Rear Box questions - Kawasaki Versys Forum
post #1 of 10 (permalink) Old 11-14-2010, 05:49 PM Thread Starter
Rear Box questions
How do the Givi's compare to Kawasaki's for hard side bags? Looking at getting set soon.
Mark
Mark
_____________________________
09 Versys blue, 87 KX-250
11 H-D V-Rod, 13 H-D Ultra
Retired Eagle driver, Long Live the Eagle
Markk9 is offline
post #2 of 10 (permalink) Old 11-14-2010, 07:07 PM
Same bags. Only difference is the color-matched inserts that Kawasaki has.
Madone1 is offline
post #3 of 10 (permalink) Old 11-14-2010, 08:09 PM
Yup. But I am pretty sure you can put the colored Kawi panels on the real Givis. Or paint them like I did.
08' Versys
HAWKSHOT99 is offline
post #4 of 10 (permalink) Old 11-14-2010, 08:59 PM
They are the same except for cosmetics.
Fastoman is online now
post #5 of 10 (permalink) Old 11-15-2010, 09:15 AM
Lours_Polaire's Avatar
Slight difference between the givi rack and the oem/kawi/givi one
Make a search on that matter and you will find lots of good info
In particular from DaveC who seem's to have nail that difference early on
LOP
Lours_Polaire is offline
post #6 of 10 (permalink) Old 11-16-2010, 12:17 AM
miguelito's Avatar
LOP
I believe one major difference between racks is that you can't mount a top box if you're using the kawi side racks. Not sure about the Givi racks.
Michael
- Terry Pratchett
miguelito is offline
post #7 of 10 (permalink) Old 11-16-2010, 04:09 AM
healdem's Avatar
as I understand it the only difference between OEM panniers and Givi V35 panniers is that the OEM ones are branded 'Versys', ie they have a Versys badge glued / stuck on the side. the OEM bags are made by Givi. You cna get colour cordinated inserts from Kawasaki for all colours prior to 2010. As yet I don't think you can get the 2010 Yellow and possibly the 2008 (US) red. Givi do do their standard range of colours which are usually gloss plain colours IE not the candy/pearlescent colours of the Versys
healdem is offline
post #8 of 10 (permalink) Old 11-16-2010, 05:38 AM
sharrison56's Avatar
I don't think you can get red inserts from Givi or Kawasaki. At least you can't in the states. You can paint either. I think the difference in the top case rack is that Kawasaki sells the SW Motech rack for the top case. I don't know who makes the OEM side case racks.
Steve
Now I have four!
sharrison56 is offline
post #9 of 10 (permalink) Old 11-16-2010, 06:06 AM
healdem's Avatar
OEM top box rails from SW Motech
OEM panniers + racks from Givi
..thats why you cannot have an OEM top box + rails AND OEM panniers + racks
you either
buy Givi Top Box rails in place of the OEM / SW motech rails to match the OEM / Givi pannier racks
buy SW Motech pannier racks in place of the OEM / Givi pannier racks to match the OEM / SW Motech rails
in essence stick to the same manufacturer and you should be OK
healdem is offline
post #10 of 10 (permalink) Old 11-16-2010, 12:40 PM
The Versys branded hard side cases are made my Givi. The side sticker label is the only difference between the two V35 models.
(I have these bags.)
The Versys branded rack for the V35 cases is made by Givi and has integrated welded grad handles (replaces the stock grand handles).
(I have these racks.)
The Versys branded rear rack is made my SW-Motech (the same thins as their Alu-Rack) and replaces the stock grab handles.
(I have this rack.)
You can make these two racks work together.
All you have to do it cut the welded grab handles on the side case racks, grind the welds spots smooth and paint the tabs. The SW-Motech rack will then mount very nicely as it would otherwise.
The two components were made ostensibly "incompatible" to prevent "overloading" of the bike - a legal issue. Note, Kawi was already sued by someone who got into an acccident then stated it was partially Kawi's fault for not including reflectors on the hard bags. If want them, you can find the different colored panels on the net, or paint them yourself.
It went this route because it is a very durable combo and I got very good deals on all of the components.
ednukey is offline
