Posts time stamp off by 7 hours? - Kawasaki Versys Forum
post #1 of 12 (permalink) Old 08-25-2017, 01:04 PM Thread Starter
It a minor annoyance, but since I've been on this forum, the postings are 7 hours off . I've looked through the settings on the website, but don't see a place to indicate time zones.
Just me?
It's 10:03 AM here.
File Type: png Screen Shot 2017-08-25 at 9.55.28 AM.png (16.0 KB, 9 views)
Buffalo_Bob is offline
post #2 of 12 (permalink) Old 08-25-2017, 04:07 PM
ItsForrest's Avatar
There is a place to change your time zone. Click on User CP up in the right corner under the search bar, then go down the menu on the left hand side until you see the Settings and Options group and click on Edit options. From there scroll down until you see the Time Zones section. There you can pick your time zone.
The urge to buy terrorizes
ItsForrest is offline
post #3 of 12 (permalink) Old 08-25-2017, 06:31 PM Thread Starter
Thanks ItsForrest. I poked around in the settings but couldn't find it.
Small victories
post #4 of 12 (permalink) Old 08-25-2017, 07:03 PM
Tools > User Control Panel (aka CP) > Edit Options
post #5 of 12 (permalink) Old 08-25-2017, 08:08 PM
I will Try
Just me?
It's 10:03 AM here.
first you click on user CP , to the left of Log Out
The third down on the left coloumn under Your Profile
is Settings & Options the fourth down under that heading is Edit Options click this
The very first heading says Login & Privacy
Next one is Messaging & Notification take your time and go through this as some can't receive PM because of this not being set properly
OK keep scrolling down and Date & Time Options shows up,
Set the appropriate one for your neck of the woods, then scroll down even further to Miscellaneous Options at the very bottom of this heading it says SAVE CHANGES
if you don't click save changes, nothing changes.
onewizard is online now
post #6 of 12 (permalink) Old 08-25-2017, 11:46 PM
motorboy's Avatar
Never gave it much though but mine was off too-easy to set-now do you have any idea why this site takes so long to load(at lease for me )I'm running 100 megs speed but it takes 10-15 sec to load each page it's only this site that's slow using my laptop??
Deep in Cajun Country
motorboy is offline
post #7 of 12 (permalink) Old 08-26-2017, 01:14 AM Thread Starter
So it wasn’t just me!
post #8 of 12 (permalink) Old 08-26-2017, 10:15 AM
FYI I am still Learning!!
One more setting, under user CP, Your Profile / Edit Your Details, part way down Toggle Right sidebar , Disable
this gets rid of the advertising etc. make sure you scroll all the way to the bottom and hit Save
Yes I am still learning, sometimes it is the question that turns on my troubleshooting skills, been doing that for over 40 years, once turned on it drives me to find a answer. I look back, a lot of problems on this site , I found that answer for.
As to slowness, it took 30 minutes for my Dell Inspiron laptop to finally load FireFox after one crash and unresponsive script, all the time my physical being is saying , throw it through the door, not my connection as the desktop computer is working fine, I am just not allowed to use it
post #9 of 12 (permalink) Old 08-27-2017, 01:40 PM
16VGTIDave's Avatar
Unhappy
Not sure if I'm doing something wrong, but I've done this and that annoying right sidebar is still there. I don't think adblocking plugins be causing it, as I've tried loading the site with them disabled. I have just added the sidebar to the block list and just have a white space on the right now. Much faster!
16VGTIDave is offline
post #10 of 12 (permalink) Old 08-27-2017, 02:00 PM
What Version Are You Using?
I am running the Kawasaki Versys Full Light , in user CP scroll all the way to the bottom, left bottom if you are using full light, this is in the black area, it shows what version you are using, also you can change it here. FYI as stated previously, checking a box won't do it, you need to click Save Changes The advantage of disabling the right side bar in full light is the text and everything else is full page width .The only thing to the right is the Smilies , looking at my monitor I have 16 inches wide per line of text. Since I wear trifocals it makes reading a breeze . In fact the post is 17 inches wide once saved.
post #11 of 12 (permalink) Old 08-28-2017, 11:09 AM
16VGTIDave's Avatar
Yup. I'm using the same theme, and the setting to disable the side bar is set. And yet the side bar still shows, unless I block it with AdBlock - which is what I'm doing. It's probably an issue with the older forum software (why most forums have switched to XenForo).
post #12 of 12 (permalink) Old 08-28-2017, 04:59 PM
Windows 7&10 FireFox & Chrome
As in the title, using chrome I had ABP , however it is disabled on this site as some things won't display for me as a mod. Both systems and both browsers have the sidebar gone with that setting. As I said before, even on the laptop I have close to a foot per sentence of text, across the screen while composing, the only thing to the right is the smilies. Once posted it is more like 14 inches of text per sentence. For me it was annoying, if it annoyed me it probably did for others, hence my effort to help. If you are happy with your work around NP
