Driveway drop, can't shift past 2nd. - Kawasaki Versys Forum
post #1 of 5 (permalink) Old 11-12-2010, 10:01 AM Thread Starter
Well, sometimes things happen sooner than later. I dropped the bike in the driveway in, perhaps, the gentlest way possible. While the shifter doesn't clearly appear bent, something has gone wrong because I can't shift past second gear now. Any ideas on what I can do other than take her to the shop?
Lowcountry is offline
post #2 of 5 (permalink) Old 11-12-2010, 10:04 AM
angst's Avatar
Bummer
Is the engine when you try to shift or off?
Cheers!
angst is offline
post #3 of 5 (permalink) Old 11-12-2010, 10:04 AM
twistedthrottle's Avatar
I had a similar experience with a Yamaha FZ1. It turned out to be that the mount holding the shifter had been tweaked just enough to cause the shift rod to bind. Look at that.
twistedthrottle is offline
post #4 of 5 (permalink) Old 11-12-2010, 10:11 AM
Possible reasons:
Shift fork bent or seized
Gear stuck on the shaft
Gear positioning lever binding
Shift return spring weak or broken
Shift return spring pin loose
Shift mechanism arm spring broken
Shift mechanism arm broken
Shift pawl broken
Does the gear level return after stepping on it or is it jammed in position?
post #5 of 5 (permalink) Old 11-12-2010, 11:37 AM
Baron650's Avatar
What year and how many miles on bike? My guess, '09 & not many.
Others have had similar issues, most resolved themselves, a few required service.
Try an Advanced Google search with your terms limited to this site.
Baron650 is offline
