attention getting patterns. This module is designed to work with standard incandescent brake lights, LED brake lights, or a combination of both (up to 10amps)."
Link: BackOFF? XP Brake Light Module - Signal Dynamics
Guess I'm back to square one.
Bale2011 is offline
post #6 of 15 (permalink) Old 08-28-2017, 02:35 PM
What bike are you installing this on?
post #7 of 15 (permalink) Old 08-28-2017, 04:06 PM
Correct Model Helps
I am digging into this again, the very second I saw more than two wires and read the instructions tells me you have something connected wrong. FYI Signal Dynamics is a reputable company.
post #8 of 15 (permalink) Old 08-28-2017, 04:17 PM Thread Starter
It's a 2017 650 LT.
Bale2011 is offline
post #9 of 15 (permalink) Old 08-28-2017, 04:18 PM Thread Starter
I'm sure it's me. Going to wire up some pig tails/connectors for further testing. Thanks!
Bale2011 is offline
post #10 of 15 (permalink) Old 08-28-2017, 04:44 PM
Directions Mode 1 Or 2
Personally I would use mode #2 https://store-wfdoukr.mybigcommerce....20Off%20XP.pdf
Mode 1:
If you choose to use mode 1, you will not need the red wire with white stripe used for mode 2. Secure the extra wire safely aside.This mode emits 3 short brake lightflashes and then one long flash and repeats. The signal automatically repeats itself as long as the brake lights are on. This pattern is not random, but
has been selected because of its ability to retain following drivers attention.
Mode 2:Note:
If you choose to use mode 2, you will not need the white wire with red stripe used for mode 1. Secure the extra wire safely aside.This mode emits a visual signal of 5 quick flashes, followed by a steady on light that remains steady as long as the brake lights are on.
I would be very annoyed if I was behind someone with mode #1 at a stop light, what I will do is describe proper wiring for mode #2.
The solid red wire goes to the blue original power source for the brake light. The black goes to I would recommend the frame ground, extend it as the wiring in the MK-3 is short everywhere, unless you are competent at doing a solder tap on the tail light ground that is my recommendation. The red with white tracer goes to the brake light LED which is your blue wire to LED . The white with red tracer gets insulated / not used.
If you choose mode 1, you insulate the red with white tracer and use the white red to the blue wire to LED Brake.
post #11 of 15 (permalink) Old 08-28-2017, 04:56 PM
chid's Avatar
I use the same BackOFF XP on my 2015 and I used it on my 2009 also.
When I moved to 2015 it was not working in the beginning, so I did some testing.
Some wires are reversed by Kawasaki on the 2015, look at my thread, I think I mentioned that when I installed the module.
Versys 2015 Green
chid is offline
post #12 of 15 (permalink) Old 08-29-2017, 06:49 AM Thread Starter
Do you have a link to your thread?
Bale2011 is offline
post #13 of 15 (permalink) Old 08-29-2017, 05:40 PM
chid's Avatar
Apparently I didn't post it in my thread, but here:
BackOFF XP problem on Versys 2015
Versys 2015 Green
chid is offline
post #14 of 15 (permalink) Old 08-30-2017, 05:17 AM Thread Starter
You mentioned "Black/yellow is ground, red is running light and blue (middle position) is brake light." That's the same as on my 2017. And it appears we wired the XP the same way with the exception that I grounded mine to the frame and it looks like maybe you tapped into the ground wire (?). Hard to see in your pic.
Bale2011 is offline
post #15 of 15 (permalink) Old 08-30-2017, 05:09 PM
chid's Avatar
Maybe you can see it better here.
The ground was connected to the bike later, this is just to show the wires from BackOFF
Versys 2015 Green
chid is offline
