Shinko 705 front tire on a 08 v - Kawasaki Versys Forum
post #1 of 11 (permalink) Old 06-01-2017, 02:32 PM Thread Starter
Red08versys's Avatar
I am looking at buying a set of shink 705 tires 150/70/17 rear. My question is concerning the front can I run a rear tire up front like a 130/80/17 I like the look of the bigger tire up front
Sent from my SM-G920R7 using Tapatalk
Rburg
Red08versys is offline
post #2 of 11 (permalink) Old 06-01-2017, 07:20 PM
Yes, but you'll need to raise the front fender. Here's my '08 w a 130/80 x 17 front.
post #3 of 11 (permalink) Old 06-01-2017, 07:32 PM Thread Starter
Awesome that is exactly what I wanted to hear it am actually going with shinko 805 instead but same size front and rear. How did you raise the finder just use some flat steel and make a adapter?
Rburg
post #4 of 11 (permalink) Old 06-15-2017, 07:58 PM Thread Starter
Well I got the 705's installed and the front finder raised itching to hit the dirt
Rburg
post #5 of 11 (permalink) Old 06-16-2017, 12:20 PM
I raised my front fender quite a bit LESS than you did - 1.375", and looking at yours I THINK you might get contact between your fender and the 'hard-stuff' above IF (when) you bottom your forks. Here's a link to a thread I started on raising the front fender.
http://www.kawasakiversys.com/forums...ger-tires.html
post #6 of 11 (permalink) Old 06-16-2017, 12:24 PM Thread Starter
I think I am going to get branded front seprate lines and get a different front fender and mount it to the lower triple and get fork guards
Rburg
post #7 of 11 (permalink) Old 06-19-2017, 01:16 AM
would there be a problem if i ran a shnko 130/80 x 17 up front with a tourance on the rear? i can't take the "whine" of the front tourance anymore.
marc is offline
post #8 of 11 (permalink) Old 06-19-2017, 01:22 AM Thread Starter
Absolutely but the 705's are not a silent road tire
Rburg
post #9 of 11 (permalink) Old 06-19-2017, 02:47 PM
Front tires normally have very a different cross sectional profile than a rear tire. They have an evenly rounded tread area to provide consistent feel and contact patch in a turn regardless of lean angle and a smooth turn in. As such I am wondering what kind of steering response you would get from the much flatter profile of the 130 rear on the front. Seems it would contribute to great braking when the bike is standing up but poor turning, especially on pavement. IE - from the picture the contact patch when vertical appears huge but then drops off to nothing as the bike leans.
Not sure about the 705 but most Shinko tires now come in stock sizes to fit the Versys now including 120/70-17 front. In a pinch you can use a 150/70-17 in place of the OEM 160/60-17 on the rear without issue.
post #10 of 11 (permalink) Old 06-19-2017, 02:49 PM Thread Starter
The 130 is labeled as a front or rear tire. I have found no downfall to turning than the feel of the front end. It is still very nimble.
Rburg
post #11 of 11 (permalink) Old 06-19-2017, 09:41 PM
DaveC's Avatar
It's in the Radial section of their website
Shinko Radial E705
120/70R17 front and 150/70R17 rear are available.
Dave C
2008 Versys (Red)
Last edited by DaveC; 06-19-2017 at 09:44 PM. Reason: Corrected link to Shinko website
DaveC is offline
